Old 05-03-2010, 08:02 PM   #14356
20 SMOKE's Avatar
Trader Rating: 101 (100%+)
how much motor timing
Jamie W
*Team Tekin*Tekno-rc*DE Racing*AKA*DDHRC*
20 SMOKE is offline   Reply With Quote
Old 05-03-2010, 08:04 PM   #14357
pakk's Avatar
Trader Rating: 79 (100%+)
Originally Posted by pakk View Post
17.5 Ballistic Motor timing set to second lowest mark
It's on the 2nd to lowest mark on the negative side. So if I understand novak motors right, the middle hole is 30. Each mark is worth 5degrees. So 20?
*Photon* *SC10 4x4*
RCRD
pakk is offline   Reply With Quote
Old 05-03-2010, 08:09 PM   #14358
VenturaDC's Avatar
Trader Rating: 32 (100%+)
dont know the full setup but one of the fastest cars at our track is a 17.5 ballistic and he is geared at a 5.0 fdr while most of us are geared 6.0-7.0 with other motors. Decent sized outdoor track.
Dustin Colt45 Aguirre
Kyosho RB6--Futaba--HW--Shuurspeed 17.5
Kyosho SCR--Hitec--Lrp--Yeah 13.5
Durango Dex210--Futaba--Trakpower--Tacon 8.5
VenturaDC is offline   Reply With Quote
Old 05-03-2010, 08:23 PM   #14359
20 SMOKE's Avatar
i would move the start up to around 4-5k with the 0delay and 1k start it may be bogging down
Jamie W
Old 05-03-2010, 08:30 PM   #14360
Hello
Is any one running the LRP x12 10.5 and if so what are your setting to keep it cool.
Mine was coming of at 199F and not as fast as the tekin.
Is it better in sensorless mode.
Steven
Casino Kid is offline   Reply With Quote
Old 05-03-2010, 08:46 PM   #14361
pakk's Avatar
That is the one thing I have not tried. I'll give that a shot.
*Photon* *SC10 4x4*
RCRD
Old 05-03-2010, 09:01 PM   #14362
L.Fairtrace's Avatar
Trader Rating: 23 (100%+)
Send a message via AIM to L.Fairtrace
I would suggest in TC never starting any motor below 3-4k start.
It seems the wider I make the range the more power the motor makes. Up to a point obviously but it also smooths out the power band also.
Awesomatix USA - EaMotorsports - RocheUSA - MonTech - Sanwa - BSR Racing Tires - TQ Wire - Solaris Racing Tires - Side Piece Racing
180 and 360 Raceway. Best on the East Coast. Take your pick
L.Fairtrace is offline   Reply With Quote
Old 05-03-2010, 10:36 PM   #14363
mok
mok's Avatar
Send a message via MSN to mok Send a message via Skype™ to mok
Originally Posted by Casino Kid View Post
Hello
Steven
Motor timing - 35
Turbo boost - 15
Timing insert - 3 dot (-5 degree)
Start rpm - 13500
End rpm - 24000
Turbo delay - 0.2
Turbo ramp - 2
Brake strength - 85 (had to balance motor temps with brakes)
Push control - 10
Drag brake - 0
Fdr - 6.995
Track - 240m length, approx 55m straight, asphalt (rubber tyre)
Motor cooling - none
Temps - 95C to 99C
Fastest lap time - 0.082s off the lap record
Chassis - Xray T3
IMHO, to go faster on that track without more heat i would need a cooling fan/heatsink solution...
With cooling I would be able to push up the turbo a couple more notches for super boosto! on the straight
-Mark
XRAY T3'2011 / TEKIN RS PRO / LRP X12 / HYPERION SWIFT G3 RACE PACKS / FUTABA S9551 / SPEKTRUM DX3R
www.epracer.com - www.precc.org.au - www.westcoastmodelrallyclub.asn.au - www.onroadrccarclubbunbury.org.au
mok is offline   Reply With Quote
Old 05-03-2010, 11:01 PM   #14364
-WHEELMAN-'s Avatar
Trader Rating: 266 (98%+)
Loving my RS thanks Tekin again!! Still have confidence youll get the RX8 figured out. Im a loyal Tekin customer!! Had a great time running the pro in my B44 last night! Turbo was fun on the long straight!!
BRETT T. RICHARDS = SUPPORT YOUR TROOPS, LOCAL TRACKS AND HOBBY SHOPS OR THEY COULD ALL BE GONE ONE DAY!
-WHEELMAN- is offline   Reply With Quote
Old 05-04-2010, 03:17 AM   #14365
Originally Posted by mok View Post
Motor timing - 35
Turbo boost - 15
Start rpm - 13500
End rpm - 24000
Turbo delay - 0.2
Turbo ramp - 2
Push control - 10
Drag brake - 0
Fdr - 6.995
Temps - 95C to 99C
Chassis - Xray T3
-Mark
Thanks Mok
these motors run hot, is that the norm.
Steven
Old 05-04-2010, 03:44 AM   #14366
warnos's Avatar
Spektrum Cap doesn't help?? omg.. just spent the day finding one.. oh well I will give it a go anyway.. Is there a way to test the Capacitor on the Tekin to see if its working correctly??
I have tried to roll back the firmware and reinstall 203.. but doesn't fix the problem.
The only thing thats left for me to do is maybe solder the wires directly to the RX motherboard. Maybe if that works I can splice in a plug for hotwire.
Or just to test run a battery for the receiver instead of the Spektrum Capacitor and disconnect the red wire from the Tekin. If this fixes it then its a brown out problem not enough power loosing bind..and a bigger cap may fix it.. instead of 420uF maybe 10V 1000uf. Doesn't leave you feeling safe and connected to the car though.
It seems people are only having issues with the Spektrums.. maybe I should change modules.
Cheers
Originally Posted by Skiddins View Post
I have had exactly the same issues, which reoccurred today.
Had few times when the throttle just stopped and a few runaways, the next round it was fine.
Fine for a few runs, then one horrific round then fine again.
Have tried a Spektrum cap but it made no difference, also tried resetting the ESC. Only thing I haven't tried is going back to earlier firmware the updating again.
Could a loose signal wire cause something like the above?
Its the SR3500 receiver with a Spektrum module in a Futaba 3VC with KO PDS-2413 servo.
Skiddins
TCX Smokem / F104 wgp
Major Sponsor : Visa Card
TEAM SMA - www.smaracing.org
warnos is offline   Reply With Quote
Old 05-04-2010, 03:55 AM   #14367
cannon's Avatar
Trader Rating: 35 (100%+)
Cheers
As a person selling Tekins I constantly see issues with Spektrum equipment, especiall Spektrum modules used in other brand radios.
I have had customers have issues with the Spektrum modules only to revert to the original FM modules and then have no issues whatsoever
www.feralbatteries.com ........... new website
cannon is offline   Reply With Quote
Old 05-04-2010, 04:33 AM   #14368
blade072's Avatar
Trader Rating: 98 (100%+)
my mate had spektrum issues but he borrowed a sm3500 micro and it was all good...i might give him a cap for it still....
David Randall
AWESOMATIX A800X ★ MUCHMORE ★ R1 WURKS ★
ROCHE RAPIDE F1-16 ★ SANWA M12 ★ SILVERBACK ★
HOBBYWING ★ RCMAKER ★ VOLANTE RC ★
blade072 is offline   Reply With Quote
Old 05-04-2010, 08:03 AM   #14369
M-Technic's Avatar
Trader Rating: 15 (100%+)
Here's my current setup.
Full turbo
Full Boost
0 delay
Ramp 3
1000 start
18000 end
6.7 FDR
I got plenty of mid and top end power, but not enough on the low side. I'd like to get a lot more rip out of the corners. I messed with my settings a lot, and always end up very close to this depending on the track I am at. I'm starting to believe my motor just doesn't have the low end grunt I am looking for. My temps very from 120-160 depending on the day and track lay out. It varies so much because we race at night here.
Any suggestions?
Lower boost to 10
Increase delay to .1 or .2
Move start to 3,000 or 5,000 - try both
Moving the timing on the motor back to the central tick
Then experiment with gearing after that.
RCAmerica | Xray | Hudy | Radiopost | Speed Passion USA | Trinity | P3 Graphics
M-Technic is offline   Reply With Quote
Old 05-04-2010, 09:12 AM   #14370
Team Tekin
Randy_Pike's Avatar
Send a message via Yahoo to Randy_Pike
If you're having DSM issues try a different servo. A failing servo can draw enough current on it's own to brown out some of the Spektrum receivers.
"Things may come to those who wait, but only the things left by those who hustle." Abraham Lincoln
Tekin,Protek,A-Main Hobbies,JConcepts,Avid RC,Yokomo,MIP,SikLidz,FactoryRC, www.randypikerc.com
Randy_Pike is offline   Reply With Quote
Tekin Redline RS Sensored ESC and motors, opinions for offroad? Cain Electric Off-Road 4230 06-07-2015 04:38 PM
Sensored vs. Sensorless lemansracer Electric On-Road 71 02-14-2009 03:19 AM
New Tekin Redline Sensored Motors are Roar Legal! Randy_Pike Electric On-Road 3 08-05-2008 02:08 AM
Tekin Redline Sensored 10.5 HUCKMAN Electric On-Road 6 07-15-2008 08:50 PM
sensored vs sensorless bprocket Rookie Zone 5 05-16-2008 09:38 AM
Tags
v203, vegas 2.0
