Old 12-01-2008, 06:37 PM   #1471
360rcspeedway's Avatar
Default Thanks
Just want to say thanks to Tekin for providing me awesome speedo's. I used an RS to win 1/12th stock, and to finish 4th in 1/12th 13.5.
Also, I used an RS-Pro in my World GT car. Missed TQ by .1 (bobble-driver) and had the fastest single lap of the event, just couldnt really get the clean run needed to win.
The speedo's performed flawlessly, that is now the 2nd major win in 17.5 for the RS (Vegas and Cleveland) against a larger field of other brands. I think it goes without saying that these speedo's get the job done in a class where H.P. is crucial.
Donny Lia
360rcspeedway is offline   Reply With Quote
Old 12-01-2008, 06:37 PM   #1472
I ran the speedo this weekend at Cleveland 1/12, switched from "Novak 4 Cell Spread Spektrum" version, and it was great. I was in Master's 1/12 Stock
If someone was beside me going down the straight, they were not when we entered the turn because of the "Max Timing". It was like having NOS on my car.
Steve Dunn
[email protected]
sdunnmcp is offline   Reply With Quote
Old 12-02-2008, 12:04 AM   #1473
Originally Posted by Randy_Pike View Post
We're looking at an aluminum lower housing to help reduce heat and get away from the fan permanently.
Might see an R1/RS Pro Worlds kit with the lower housing and 2nd cap...
Lower housing looks killer in Tekin Red...
When? Will sell an upgrade kit?
higbo is offline   Reply With Quote
Old 12-02-2008, 12:33 AM   #1474
Well its also only 5 cells we run with and its indoor... I will give it a try this sunday and hope it will work...
Foodie is offline   Reply With Quote
Old 12-02-2008, 05:04 AM   #1475
sg1
sg1's Avatar
Trader Rating: 79 (100%+)
Hey Guys,
If anyone is running 13.5 1/12 on a large track like the Indoorchamps a great starting point is 45 total degrees of timing, #3 profile. 55% drag break, and a 40-88 gear ratio with 1.70" tires. That set-up turned the fastest times in every run, unfortunately the drive didn't drive well every run..lol.. I eneded up qual. 4th and breaking in the main. If anyone needs more help with speedo or motor set up feel free to ask.
Thanks,
Wayne
**Team Scream**Parma/PSE**TQ Wire**Roche**Pemberton**BSR**Graupner/GM**SXT**
sg1 is offline   Reply With Quote
Old 12-02-2008, 05:05 AM   #1476
jono mad racer's Avatar
Send a message via MSN to jono mad racer
Hey, Just ordered myself the Team Tekin RS... So i am hoping its a good one! Any tips or tricks i need to know about... Im only running a 10.5 in it at the moment.
Volkswagen Australia
jono mad racer is offline   Reply With Quote
Old 12-02-2008, 08:02 AM   #1477
Grenade10's Avatar
Trader Rating: 37 (100%+)
Donny Lia
Very Nice Run's!!!
What motor did you power with the RS??
I've got the RS in my 1/12 and RS Pro's in WGT and Oval cars and am not looking back!!!!!
Darkside, Sweep, BSR, Fantom, IGT Hobbies and IGT8
Byrons Fuel, ProtoForm Bodies & Futaba Radio Gear by Choice
Founding Member of CORRC .... 5280raceway
www.darksidems.com www.igthobbies.com www.IGT8.com
Grenade10 is offline   Reply With Quote
Old 12-02-2008, 08:08 AM   #1478
mangoman's Avatar
Make sure get the hotwire or know someone who has one that can program the speedie for you.
Crank the timing up to 85 or 90 and i also put current limiting on it at 90. Damn thing just has too much rip and i cant control it at 100. Although it may be car setup, ive noticed other people have set the current limiting to 90 when paired with a 10.5
Hot Bodies Cyclone!!!
www.smaracing.org
www.rchobbies.com.au - www.feralbatteries.com.au
craig mcphee ( WHERE'S MY BEER )
mangoman is offline   Reply With Quote
Old 12-02-2008, 02:26 PM   #1479
Team Tekin
Randy_Pike's Avatar
Send a message via Yahoo to Randy_Pike
I also recomend the Hotwire. Any new software update will come this way.
No new "esc" of the month. Simple easy to install software updates that keep your Tekin up to speed at all times!
Most 10.5 setups use sensored only, motor timing around 24 degrees or so. Gear accordingly.
"Things may come to those who wait, but only the things left by those who hustle." Abraham Lincoln
Tekin,Protek,A-Main Hobbies,JConcepts,Avid RC,Yokomo,MIP,SikLidz,FactoryRC, www.randypikerc.com
Randy_Pike is offline   Reply With Quote
Old 12-02-2008, 02:32 PM   #1480
CCristo's Avatar
Trader Rating: 55 (100%+)
Randy,
Do you have an ETA for the new ESC firmware?
CCristo is offline   Reply With Quote
Old 12-02-2008, 07:11 PM   #1481
Trader Rating: 26 (100%+)
on the current limiter if you reduce it does the top end speed slow down. i usually run 1/12 in the 13.5 and 6.5 class in a fairly tight track, what kind of drag brake settings would be a good starting point
eddie10 is offline   Reply With Quote
Old 12-02-2008, 07:34 PM   #1482
I'm not sure about 6.5 but I run mine in 1/12th with 13.5. In Hybrid mode you'll find you have very little brakes and drag brakes even maxed out with a 13.5. Run it in Sensored Only mod and you will have all the brakes you need and more. I'm not sure how the brake are running a motor as low as a 6.5. My car isn't near me right now so I don't know where my drag brake is set.
Old 12-02-2008, 07:37 PM   #1483
Krio's Avatar
Trader Rating: 150 (99%+)
I was able to test the pre-production software with the new "boost". MAD rip with my 17.5 I need to gear down now because I'm still accelerating at the end of the straight.
www.kriostasis.com
Krio is online now   Reply With Quote
Old 12-02-2008, 08:42 PM   #1484
mangoman's Avatar
It effectively reduces the amount of punch the speedie will provide. It shouldnt reduce speed.
I forgot to check if my motor temp went down though (which i suspect it may slightly).
new "boost"????
BTW i have a mobile broadband usb device (HSDPA via 3g mobile phone sim) and the hotwire doesnt seem to work with updating via it. Effectively when windows picks up the device as a dial-up modem. Has anyone else had problems with this?
www.smaracing.org
Old 12-02-2008, 10:01 PM   #1485
Team Tekin
Randy_Pike's Avatar
Most of the team has the new boost software.
The public version will be out soon. When the team guys get the software it's beta software. Things can be done wrong if you're not careful.
When the public load is ready I WILL post it here!
Tekin Redline RS Sensored ESC and motors, opinions for offroad? Cain Electric Off-Road 4230 06-07-2015 04:38 PM
Sensored vs. Sensorless lemansracer Electric On-Road 71 02-14-2009 03:19 AM
New Tekin Redline Sensored Motors are Roar Legal! Randy_Pike Electric On-Road 3 08-05-2008 02:08 AM
Tekin Redline Sensored 10.5 HUCKMAN Electric On-Road 6 07-15-2008 08:50 PM
sensored vs sensorless bprocket Rookie Zone 5 05-16-2008 09:38 AM
Tags
v203, vegas 2.0
