Old 11-20-2008, 12:27 AM   #1441
bsmooth's Avatar
Trader Rating: 17 (100%+)
Default Cannot Calibrate
Hello Randy,
I hope you (or anyone else for that matter) can help me. I just got my 12th scale car all wired up with the RS and 17.5 combo, and am having trouble calibrating the esc. When I power up, all I get are all 7 led's lit up solid. Using the mode button (for 3 seconds) does nothing. I've tried to reset the whole system back to factory specs just for kicks, but I don't think its responding. I'm getting no audible chime either. I'm running a KO Helios w/ Spektrum. Also have the Hotwire interface as well.
Please help as i'm planning a trip to the new facility in Chico this Saturday.
Regards,
Steve
bsmooth is offline   Reply With Quote
Old 11-20-2008, 03:44 AM   #1442
Shop Owner
nnick's Avatar
R/C Tech Charter Subscriber
Send a message via ICQ to nnick Send a message via MSN to nnick Send a message via Yahoo to nnick Send a message via Skype™ to nnick
Any recommendations for setting my new RS Pro would be greatly appreciated
car, Xray T2008 (or T2009 if it gets in time )
track size, HUGE
straight length, 80-90meters
current gearing 6.92-7.17
Motor I will use Tekin 3.5
Previous configuration was LRP TC, SP3.5
Nikolakopoulos Nick
RC RING
The #1 source for all your electric needs www.rcring.eu
Enjoy RCing....
R/C Tech #82
IRT #123
Don't practice until you get it right. Practice until you can't get it wrong
Team Xray T4'17, Team Xray X10'18, TOP Racing Rebel
nnick is offline   Reply With Quote
Old 11-20-2008, 09:45 AM   #1443
Regional Moderator
CarbonJoe's Avatar
Originally Posted by bsmooth View Post
Hello Randy,
Regards,
Steve
Did you upgrade to v1.80 firmware? If so, try downgrading to v1.78, then upgrade back to v1.80. Worked for a few of us...
*** The Gate - Celebrating 8 years at the same location ***
The difference between genius and stupidity is that genius has its limits. - Albert Einstein
Understeer is when you hit the wall with the front of the car and oversteer is when you hit the wall with the rear of the car
CarbonJoe is offline   Reply With Quote
Old 11-20-2008, 11:44 AM   #1444
Team Tekin
Randy_Pike's Avatar
Send a message via Yahoo to Randy_Pike
IF all the led's are flashing that means we see know radio signal.
Make sure that your receiver is working. Do you have steering? Make sure the esc is plugged in the right way.
Nick: Make sure to run a double cap setup on a huge track such as that one. I'm sure you're on throttle and hard on brakes there...
Two caps help keep esc temps down.
"Things may come to those who wait, but only the things left by those who hustle." Abraham Lincoln
Tekin,Protek,A-Main Hobbies,JConcepts,Avid RC,Yokomo,MIP,SikLidz,FactoryRC, www.randypikerc.com
Randy_Pike is offline   Reply With Quote
Old 11-20-2008, 01:59 PM   #1445
bsmooth's Avatar
I'll try that.
Old 11-20-2008, 02:02 PM   #1446
bsmooth's Avatar
Randy,
I do have steering, so I assume it's plugged in correctly. All 7 lights are solid, not flashing.
Old 11-20-2008, 03:36 PM   #1447
TRF415boy's Avatar
Are you on a tutaba system by any chance?
TRF415boy is offline   Reply With Quote
Old 11-20-2008, 03:44 PM   #1448
Team Tekin
Randy_Pike's Avatar
No he's running a Helios KO. I've got a shop with the car and I'm working to sort it out over the phone.
We'll get it handled.
Old 11-20-2008, 05:48 PM   #1449
bsmooth's Avatar
Thanks Randy,
It would mean a lot.
-Steve
Old 11-21-2008, 01:55 PM   #1450
Hi,
Where can i get the recommended FDR for all of the Tekin Redline sensored motors?
Thanks Ya`All
MoonTrap is offline   Reply With Quote
Old 11-21-2008, 02:40 PM   #1451
mo
mo's Avatar
Thanks Randy,
-Steve
You're all set. I wen by SWR and reflashed the speedo and set it to the radio and all appears to be working now.
TLR, Spektrum, Tekin, SMC, MO-GRIP, www.factory-rc.com https://www.shapeways.com/shops/MPP
mo is offline   Reply With Quote
Old 11-21-2008, 03:23 PM   #1452
Hello Randy,
Regards,
Steve
did you get this problem solved, i had the exact same problem and i found that the sensor wire was bad right out of the box.There was no continuity at one of the terminals, replaced the wire and it worked great
Chad M is offline   Reply With Quote
Old 11-21-2008, 11:41 PM   #1453
bsmooth's Avatar
Thank's Mo!
I owe you and Billy one.
Regards,
Steve
Old 11-22-2008, 12:24 AM   #1454
Team Tekin
Randy_Pike's Avatar
Yes Mo, thank you. I had planned to make it there tomorrow and do it myself.
Old 11-24-2008, 12:32 AM   #1455
Team Tekin
Randy_Pike's Avatar
Testing appears to be going good over the weekend for the new software. Should see a public version very soon.
Tekin Redline RS Sensored ESC and motors, opinions for offroad? Cain Electric Off-Road 4230 06-07-2015 04:38 PM
Sensored vs. Sensorless lemansracer Electric On-Road 71 02-14-2009 03:19 AM
New Tekin Redline Sensored Motors are Roar Legal! Randy_Pike Electric On-Road 3 08-05-2008 02:08 AM
Tekin Redline Sensored 10.5 HUCKMAN Electric On-Road 6 07-15-2008 08:50 PM
sensored vs sensorless bprocket Rookie Zone 5 05-16-2008 09:38 AM
Tags
v203, vegas 2.0
