Old 05-13-2010, 08:13 AM   #14671
JLock's Avatar
Ok fellas, I need your help. I recently bought and installed a Tekin RS into my HPI Blitz. I am currently running a Novak 13.5 in it. My current gearing is 25/83. On my local track, after a 6 minute run, it comes off at about 125F degrees, give or take +/- 3 degrees. The track is approximately 70'x100' with moderate jumps and elevation changes. I run the Tekin in my 12th scale and 10th scale carpet touring cars but I know that running it in offroad conditions is a different animal. I don't want to ruin the motor or ESC, so, any helpful settings to use as a base will be greatly appreciated.
Juan
Texas 5
It's not what you know; it's what you can prove.
The only thing that is for sure is that nothing is for sure!!!
The needs of the many outweigh the needs of the few, or the one.
There are 2 things in life that are infinite: the universe and stupidity.
JLock is offline   Reply With Quote
Old 05-13-2010, 08:45 AM   #14672
Super Moderator
Cpt.America's Avatar
Trader Rating: 52 (100%+)
Juan
What's the problem? The only thing different I do between my touring cars and my offroad cars with my tekins are: offroad = wider RPM range for boost, no turbo. Gear appropriatly, check for heat. That's it.
A big thanks to my sponsors:
- Fantom Racing - www.fantomracing.com -
- Fusion Graphix- www.fusiongraphix.com -
- RCSpecialties -
Cpt.America is offline   Reply With Quote
Old 05-13-2010, 08:57 AM   #14673
Krio's Avatar
Trader Rating: 150 (99%+)
Juan
Is it a Ballistic or Velociti?
My Short Course esc setup:
10 on my tekin motor
Start rpm 5k
End rpm 20k
45 boost
Geared 23/75 with a 2.6 internal ratio
Let us know on what motor as you can run more boost with the Velociti or bump up the motor timing on the Ballistic.
www.kriostasis.com
Krio is offline   Reply With Quote
Old 05-13-2010, 09:01 AM   #14674
M-Technic's Avatar
Trader Rating: 15 (100%+)
Here are two Tekin threads specifically for offroad:
http://www.rctech.net/forum/electric...p-support.html
http://www.rctech.net/forum/electric...s-offroad.html
RCAmerica | Xray | Hudy | Radiopost | Speed Passion USA | Trinity | P3 Graphics
M-Technic is offline   Reply With Quote
Old 05-13-2010, 09:14 AM   #14675
JLock's Avatar
Ooops, I forgot to tell you guys a couple of things. First, that temp I was getting was when I was running my 13.5 with an old Novak SS ESC (pre-GTB/Havok). Second, the Novak 13.5 is not a Ballistic 13.5; I guess it can be considered a Velociti because it was the one sold with the sintered rotor.
Thanks Krio for posting a base in which I can program and start from. Is that 10 on the motor advancing the timing?
Texas 5
Old 05-13-2010, 09:37 AM   #14676
Krio's Avatar
Yes, it is 10 degrees of advanced timing as marked on the can of the tekin motors. Unfortunately the old novak motors aren't marked for timing and aren't very adjustable. I wouldn't worry about the motor timing to start and just set up the speed control with the settings.
www.kriostasis.com
Old 05-13-2010, 11:57 AM   #14677
JLock's Avatar
Thanks again. Now, I have a base setup in which to go from.
Texas 5
Old 05-14-2010, 09:48 AM   #14678
hijinx's Avatar
Trader Rating: 47 (100%+)
Default Problem with my Tekin RS
Hi there all, I have got a problem with my tekin rs, when I turn it on no lights or chime noise happens, while trying to work out what is going on, the speedy decided to start up, I had the use of the throttle and all was looking good, but 10seconds later it shut down and now it will not start at all or any lights coming on, I have checked and resoldered all the wires but with still no luck.
If anyone has any ideas on what could be going on please PM me or leave a post.
Cheers
Sponsored by Yokomo Australia Team Hearns Hobbies, AKA Tires from Ryper Hobbies.Fantom batteries and motors. Hobbywing,Pro Amps servos,Wild Turbo Fans,TWT. Yokomo BMax2 Hobbywing Fantom Ion4 8.5t. Yokomo BMax4 III Hobbywing Fantom Ion4 6.5t. Yokomo BD7 2016 Hobbywing Fantom FR-1 4.5. S2H BODIES for all your custom RC paint jobs.
hijinx is offline   Reply With Quote
Old 05-14-2010, 12:34 PM   #14679
macdude's Avatar
Cheers
What is it in? I have seen this in a 1 cell vehicle when the receiver pack is dead. The controller acts really weird. I can' t remember off the top of my head, but there was a certain order to how everything needed to be turned on to work.
KO Eurus / Orca / MMP / XB2 / 22-4 /
macdude is offline   Reply With Quote
Old 05-14-2010, 02:52 PM   #14680
20 SMOKE's Avatar
Trader Rating: 101 (100%+)
rx first,but mine works either way esc or rx first
Jamie W
*Team Tekin*Tekno-rc*DE Racing*AKA*DDHRC*
20 SMOKE is offline   Reply With Quote
Old 05-14-2010, 03:41 PM   #14681
hijinx's Avatar
Hi there, I'm putting it in my B44, the receiver is a spektrum sr300 with a 2cell LiPo, just tried a receiver that is in my TC5 with a tekin RS that works and it still won't power up
Any other ideas on what could be the problem as the RS is fresh and new straight from Tekin???????
Cheers
Old 05-14-2010, 06:51 PM   #14682
20 SMOKE's Avatar
check the wires red/wh/blk maybe try a new one
Jamie W
Old 05-14-2010, 07:02 PM   #14683
hijinx's Avatar
Check the wires from the esc that go to the receiver? I have unpluged my other RS that works and it turns on not connected to anything eg reciver, sensor wire and motor wires
Old 05-14-2010, 07:27 PM   #14684
20 SMOKE's Avatar
take the case apart and make sure the on/off wires are connected if so it may need to go back
Jamie W
Old 05-14-2010, 09:30 PM   #14685
hijinx's Avatar
On off wires are both connected, bugger looks like it will have to go back again
Tekin Redline RS Sensored ESC and motors, opinions for offroad? Cain Electric Off-Road 4230 06-07-2015 04:38 PM
Sensored vs. Sensorless lemansracer Electric On-Road 71 02-14-2009 03:19 AM
New Tekin Redline Sensored Motors are Roar Legal! Randy_Pike Electric On-Road 3 08-05-2008 02:08 AM
Tekin Redline Sensored 10.5 HUCKMAN Electric On-Road 6 07-15-2008 08:50 PM
sensored vs sensorless bprocket Rookie Zone 5 05-16-2008 09:38 AM
Tags
v203, vegas 2.0
