Old 05-23-2010, 06:21 PM   #14791
20 SMOKE's Avatar
Trader Rating: 101 (100%+)
the sensor's are working ?,did you try less motor timing. the 200 version was more a 0 motor max timing boost and max turbo
Jamie W
*Team Tekin*Tekno-rc*DE Racing*AKA*DDHRC*
20 SMOKE is offline   Reply With Quote
Old 05-23-2010, 06:31 PM   #14792
Because of the class rules I can't run max turbo. What ever this problem is it's getting worse. Last week, my 1st time with the Tekin, it happened twice. I thought it was because I applied the throttle too fast after I turned the esc on.
I didn't notice the leds flashing when I manualy turned the motor. I'll try that tonight.-Thanks
outlandr91 is offline   Reply With Quote
Old 05-23-2010, 06:34 PM   #14793
theisgroup's Avatar
motor timing at 40 degrees is way to much and you are over timed. that is why you are seeing stuttering and the motor going in reverse
yang lai
Team Tamale | Team Tekin | RCAmerica | Speedmerchant | Speedzone RC | EA Motorsports | Ko Propo USA | eXpress Motorsports | Parma/PSE
theisgroup is offline   Reply With Quote
Old 05-23-2010, 06:44 PM   #14794
Thanks, but I don't understand why it was working "most" of the time last week.
Old 05-23-2010, 08:48 PM   #14795
Jaybuz20's Avatar
Default TEKIN RS PROBLEM
I have a problem with my Tekin rs today. My car was set up for 17.5, fdr was 5.6. I swapped out my motor for a 13.5 motor but kept the same gearing, motor temp was apprx 160-170. The speedo was around 140. But my problem, I blew my capacitor. Is this normal?or can I just put another and keep going also, what cause this? Or will it need to be sent back to tekin for service?
Any assistance is greatly appreciated.
MI-3.5 pro
MI-4 lp pro
Jaybuz20 is offline   Reply With Quote
Old 05-23-2010, 09:44 PM   #14796
mikel33's Avatar
Trader Rating: 2 (75%+)
Guy, if you want, give me a shout next time you're up at Eric's and we'll get her straightened out. We had good success with the Novak Ballistics during the VTA Nationals race. It does sound like overtiming, but we were running them cranked pretty far over during that race. The ballistic starts at what, 30 degrees of timing?
anyway, stop by and let's check it out.
michael.
Michael Larson.
Village Idiot Racing - Now accepting driver applications.
mikel33 is offline   Reply With Quote
Old 05-24-2010, 01:17 AM   #14797
Greetings all,
Finally had a chance to run the RS Pro with my newly aquired LRP X12 17.5. I could not figure this motor out. In the manual for the motor it says DO NOT run any ESC timing or boost and to gear the motor starting around 4:1. Some people at the track said to gear it at 6.5:1 and set the speedo to:
drag brake - off
rev strength - off
brake strength - 94
Neutral width - 10
motor type - BL-FW
Throttle profile - 4
voltage cutoff - 2
push control - off
timing boost - 40
turbo boost - 15
turbo delay - 0.2
turbo ramp - 3
start rpm - 3865
end rpm - 8000
Well this brought the motor temp to about 200F in about 6 minutes, I checked it every minute. about 5 minutes in, the motor began to fade.
Later in the day, someone told me this motor is a special case where current popular RS pro settings will not work, however, he didn't have any recommendation and I never had a chance to try any other settings.
I'm not sure exactly how to set the RS Pro for this motor for use on a big sweeping track ( for a pic of the track goto www.norcal-hobbies.com). Next time out I would like a good starting point for this motor from someone that has run it successfully.
Thanx for any help.
cheerz
Obsidian is offline   Reply With Quote
Old 05-24-2010, 01:56 AM   #14798
That is a REALLY short rev range, especially for low gearing. I'd say start a bit higher, and end a LOT higher to get the temps down
Agama A8 Evo | GRP .21 | Spektrum | Savox
My car just hit 88mph. I hope it comes back soon....
JR007 is offline   Reply With Quote
Old 05-24-2010, 05:22 AM   #14799
gonzo416's Avatar
Trader Rating: 39 (98%+)
Originally Posted by Obsidian View Post
Greetings all,
drag brake - off
rev strength - off
brake strength - 94
Neutral width - 10
motor type - BL-FW
voltage cutoff - 2
push control - off
timing boost - 40
turbo boost - 15
turbo delay - 0.2
turbo ramp - 3
start rpm - 3865
end rpm - 8000
I'm not sure exactly how to set the RS Pro for this motor for use on a big sweeping track ( for a pic of the track goto www.norcalhobbies.com). Next time out I would like a good starting point for this motor from someone that has run it successfully.
Thanx for any help.
cheerz
I had the same problem. I fixed it. I took it out and replaced it with a BOSS dynoed motor. Problem solved
gonzo416 is offline   Reply With Quote
Old 05-24-2010, 06:18 AM   #14800
g12314's Avatar
Send a message via AIM to g12314 Send a message via Yahoo to g12314
Greetings all,
Thanx for any help.
cheerz
I ran a new X12 17.5 outdoors and found the following settings (and the comments from the other racers were ITS FAST):
1. You need to install the X - 10 degree timing bushing (I think its 4 dots)
2. I was running with a heatsink/fan on the motor and was 150F after 8 minutes
3. Gearing for a 100-120ft straight should be around 6.5-6.8 FDR
4. ESC Settings:
drag brake - 15
rev strength - off
brake strength - 90
Neutral width - 10
motor type - BL-FW
Throttle profile - 3
voltage cutoff - 2
push control - off
timing boost - 42
turbo boost - 8
turbo delay - 0.4 (for me .4 kicked in about 1/2 down the straight)
turbo ramp - 2
start rpm - 5000
end rpm - 14500
Jimmy
"PREPARE TO QUALIFY"
g12314 is offline   Reply With Quote
Old 05-24-2010, 08:00 AM   #14801
Will the Tekin RS still work if the cap. is bad? If so what would the symptoms be? I cant rember my settings,but the car was working great on all sections of our track for two different race days then lost most of the throttle (low to mid) punch. Still had great straight speed but a real dog on the infield. We rechecked the settings and they were the same, but someone thought it might be a bad cap. or?? I know it is hard to answer with out the settings, but it worked great with its current settings for a few races,and still does except it has no in field punch like it did. Thanks for any info.
TheOtherBill is offline   Reply With Quote
Old 05-24-2010, 09:05 AM   #14802
Default Tekin & hw
Guys , Thanks for your help earlier. Unloaded and Reloaded the program several times and finally got it to take Now its time to play with set ups Any Suggestions for a SS 17.5 on Asphalt, medium grip in a T3?
Thanks in advance, Jr.
Touring Jr. is offline   Reply With Quote
Old 05-24-2010, 11:05 AM   #14803
Team Tekin
Randy_Pike's Avatar
Send a message via Yahoo to Randy_Pike
YOu should not have used the same gear. While the motor took it the cap didn't care for the "new" current spikes, which blew the cap.
Install a new one and change your gearing: TT3520
"Things may come to those who wait, but only the things left by those who hustle." Abraham Lincoln
Tekin,Protek,A-Main Hobbies,JConcepts,Avid RC,Yokomo,MIP,SikLidz,FactoryRC, www.randypikerc.com
Randy_Pike is offline   Reply With Quote
Old 05-24-2010, 11:06 AM   #14804
Team Tekin
Randy_Pike's Avatar
Don't run the speedo without a cap. If you can't find the right ones: TT3520 a good 16v 1000uf cap will work. They can be found at most Radio shacks.
Old 05-24-2010, 12:01 PM   #14805
Thanks very much Mike, I gotta get this thing working!
michael.
Tekin Redline RS Sensored ESC and motors, opinions for offroad? Cain Electric Off-Road 4230 06-07-2015 04:38 PM
Sensored vs. Sensorless lemansracer Electric On-Road 71 02-14-2009 03:19 AM
New Tekin Redline Sensored Motors are Roar Legal! Randy_Pike Electric On-Road 3 08-05-2008 02:08 AM
Tekin Redline Sensored 10.5 HUCKMAN Electric On-Road 6 07-15-2008 08:50 PM
sensored vs sensorless bprocket Rookie Zone 5 05-16-2008 09:38 AM
Tags
v203, vegas 2.0
