Old 05-28-2010, 06:05 AM   #14866
20 SMOKE's Avatar
Trader Rating: 101 (100%+)
Originally Posted by microcrazy24 View Post
will the Rx8 that is on rctvlive work fine in an 1/8 on road car as well?
yes
Originally Posted by DaveW View Post
Interface issues aside... i had the pleasure of running an RS Pro today. Since mine is in the mail for repair, a local was awesome enough to let me use one of his for practice today (1/10 TC outdoor asphalt).
I made two baseline runs with the LRP x12 17.5 (0 timing) and "Brand X" controller (timing 3) to find a suitable gear. After a consistent 6:30 run, i temped 202 degrees without fade on the x12, and 141 degrees on the speedo.
All i did was drop in the RS Pro with a baseline 'map' and repeated the above test with the same gear. The car was notably faster on the top end, and marginally smoother with a little more midband response... all to the tune of 163 degrees on the x12, and 117 degrees on the RS.
After some timing and boost adjustments, along with some delay change... the car was great in the infield, and ballistic (for a 17.5) on the straight! The x12 never temped over 180 degrees, so i have PLENTY of room to grow.
I cant wait till my RS comes back so i can get some wheel time with it! Kudos Tekin!
can you post the setup and size of the track as it gets asked allot for x12 setups
Originally Posted by RC4ODC View Post
was wondering if anyone had a decent starting point for a 10.5 motor.. straight is about 170 feet. and inside is flowing... all help is appreciated... thanks...
start with randys 13.5 large track setup geared closer to 8.0 to start as 99% of the time setups are the same with a diferent fdr
Originally Posted by A.Wojtecki View Post
I'm hoping if somebody can give me some tips for setting up the speedo and gearing as well. I run a 13.5 GM motor (1600 gauss version) in a fairly small indoor rubber, carpet track. If it helps with the same motor and a LRP Sphere speed control I was on a 5.4 FDR.
Thanks in advance
size of the track will work better
Jamie W
*Team Tekin*Tekno-rc*DE Racing*AKA*DDHRC*
20 SMOKE is offline   Reply With Quote
Old 05-28-2010, 06:22 AM   #14867
Hi,
The track are is 18 m x 12 m (the straight is usually the full 18 m length).
A.Wojtecki is offline   Reply With Quote
Old 05-28-2010, 10:30 AM   #14868
DaveW's Avatar
No problem, let me get exact track size info first. I know that plays a huge part in the settings.
DaveW is offline   Reply With Quote
Old 05-29-2010, 01:00 AM   #14869
team minkya trf's Avatar
Default tekin setup
im getting a tekin but i want to know what gear ratio i need to run im running a trf 416 with A 17.5 speed passion it wiil have firmware i also want to know a very good firm ware set up for a meduim grip track it is a indoor track wich is concrete the straight abought 10 to 15 meteres long i want some thing with the turbo to cut in at half throtle
thanks
speedpassion|trf416we|protoform|lrp|sanwa|m03|f109|hitec|xrayt2|tekin rs
team minkya trf is offline   Reply With Quote
Old 05-29-2010, 01:55 AM   #14870
TeamWTF's Avatar
Hey All,
I did the ol' "Hook up the battery in reverse" trick yesterday and fried my RS. I have sent Tekin an Email.. Im just wondering if anyone else has done this and had it repaired.... to get an estimated cost to see if its worth fixing or not.
Did not plug the battery in, i heard a noise when the connectors made contact (corally type) and instantly seperated... But now speedy does not work, smells, and when turned on just flashed the 4 outside LED's (two on each end)
Cheers
Phill
T.O.P. Racing Australia www.topracing.net.au
TeamWTF is offline   Reply With Quote
Old 05-29-2010, 04:24 AM   #14871
I did the same trick some time ago. To get it replaced, follow the service procedure at http://teamtekin.com/service.html. It will cost you US$79 plus postage. It's a lot cheaper than buying a new RS.
brrrrm is offline   Reply With Quote
Old 05-29-2010, 04:59 AM   #14872
TeamWTF's Avatar
Thanks brrrrm,
I just bought a hobby wing xerun to tide me over.. $79 isnt too bad. Ill get it done!
Very dissapointed... What a tool...
Old 05-29-2010, 05:04 AM   #14873
20 SMOKE's Avatar
thanks
with a straightaways less than 100ft you wont use turbo it will be all timing boost and motor timing
Jamie W
Old 05-29-2010, 11:11 AM   #14874
Super Moderator
Cpt.America's Avatar
Trader Rating: 52 (100%+)
i want to know what gear ratio i need to run with A 17.5 speed passion
If you are planning on running lots of dynamic timing with v203, start your FDR at 6.0.
Impossible. Turbo only kicks in once you reach 100% trigger pull...and there is a delay. Most people run a ~.5 delay.
A big thanks to my sponsors:
- Fantom Racing - www.fantomracing.com -
- Fusion Graphix- www.fusiongraphix.com -
- RCSpecialties -
Cpt.America is offline   Reply With Quote
Old 05-29-2010, 11:31 AM   #14875
Senna Racing's Avatar
thanks
were in sydney do you run
im normal at sma every tueday night and most sundays
Feral Batteries for all your on road needs
TRF 416, Fantom Batteries, Sorex, Tekin
Senna Racing is offline   Reply With Quote
Old 05-29-2010, 11:36 AM   #14876
shoud have read your post sounds like castel hill which should be a little bit longer from memory
Old 05-29-2010, 04:10 PM   #14877
yes i run at castlehill
Old 05-29-2010, 06:36 PM   #14878
DaveW's Avatar
Awesome day at the track with the RS. I asked, and was told our track size is 140'x60'. Its pretty flowing with a few technical sections and plenty of WOT time. Todays changes...
Air Temp: 85 degrees
Motor: x12 17.5
Motor timing: 1 dot
Motor temp after 6:30 run: 169 degrees
Brake: Drag 10, Strength 100%, Radio EPA 80% from 125%.
FDR: 4.821
Push: Off
Deadband: 7
Profile: 3
Timing: 24
Boost: 14
Delay: .4
Ramp: 1
End RPM: 15k
Start RPM: 5k
The car sounded like a missile on the front straight. NO fade, all pull. Simply awesome. Its the first time in years i was concerned about, and adjusted body aerodynamics on a stock class car (wing/front lip changes). It actually went fast enough to make a notable difference...
Old 05-29-2010, 06:42 PM   #14879
20 SMOKE's Avatar
dave what is the motor timing at one dot
Jamie W
Old 05-29-2010, 06:56 PM   #14880
DaveW's Avatar
Supposed to be 0 timing. I didnt try any of the positive motor settings, and i didnt like the timing set at either -5 or -10 on the motor. It felt too punchy, and harder to modulate. Maybe with throttle profile 2, but i am used to linear steering and throttle and use very little expo if any at all. Ill try it out soon though.
Tekin Redline RS Sensored ESC and motors, opinions for offroad? Cain Electric Off-Road 4230 06-07-2015 04:38 PM
Sensored vs. Sensorless lemansracer Electric On-Road 71 02-14-2009 03:19 AM
New Tekin Redline Sensored Motors are Roar Legal! Randy_Pike Electric On-Road 3 08-05-2008 02:08 AM
Tekin Redline Sensored 10.5 HUCKMAN Electric On-Road 6 07-15-2008 08:50 PM
sensored vs sensorless bprocket Rookie Zone 5 05-16-2008 09:38 AM
Tags
v203, vegas 2.0
