Old 05-01-2010, 05:47 PM   #14311
theisgroup's Avatar
Originally Posted by obi wun View Post
i have my wgt set with a 13.5 duo 2 and rs 1s....the settings r as follows
20 degrees on motor
profile 5
rpm..4400.....11000
timing...50
turbo....10
delay .2
ramp 3
Problem: i do not have enough bottom end power...i have plenty straight away speed, i need more bottom end speed...what could i do differently? any suggestions...help needed..
i would drop the motor timing to zero on the can. drop the end RPM down to 6500 and increase your delay to .4-.5, but that depends on if you get value out of the turbo at all.
on smaller tracks, i would possible look at the max/max setups like cuffs ran at the birds. but they do require a lot less gear. i would drop like 3-4 teeth from your current setup to run those.
yang lai
Team Tamale | Team Tekin | RCAmerica | Speedmerchant | Speedzone RC | EA Motorsports | Ko Propo USA | eXpress Motorsports | Parma/PSE
theisgroup is offline   Reply With Quote
Old 05-02-2010, 12:42 AM   #14312
Originally Posted by Randy_Pike View Post
You've left out a key factor in your setup: motor timing. What motor are you using and where is the timing set?
speedpassion 11.5t black color old version not V3.0, motor timing is lock, sorry I don't know timing value
mmh racing 8.5t motor timing 10
side_3 is offline   Reply With Quote
Old 05-02-2010, 01:59 AM   #14313
blade072's Avatar
Trader Rating: 98 (100%+)
i take it that if you accidently reverse the polarity on the esc (only took a second) that it will not be covered by the warranty......flames + smoke = unhappiness....
expensive lesson learned (and is out of warranty anyway)
David Randall
AWESOMATIX A800X ★ MUCHMORE ★ R1 WURKS ★
ROCHE RAPIDE F1-16 ★ SANWA M12 ★ SILVERBACK ★
HOBBYWING ★ RCMAKER ★ VOLANTE RC ★
blade072 is offline   Reply With Quote
Old 05-02-2010, 04:41 AM   #14314
Trader Rating: 15 (100%+)
please help me guys 1st run with the rs no brakes in advance mode tried motor on sxx esc no probs with couple of the guys at the track loaded there setups by hot wire with no luck so we messed round with the tx and epa like suggested on this thread tried various times with different values loaded 200v and reloaded 203v tried dual mode brakes seem ok. brakes not to bad on infield not great problem only comming off boost at end of straight if i dont hit boost its ok not great and no the wheels arnt locking up tried different ratios motor not getting hot. large track built for 1/5 cars. end setting as follows
redline 10.5t
2s lipo sensored mode
Firmware 203
Throttle profile: 3
Timing Boost: 40
Turbo Boost: 10
Start RPM: 4xxx
End RPM: 12000
Turbo Ramp: 1.0
Turbo Delay: 0.2
Gear Radio: tried 6.4 to 9.4 ended up with 9.4
got to drive mates sxx with x12 great punch and brakes good top end so i need help otherwise il have no option but to go back to blue
jay m is offline   Reply With Quote
Old 05-02-2010, 06:38 AM   #14315
wingracer's Avatar
Trader Rating: 24 (100%+)
redline 10.5t
Firmware 203
Throttle profile: 3
Timing Boost: 40
Turbo Boost: 10
Start RPM: 4xxx
End RPM: 12000
Turbo Ramp: 1.0
Turbo Delay: 0.2
I don't know about the brakes since I have never had a problem with them but raise those rpm levels a LOT. At least get the end rpm up to 20k or so. On a big track you will be at max boost all the time.
Sean. Certified speed crazed mowron.
Team Shepherd USA
www.ashfordhobby.com
wingracer is offline   Reply With Quote
Old 05-02-2010, 06:42 AM   #14316
cannon's Avatar
Trader Rating: 35 (100%+)
redline 10.5t
Firmware 203
Throttle profile: 3
Timing Boost: 40
Turbo Boost: 10
Start RPM: 4xxx
End RPM: 12000
Turbo Ramp: 1.0
Turbo Delay: 0.2
Out of interest what radio were you using?
www.feralbatteries.com ........... new website
cannon is offline   Reply With Quote
Old 05-02-2010, 06:48 AM   #14317
Trader Rating: 16 (100%+)
which brand motors do ur tekin powers for 10.5, 11.5, 13.5? Any reliable and FAST ones to recommend?
ronaldo-1234 is offline   Reply With Quote
Old 05-02-2010, 06:54 AM   #14318
Today I have try new the setup, thanks for everyone's suggestion, outdoor temp same yesterday, but wind more bigger.
Firmware 203
Throttle profile: 3
Timing Boost: 38
Turbo Boost: 7
Start RPM: 2xxx
End RPM: 14000
Turbo Ramp: 3.0
Turbo Delay: 0.3
Gear Radio: 5.8
motor timing 0
This setup use in mmh 8.5t hi-torque version, the motor temp looks allright is 65-70 degrees celsius,
if change turbo boost 7>10, speed have more better Performance, but temp up to 80+ in 4minute, and very fast speed on keep 2-3 minute, after 2-3 minute later speed down, look same turbo boost=7's speed, look feel no trubo boost in final speed, but timing boost looks no probelm.
Same setup use in mmh 8.5t hi-rpm version(same yesterday), motor timing 0. gear 6.4, turbo boost=7, motor temp probelm same yesterday, but have Some improvements, motor temp is 80-90degrees celsius,
not test in turbo boost=10,
How can I to modify setup is better? thanks
Old 05-02-2010, 07:00 AM   #14319
wingracer's Avatar
Originally Posted by side_3 View Post
Today I have try new the setup, outdoor temp same yesterday, but wind more bigger.
Firmware 203
Throttle profile: 3
Timing Boost: 38
Turbo Boost: 7
Start RPM: 2xxx
End RPM: 14000
Turbo Ramp: 3.0
Turbo Delay: 0.3
Gear Radio: 5.8
motor timing 0
If more turbo was giving a lot more speed, go for the more turbo. To bring the temps down, raise the end rpm a bunch and go down to ramp 1 or two.
Team Shepherd USA
Old 05-02-2010, 07:03 AM   #14320
wingracer's Avatar
Tekins and Duos.
Team Shepherd USA
Old 05-02-2010, 07:52 AM   #14321
20 SMOKE's Avatar
Trader Rating: 101 (100%+)
Originally Posted by wingracer View Post
Tekins and Duos.
x2 but i am a fan of tekins over the duo
Jamie W
*Team Tekin*Tekno-rc*DE Racing*AKA*DDHRC*
20 SMOKE is offline   Reply With Quote
Old 05-02-2010, 12:43 PM   #14322
i am after a little bit of help ,
i cooked my GM13.5 motor today and i replaced it with my Tekin 13.5
i tried two set ups
this 1st from Randy Pike
Start revs 4,xxx
End revs 12,xxx
turbo delay 0.5
timing boost 45
Turbo 10
gearing of 6.7
Throttle profile 5
end bell timing 4 degrees
the motor was at 85 degrees after 7 mins
i then went to my set up of
Start revs 4,xxx
end revs 10,xxx
turbo delay of 0.0
timing max
turobo 12
Gearing 6.7
Throttle profile 5
end bell timing 8 degrees
this set up was quicker but still the motor was 85 degrees , i run a motor cooler with a fan but still this is too hot
our track is quick open and a 70 meter straight wath speeds of around 80 kph at the end , there is only one slow corner and i am on full throttle a lot of the track .
I like the feel of the 0 turbo delay as the corner on to the straight is a fast sweeper and if i miss my line (i am no reinhard ) If i do miss it i have to get off the throttle then back on it and if i have a turbo delay then i can loose a meter or so on the straight .
Please help as i don't want to destroy another good motor , but i want to make this motor work , i am not far off the pace with the rest of the guys but want to make the motor cooler but 10 degrees or so
Thanks in advance Phil
sidecarphil1 is offline   Reply With Quote
Old 05-02-2010, 01:29 PM   #14323
duggyload's Avatar
Smile WOW
WE RAN A CLUB EVENT TODAY
17.5 TEKIN 1ST 2ND 3RD AND 4TH
SINCE I BOUGHT A TEKIN I HAVE HAD TO LEARN MORE ABOUT CAR SETUP
SPEED IS NO PROBLEM ANYMORE
THANKS GUYS
duggyload is offline   Reply With Quote
Old 05-02-2010, 03:48 PM   #14324
tomracing's Avatar
run the boost over a longer period.
start rpm @5k-8k
end rpm @17k-25k
it doesn't hurt acceleration (might even help it)
i think you heated the motor by to much timing to quick.
Tom van den Brink
RC Crewchief - setup software for racers
tomracing is offline   Reply With Quote
Old 05-02-2010, 04:14 PM   #14325
this is what i run in eindhoven;
Start revs 800
End revs 25k
turbo delay 0.2
timing boost 45
Turbo max
gearing of 6.3
Throttle profile 3
end bell timing 20 degrees, depending on weather, HOT days are 15 degree, cold days 25 degree.
widening the boost gives a lot more lineair feel on the acceleration. i started from about the same setup as you did. i quickly noticed i bogged a little round about 1/3th of the speed of the car. when i raised the end RPM the bog went away and motor got cooler. this was with max boost and max turbo! so then i was temping about 90 degree on a normal 20degree day. started to gear up 3 to 4 tooth and use little less timing, from max boost to 45. saved about 20 degrees of heat and gave a little more infield punch, but a little less back straight acceleration... then i started playing around with the motor timing. WOW and that was the big point! i started from about 12, and went up to 20, man it was like a modified motor! sooo much power. tried 25 degrees, was more power but got hotter aswell...
next thing im going to try is some cooling. i made a lexan part that directs air from a fan directly into the motor, trough the open slots of my motor. hope this helps!
good luck in Haren!
Mark
Markiempje is offline   Reply With Quote
Tekin Redline RS Sensored ESC and motors, opinions for offroad? Cain Electric Off-Road 4230 06-07-2015 04:38 PM
Sensored vs. Sensorless lemansracer Electric On-Road 71 02-14-2009 03:19 AM
New Tekin Redline Sensored Motors are Roar Legal! Randy_Pike Electric On-Road 3 08-05-2008 02:08 AM
Tekin Redline Sensored 10.5 HUCKMAN Electric On-Road 6 07-15-2008 08:50 PM
sensored vs sensorless bprocket Rookie Zone 5 05-16-2008 09:38 AM
Tags
v203, vegas 2.0
