Old 05-06-2010, 09:51 PM   #14506
20 SMOKE's Avatar
Trader Rating: 101 (100%+)
Originally Posted by -WHEELMAN- View Post
Got the hot wire running now how to change firmware endcode from .txt to .zip?
go to win zip if you dont have it or google free zip programs
+ YouTube Video
Jamie W
*Team Tekin*Tekno-rc*DE Racing*AKA*DDHRC*
20 SMOKE is offline   Reply With Quote
Old 05-06-2010, 10:21 PM   #14507
-WHEELMAN-'s Avatar
Trader Rating: 266 (98%+)
You the man just got it figured out. It looks as if in dual mode you cant run the turbo. It seems that is the way I want it just curious. Im taking your advice on the dual mode setting ill let you know how it turns out taking the computer and hot wire to the track saturday. Where do I find that guys settings you said I should check out.
BRETT T. RICHARDS = SUPPORT YOUR TROOPS, LOCAL TRACKS AND HOBBY SHOPS OR THEY COULD ALL BE GONE ONE DAY!
-WHEELMAN- is offline   Reply With Quote
Old 05-07-2010, 01:59 AM   #14508
tc3team's Avatar
Originally Posted by Tomah View Post
Nope, motor is at its stock position. Havent touched the endbell timing.
Is the stock endbell position 0 degrees?
I only ask as I made that same mistake when I first got the tekin Redline motor - "stock" endbell position on the Redline is 12 degrees, so when I went to put ESC timing on the motor, it was overtimed and stuttered on spool up.
As a general rule, total endbell and esc timing should be a max of about 45-50, well, that seems to work for me. Any more and it doesnt like it, but all motors are different
v203 appears to make the motor work at a cooler temperature too, which might help you out too
Fusion Hobbies / www.horshamrc.org
The wife stops me being sane and the r/c stops me from going insane....
tc3team is offline   Reply With Quote
Old 05-07-2010, 03:08 AM   #14509
Quick question , i have just bought replacement capacitors for my RS and want to know , will it hurt to add 2 instead of 1 and can i add some wire to tgem so i can place them in a differant position ??
cheeRS Phil
sidecarphil1 is offline   Reply With Quote
Old 05-07-2010, 03:15 AM   #14510
PizzaDude's Avatar
cheeRS Phil
The closer to the esc is best (way best!).
PizzaDude is offline   Reply With Quote
Old 05-07-2010, 03:19 AM   #14511
pakk's Avatar
Trader Rating: 79 (100%+)
cheeRS Phil
You can add two. It is even recommended if you are having heat issues. If you are not, it is unnecessary. And as already stated, the closer, the better.
*Photon* *SC10 4x4*
RCRD
pakk is offline   Reply With Quote
Old 05-07-2010, 03:40 AM   #14512
not having heat problems with the speedo
i am with the motors LOL
but that is the way of the stock class
push it till it blows then back it off a little
Old 05-07-2010, 04:46 AM   #14513
Potoczak's Avatar
Trader Rating: 112 (100%+)
How do you know where the timing is on a redline motor? Or where the timing is when it comes from the factory?
Pete Potoczak
Home entertainment specialist
Secure Technologies/ www.stiworldwide.com
Potoczak is offline   Reply With Quote
Old 05-07-2010, 05:20 AM   #14514
20 SMOKE's Avatar
all the way clockwise is 0 counter clockwise is 24 factory is 12 in the middle
Jamie W
Old 05-07-2010, 12:30 PM   #14515
Kenny L's Avatar
Trader Rating: 16 (100%+)
Was bored today so I figure I see you guys talking about heat. So it got me thinking. Here what I got removed case made a a lot of small holes in it. Next took muchmore fan and small piece of servo tape place it in middle making sure when I drilled hole they would be were fan would be blowing. Next took two small screw and screwed they into back two hole. Before you ask you can push gently on the front of fan and use the buttons still
Team Tekin, Ko Propo America
Kenny L is offline   Reply With Quote
Old 05-07-2010, 12:32 PM   #14516
pakk's Avatar
can you see the leds? have you tested?
*Photon* *SC10 4x4*
RCRD
Old 05-07-2010, 12:34 PM   #14517
Kenny L's Avatar
I bench tested seem ready for some 8.5 testing out doors on 210ft long straight track
Old 05-07-2010, 12:39 PM   #14518
Kenny L's Avatar
Right now I'm testing temp of bottom of case after 5 min of sitting in can on
Old 05-07-2010, 12:43 PM   #14519
2wdrive's Avatar
your blowing into a case but can the air pass through the case? Otherwise the heat will still be trapped inside as the air can not pass through. The air gets blown against itself so to speak as it can't go anywhere. The solder posts are the heatsinks so it should at least blow against that.
2wdrive is offline   Reply With Quote
Old 05-07-2010, 12:47 PM   #14520
Kenny L's Avatar
Yes air flows out bottom of post slot after almost 5 min bottom of case temped 6* cooler than started mounted in car
Tekin Redline RS Sensored ESC and motors, opinions for offroad? Cain Electric Off-Road 4230 06-07-2015 04:38 PM
Sensored vs. Sensorless lemansracer Electric On-Road 71 02-14-2009 03:19 AM
New Tekin Redline Sensored Motors are Roar Legal! Randy_Pike Electric On-Road 3 08-05-2008 02:08 AM
Tekin Redline Sensored 10.5 HUCKMAN Electric On-Road 6 07-15-2008 08:50 PM
sensored vs sensorless bprocket Rookie Zone 5 05-16-2008 09:38 AM
Tags
v203, vegas 2.0
