Old 05-11-2010, 07:56 AM   #14611
20 SMOKE's Avatar
Trader Rating: 101 (100%+)
yes current limiter works in sensored mode,timing advance doesn't but set it to 100 that way there you have 30* of timing if you loose your sensor wire
current limiter is punch control,in dual mode timing advance is used only the motor timing is not
Jamie W
*Team Tekin*Tekno-rc*DE Racing*AKA*DDHRC*
20 SMOKE is offline   Reply With Quote
Old 05-11-2010, 08:03 AM   #14612
Krio's Avatar
Trader Rating: 150 (99%+)
Originally Posted by DrBen View Post
Whilst I understand that boost and turbo is not available in "dual" mode, Im a bit surprised that the values "current control" and "timing advance" are not available in "sensored".
The settings "timing advance" and "current limit" are still applied and active in the esc. Rather than making the hotwire box too wide by lining up all the sliders they chose to have you switch between dual and sensored in order to see them.
What happens when I switch to "dual", change the setting for "current" or "timing" and switch back to "sensored".
Will the changes have an effect?
I want a current limit in "sensored".
Yes, current limit AND dual mode timing are stored and in effect. If you lose your sensor harness the dualmode timing you selected comes into play to finish the race. This is why you should always set your timing advance even if you don't plan to use it. For stock racing put it all the way up at 100.
And about the value ranges itself: I dont understand why "current control" and "timing advance" have such a limited range:
- Why is timing only positive? I would rather like to retard my (factory 30*) motor with the ESC than by touching the can.
Timing advance is not based off the sensors, but rather true zero. If you put any less timing the motor would spin backwards. 80 to 100 on the timing advance is close to the stock sensored timing in most motors.
- Why is current limit only up to 100? I guess the value represent Ampere. How dont have to look long to find a pack that can deliver 200A or more.
Current limit is an arbitrary scale. 100 equals no current is limited (100% power available) and zero means your grandma could drive the car.
Answers in red
www.kriostasis.com
Krio is offline   Reply With Quote
Old 05-11-2010, 08:27 AM   #14613
mr fit's Avatar
Originally Posted by theisgroup View Post
first thing I would try is a vr adjust on the helios. also on the helios you will need to run the throttle reverse. the next thing I would try if those 2 don't work is to do a reset on your helios for that profile. then set the throttle to reverse and try to calibrate with the rs
i did all of the above. what i had to do was click- "update esc" -on the hotwire. the esc resetted itself and i was able to reprogram it. thanks for your help.
marc davila aka... marc ups.... drive it like you stole it.
mr fit is offline   Reply With Quote
Old 05-11-2010, 08:39 AM   #14614
thanks for the quick replies, guys.
Im clear about the timing advance now.
But for the current limit: Beside of protecting the battery, I guess I might be able to use this value to reduce heat and punch?
What would be a good value to start with for a 13.5?
What is a typical peak amp rate that the RS can push through a 13.5 motor, and how would that value translate in the ESCs current limiter scale? I would like to start experimenting at about 80% of the maximum draw rate to check what effect that has on heat and punch.
DrBen is offline   Reply With Quote
Old 05-11-2010, 09:02 AM   #14615
syndr0me's Avatar
Trader Rating: 32 (100%+)
Only a few weeks left until tuning ESC's goes the way of the dinosaur. I'm not sure if we should have a party or a funeral.
syndr0me is offline   Reply With Quote
Old 05-11-2010, 09:03 AM   #14616
Team EAM
EAMotorsports's Avatar
Trader Rating: 79 (100%+)
Send a message via AIM to EAMotorsports
Huh?
EA
Contact Us
Team EAM, Our Facebook
Team EAM | Xray | RCAmerica | Hudy | APEX Raceway and Hobbies | RC Mission | Killer Concepts | AVID | Hobbywing.
EAMotorsports is offline   Reply With Quote
Old 05-11-2010, 09:13 AM   #14617
syndr0me's Avatar
Originally Posted by EAMotorsports View Post
Huh?
EA
ROAR is moving to approved ESC's (and profiles) for stock classes. ETS this week is using handout Citrix ESC's and motors. Scotty has basically said all stock classes at IIC will be no timing in the ESC's. What's left? It's just a matter of time now before the TC Spec's come back out.
Old 05-11-2010, 09:18 AM   #14618
Team EAM
Ah Gottcha. I'll agree with them all and say for 17.5 or Amature classes it should be done. Things are getting way to fast for most guys. 13.5 and up should be left open though.
Remember when BL came out it was one less thing to have to worry about. Not as it is now though! LOL
EA
Contact Us
Old 05-11-2010, 09:24 AM   #14619
syndr0me's Avatar
It's enough to make me want to go back and edit all but about 5 of the total posts I've made on this site.
Who knows what's going to happen with 13.5. It seems like ROAR is trying to kill it. I'm eager to see what Scotty does for IIC, but his post said "all" stock classes. I guess we'll know soon.
Old 05-11-2010, 09:25 AM   #14620
Krio's Avatar
Roar is moving to approved esc's and profiles for sportsman classes. It's up to tracks and their respective races if they want to use the sportsman specs for their classes. 17.5 "stock" is still open timing (for now).
www.kriostasis.com
Old 05-11-2010, 10:10 AM   #14621
Team Tekin
Randy_Pike's Avatar
Send a message via Yahoo to Randy_Pike
ROAR is trying to make a positive change for the "average" racer that is trying to get into National or other large events to compete. The Spec software rule wont' change anything for the Tekin user. With 208 simply select TP 1 and you're done, period.
I also DO NOT expect this to affect any of our team drivers as NONE of them should be running in the Sportsman class anyways!
13.5 is still going to be around. I do suspect to see something along the lines of weight vs. motor wind chosen. The UK is doing something like this with a simple voltage maximum, and wind maximum. Clearly we've proven that at times a slower motor will provide you with an overall faster run.
"Things may come to those who wait, but only the things left by those who hustle." Abraham Lincoln
Tekin,Protek,A-Main Hobbies,JConcepts,Avid RC,Yokomo,MIP,SikLidz,FactoryRC, www.randypikerc.com
Randy_Pike is offline   Reply With Quote
Old 05-11-2010, 10:16 AM   #14622
Once we get back to simply stock and mod then it will be fun to race again!
Schuurspeed / Aero-model / Gear One / LG1
www.OHRCR.com
Gitsum is offline   Reply With Quote
Old 05-11-2010, 10:23 AM   #14623
bfong13's Avatar
Trader Rating: 17 (100%+)
+1 Things were so much better way back when the classes were novice, stock, and modified, and the only thing different between novice and stock was skill level.
bfong13 is offline   Reply With Quote
Old 05-11-2010, 10:42 AM   #14624
Hey guys
A question away from the usual poop about brakes and motors cooking
I want to use a mod motor on my RS , it is a 6 turns i have added another Cap to the speedo to help cool it and a fan blowing across the posts.
But my question is what do i do for settings ?? i have never run Mod but want to see if i can handle the power as i am fed up with the way stock class is going .....
Thanks i advance Phil
sidecarphil1 is offline   Reply With Quote
Old 05-11-2010, 10:57 AM   #14625
20 SMOKE's Avatar
we were talking about this a few pages back start with dual mode timing advance around 70 and gear accordingly you can add more timing if you need more rip,in sensored mode timing boost 20-30 motor 0-10 turbo 0 to start 5k start 25k end start slow in sensored mode and add slowly,i would start with dual until you get a feel for a 6.5
Jamie W
Tekin Redline RS Sensored ESC and motors, opinions for offroad? Cain Electric Off-Road 4230 06-07-2015 04:38 PM
Sensored vs. Sensorless lemansracer Electric On-Road 71 02-14-2009 03:19 AM
New Tekin Redline Sensored Motors are Roar Legal! Randy_Pike Electric On-Road 3 08-05-2008 02:08 AM
Tekin Redline Sensored 10.5 HUCKMAN Electric On-Road 6 07-15-2008 08:50 PM
sensored vs sensorless bprocket Rookie Zone 5 05-16-2008 09:38 AM
Tags
v203, vegas 2.0
