Old 05-29-2010, 07:43 PM   #14881
ShadowAu's Avatar
Hi guys... looking for a little feedback
Was running My RS with a 8.5T SP 3.0 motor on a fairly tight track but with a long high-speed section (can't really call it a straight as it actually has 3 corners in it but they are really only brief off the throttle corners)
My setup started as (based on Steve Curtis's 7.5 profile) -
Radio - Futaba 3VC (basically a stick version of a 3PK)
FDR: 7.1
Drag Brake 25
Brake Strength 100
Neutral Width: 15
Throttle Profile: 3
Push: Off
Timing: 30
Boost: 10
Delay: 2.0
Ramp: 2
End RPM: 18k
Start RPM: 5k
I found this setup REALLY punchy but also very touchy as far as throttle even after playing with Throttle EXP etc... what it lacked was top end/straight line speed so I changed the following -
Timing: 40
Boost: 10
Delay: 1.5
Ramp: 2
End RPM: 20k
Start RPM: 5k
This felt better but still very punchy and still lacking what I expected as top end... I was doing no better than the local 10.5 runners and while a 8.5 isn't a big jump I was expecting better than I was getting... the motor was also barely getting above 45C and the ESC was showing only 1 light for temp... Next changes -
Neutral width - 25
FDR - 6.4
Again felt like more top end and STILL punchy... unfortunately the car developed other issues and I couldn't get any more runs in..
Any advice or feedback on the changes I was making/setup generally?
I am quite content with doing what I do
Don't mistake not being happy for unhappiness - its not the same thing
ShadowAu is offline   Reply With Quote
Old 05-29-2010, 08:16 PM   #14882
20 SMOKE's Avatar
Trader Rating: 101 (100%+)
Originally Posted by DaveW View Post
Supposed to be 0 timing. I didnt try any of the positive motor settings, and i didnt like the timing set at either -5 or -10 on the motor. It felt too punchy, and harder to modulate. Maybe with throttle profile 2, but i am used to linear steering and throttle and use very little expo if any at all. Ill try it out soon though.
FDR: 7.1
Drag Brake 25
Brake Strength 100
Neutral Width: 15
Throttle Profile: 3
Push: Off
Timing: 30
Boost: 10
Delay: 2.0
Ramp: 2
End RPM: 18k
Start RPM: 5k
Timing: 40
Boost: 10
Delay: 1.5
Ramp: 2
End RPM: 20k
Start RPM: 5k
Neutral width - 25
FDR - 6.4
for both, hit the calculate rpm and go to the next lower number under the 5k and this will help smooth it out if it is still punchy go up 1k on the endrpm
Jamie W
*Team Tekin*Tekno-rc*DE Racing*AKA*DDHRC*
20 SMOKE is offline   Reply With Quote
Old 05-30-2010, 12:46 AM   #14883
I'd just put it on dual-mode and unleash the power
Agama A8 Evo | GRP .21 | Spektrum | Savox
My car just hit 88mph. I hope it comes back soon....
JR007 is offline   Reply With Quote
Old 05-30-2010, 08:37 AM   #14884
Does the boost/turbo works on sensorless?
Winson is offline   Reply With Quote
Old 05-30-2010, 08:54 AM   #14885
stiltskin's Avatar
Trader Rating: 102 (100%+)
No it doesn't. The sensor is required for the turbo to operate.
Tony Rumple
Team EAM // Gravity RC
stiltskin is offline   Reply With Quote
Old 05-30-2010, 06:27 PM   #14886
ShadowAu's Avatar
How is dual mode different?
Old 05-30-2010, 06:30 PM   #14887
20 SMOKE's Avatar
mod motors are usually in dual mode,there is only timing advance used with 30*
Jamie W
Old 05-30-2010, 07:13 PM   #14888
ShadowAu's Avatar
I was meaning more in regards to performance versus the sensored mode
Old 05-30-2010, 07:54 PM   #14889
20 SMOKE's Avatar
smoother
Jamie W
Old 05-30-2010, 08:50 PM   #14890
Dual mode is sensored to stat off, and sensorless when it's rolling. It doesn't use any dynamic timing, but does still have esc timing if you want.
Dual Mode is almost always faster for lower turn motors, not to mention it's a hell of a lot easier to set up without all the other guff to worry about.
Old 05-30-2010, 09:23 PM   #14891
hpisims's Avatar
Hi everyone I was wondering if anyone could help me out with some settings for a 130' x 75' asphalt track I will be running a dou2 17.5 just need a good starting setup any help is appreciatied. Thanks.
J.SIMS
Team Associated TC6-Viper R/C Solutions-Sweep Racing-Fullthrottle Motorsports-APH
www.speedybillsrc.com
www.ovrccc.com
hpisims is offline   Reply With Quote
Old 05-30-2010, 09:34 PM   #14892
Senna Racing's Avatar
fdr 4.5-5.5
Timing 30
turbo 10
delay .5
start 5xxx
end 15xxx
Feral Batteries for all your on road needs
TRF 416, Fantom Batteries, Sorex, Tekin
Senna Racing is offline   Reply With Quote
Old 05-30-2010, 09:43 PM   #14893
dewaltracin's Avatar
just getting into onroad racing was wondering what would be a good esc motor combo for a T2 thanks Lee
MBX7R, MBX7T, sidewinder fuel, aka, novarossi
B44.3, hobbywing 6.5, smc
B5m, hobbywing 8.5, smc
TEAM "C" Stadium truck
hotshot rc race track
dewaltracin is offline   Reply With Quote
Old 05-30-2010, 09:48 PM   #14894
were and what do you plan to race
but Tekin have great products for all elec racing
Old 05-30-2010, 10:03 PM   #14895
A Ilievski's Avatar
Trader Rating: 39 (100%+)
36mm rollout
50 Boost
15 Turbo
Start 3200
End 9000
.2 Delay
Alex Ilievski
*INFINITY * R1 WURKS * PLAIG BEARINGS* SPEEDY RC
A Ilievski is offline   Reply With Quote
Tekin Redline RS Sensored ESC and motors, opinions for offroad? Cain Electric Off-Road 4230 06-07-2015 04:38 PM
Sensored vs. Sensorless lemansracer Electric On-Road 71 02-14-2009 03:19 AM
New Tekin Redline Sensored Motors are Roar Legal! Randy_Pike Electric On-Road 3 08-05-2008 02:08 AM
Tekin Redline Sensored 10.5 HUCKMAN Electric On-Road 6 07-15-2008 08:50 PM
sensored vs sensorless bprocket Rookie Zone 5 05-16-2008 09:38 AM
Tags
v203, vegas 2.0
