Old 05-16-2010, 10:07 PM   #14701
I want to make sure I'm on the same page as the rest of you.
When talking FDR I understood a higher FDR as a lower #. Such as 5.0 as opposed to 6.0. 6.0 being a lower FDR. Some seem to be calling it differrently. Are we not talking about gear ratios when talking FDR?
Regarding setup. To get more infield punch, what is the correct change to make. Settings or gearing or combination of both? I have a good Baseline setup from Ty to start with.
Thanks, Rob..........
*Restructuring* :)
Robio is offline   Reply With Quote
Old 05-16-2010, 10:25 PM   #14702
cosmo1974's Avatar
Location: Adelaide AUSTRALIA (5.754 mins SE of The Parks)
Historically, higher and lower refers to the pinion size.
Therefore,
-- higher gearing means a larger pinion.
-- lower gearing means a smaller pinion.
Now FDR is inversely related to pinion size.
Therefore, a higher gearing (larger pinion) means a smaller FDR.
To be more precise:
FDR = InternalDriveRatio * ExternalDriveRatio
InternalDriveRatio is fixed for a given car (eg: 2.167 for Cyclone TC).
ExternalDriveRatio = Spur / Pinion (* this is where is inverse relationship fits in *)
To complete the picture:
RollOut = (pi * d) / FDR = distance travelled for 1 rev of the motor.
d = tire diameter.
Cheers
"I'm either retired or unemployed, depending on when the money runs out !" > AERCCC_#25 > LargeOutdoorAsphaltTrack > CycloneTC + TekinRS_HWXerun_ESCs + Duo2_17.5 + SMC_Fantom_LiPos + BLS551 + MX3FG + TC1030 + MM >> =======TRACK_VIEW_FROM_SPACE========> http://www.nearmap.com/[email protected],138.560313&ll=-34.857766,138.560313&z=19&t=h&nmd=20100614
cosmo1974 is offline   Reply With Quote
Old 05-16-2010, 10:42 PM   #14703
Therefore,
To be more precise:
d = tire diameter.
Cheers
Excellent! Just wanted to make sure I was on the right track.
Also inadvertantly answered another question I had regarding "rollout".
Thanks much, Rob................
*Restructuring* :)
Old 05-17-2010, 05:06 AM   #14704
20 SMOKE's Avatar
Trader Rating: 101 (100%+)
Originally Posted by Randy_Pike View Post
Awesome! Get me a pic and some sort of confirmation and I'll put it up on the Tekin FB page. [email protected]
i believe it was a clean sweep for all classes but 3rd in 12th who ran tekins
Jamie W
*Team Tekin*Tekno-rc*DE Racing*AKA*DDHRC*
20 SMOKE is offline   Reply With Quote
Old 05-17-2010, 05:09 AM   #14705
scoyle's Avatar
I ran the Tekin at the weekend on the v203 software and based my settings on Randy's setting for medium tracks and it worked well. I did change a few things during the day to suit our track - the main change being the turbo ramp rate and turbo delay. Very pleased with my speed...
After the race when I was going through the settings I realised that I had not played with the throttle profile - I had it set at 3 as per Randy's settings. What would I have noticed it I upped the profile?
I was running 10.5.
scoyle is offline   Reply With Quote
Old 05-17-2010, 05:16 AM   #14706
Trader Rating: 15 (100%+)
I was running 10.5.
profile 3 is fine iv tried 4 with no great differance maybe a tad more engine temp
jay m is offline   Reply With Quote
Old 05-17-2010, 07:10 AM   #14707
M-Technic's Avatar
To get the punch I wanted out of my 17.5 it took a combo of ESC settings, motor timing, and gearing.
RCAmerica | Xray | Hudy | Radiopost | Speed Passion USA | Trinity | P3 Graphics
M-Technic is offline   Reply With Quote
Old 05-17-2010, 08:15 AM   #14708
FLATMAN's Avatar
[QUOTE=M-Technic;7415636]To get the punch I wanted out of my 17.5 it took a combo of ESC settings, motor timing, and gearing.[/QUO
so what is ur esc settings,motor timing and gearing?
FLATMAN is offline   Reply With Quote
Old 05-17-2010, 10:38 PM   #14709
Would you mind posting your settings and type of track you run on? It would be good to have more options to pull from.
Thanks, Rob...........
*Restructuring* :)
Old 05-17-2010, 11:27 PM   #14710
Senna Racing's Avatar
Default much more masters
Tekin takes out 1st,2nd,3rd,4th in 17.5 stock at this weeks Much More Masters held every year in May at SMA club in Sydney Australia
Here is a few links to the Club and Facebook Page
http://redirectingat.com/?id=42X1295...th-may-10.html
http://redirectingat.com/?id=42X1295...-org-1142.html
stock http://www.youtube.com/watch?v=KBI7oRYU3B8
superstock http://www.youtube.com/watch?v=IVoA-BgNCsE
Mod http://www.youtube.com/watch?v=SkCgO3dGiUY
12scale http://www.youtube.com/watch?v=dRgwYzwuBWE
Feral Batteries for all your on road needs
TRF 416, Fantom Batteries, Sorex, Tekin
Senna Racing is offline   Reply With Quote
Old 05-18-2010, 12:07 AM   #14711
FLATMAN's Avatar
[QUOTE=Senna Racing;7420038]Tekin takes out 1st,2nd,3rd,4th in 17.5 stock at this weeks Much More Masters held every year in May at SMA club in Sydney Australia
12scale http://www.youtube.com/watch?v=dRgwYzwuBWE[/QUOT
Old 05-18-2010, 12:07 AM   #14712
FLATMAN's Avatar
Well done!! i hope that they will post there esc setings for 17.5 soon?
Old 05-18-2010, 12:33 AM   #14713
dameetz's Avatar
Last weekend was the FEMCA ISTC race. I TQ and won the stock class 11.5T using TEKIN. I posted the fastest TQ of all class even beating the mod class. The track was indoor carpet technical design. My car was so smooth and using Tekin got me the advantage. Thank you Tekin for a very fine product.
Dudududududuuuuuu.....
dameetz is offline   Reply With Quote
Old 05-18-2010, 02:33 AM   #14714
Congratz to you dameetz,
mind to share your tekin setting at here.
AlexNg is offline   Reply With Quote
Old 05-18-2010, 07:06 AM   #14715
JCarr's Avatar
Default Turbo lag
Ok, I had my first chance to run the new software this past weekend. What i am experiencing is what i can best describe as turbo lag. I hit the power comming out of a corner and teh car is really slugglish then after about 3ft it starts to really take off.
Here are my settings:
Car: Tam 416
FDR: 6.12
Track: 120x72 fast but with a few tight corners
Drag: off
brake: 100
nw: 56
motor: bl-fw
tp: 3
cut off: 6.430
push: off
timing: 30
turbo: 10
delay: .2
start: 4989
end: 14997
ramp: 2
I tried changing the timing to 40 and boost to 15, it helped some but still had the lag. Temps after 6 minutes 140 and 135 after the change. What do the gurus think, am I getting too much timing too soon? Should I set the delay back a little? Thanks for any and all advice.
Gorilla Size Racing
R10 USGT, TRF416 USGT, DB10R, TA05R VTA, R40, RS4 3SS, RS4 super, Savage, Hellfire.
Youthful enthusiasm only rules until old age and common sense exert themselves
JCarr is offline   Reply With Quote
Tekin Redline RS Sensored ESC and motors, opinions for offroad? Cain Electric Off-Road 4230 06-07-2015 04:38 PM
Sensored vs. Sensorless lemansracer Electric On-Road 71 02-14-2009 03:19 AM
New Tekin Redline Sensored Motors are Roar Legal! Randy_Pike Electric On-Road 3 08-05-2008 02:08 AM
Tekin Redline Sensored 10.5 HUCKMAN Electric On-Road 6 07-15-2008 08:50 PM
sensored vs sensorless bprocket Rookie Zone 5 05-16-2008 09:38 AM
Tags
v203, vegas 2.0
