Old 04-29-2010, 06:43 AM   #14266
20 SMOKE's Avatar
Trader Rating: 101 (100%+)
thats one that i have not seen,only his 10th was posted
Jamie W
*Team Tekin*Tekno-rc*DE Racing*AKA*DDHRC*
20 SMOKE is offline   Reply With Quote
Old 04-29-2010, 11:36 AM   #14267
Senna Racing's Avatar
Ha Randy
Any more news on the on the new software it is getting quite in here
Feral Batteries for all your on road needs
TRF 416, Fantom Batteries, Sorex, Tekin
Senna Racing is offline   Reply With Quote
Old 04-29-2010, 03:46 PM   #14268
Team Tekin
Randy_Pike's Avatar
Send a message via Yahoo to Randy_Pike
No, there is no advantage. If anything it's a disadvantage. The stock cap has superior qualities for it's job. IF you do anything you should/could add a 2nd cap TT3520.
"Things may come to those who wait, but only the things left by those who hustle." Abraham Lincoln
Tekin,Protek,A-Main Hobbies,JConcepts,Avid RC,Yokomo,MIP,SikLidz,FactoryRC, www.randypikerc.com
Randy_Pike is offline   Reply With Quote
Old 04-29-2010, 03:59 PM   #14269
I've just dusted off my 1/10 touring car and updated the software to the new 203 and would like a little guidence to base settings please. I run on a small technical high grip carpet track using rubber tyres, track is approx 24m x 12m. Using the old 200 software i had plenty of speed without the turbo but always seemed to lack the torque / punch of the lrp's and Nosrams.
Xray T2 009
Tekin RS 203 firmware
Tekin 10.5 timing on can at 0
7.4v 5400mah 45c Orion lipo
FDR high 6's early 7's motor comes off cool / 100 degrees f after 5 min race
I'm slightly confused by the motor / can timing as people have said to turn it up to get more punch but others say it increases speed / revs? My lack of punch is not soft batteries as i have tried / borrowed others with no performance gain. Any help appreciated.
BILKO1 is offline   Reply With Quote
Old 04-29-2010, 04:45 PM   #14270
Micro-E's Avatar
Xray T2 009
FWIW: I run a Tekin 17.5 and was tuning around 0* on the can. Always seemed to lack "punch" for me - as well as oddly low temps. Set the can @ 10* and WHAMMO, it now has "punch" and temps went up a good +25*F.
- Erik
Micro-E is offline   Reply With Quote
Old 04-29-2010, 04:50 PM   #14271
LOSI123's Avatar
Trader Rating: 63 (100%+)
LOSI123 is offline   Reply With Quote
Old 04-29-2010, 08:19 PM   #14272
Hi: Can anyone tell me if there is any problem with operating a Futaba transmitter in HRS mode with the RS ESC or is it better to use the PPM mode.
Thanks in advance.
AlGio is offline   Reply With Quote
Old 04-30-2010, 02:36 AM   #14273
Hi I am about to try a Nosram X12 Pure Evo 10.5 (not sure if this is the same as the LRP in ALL respects)
Does anyone know what the real engine timing is at the factory default level ie the 2 dot timing adaptor?
Someone said to me to use the 4 dot adaptor (-10*) but I read somewhere that the 4 dot retards the timing, which suggests to me that the 2 dot is<+10*
I know there is no simple answer but has anyone got a view on a good motor timing setting on these - I am more interested in infield punch than top speed.
yellowshark is offline   Reply With Quote
Old 04-30-2010, 03:33 AM   #14274
Skitee's Avatar
Apparently it's something like 28 - 32 degrees at zero on the motor.
Xray T4 2018 ~ HobbyWing Xerun XR10 Pro ~ Motiv RC 4.5
Xray X12 2018 ~ ORCA Vritra VX3 1S ~ Speedzone 4.5
POWERED BY SPEEDZONE USA
Skitee is offline   Reply With Quote
Old 04-30-2010, 04:21 AM   #14275
tc3team's Avatar
Thanks in advance.
Are you asking because you cannot sync the ESC to the Transmitter?
If so, in some cases, (with Futaba Transmitters), it is a known "issue" (I use this term very light way, it's not an issue, just an extra step to tune in the ESC to the Transmitter) to reverse the throttle channel to allow the ESC to be sync'd to the Transmitter.
Hope that answers your question!
Fusion Hobbies / www.horshamrc.org
The wife stops me being sane and the r/c stops me from going insane....
tc3team is offline   Reply With Quote
Old 04-30-2010, 09:20 AM   #14276
Thanks. That's more like the figure I had in mind. So the statement on this website that no.1 timing adapter retards the timing is misleading, all it does is reduce the timing advance 10 degrees down to say 18-22, yes?
Old 04-30-2010, 09:53 AM   #14277
Trader Rating: 18 (100%+)
Thanks in advance.
So far so good. I am using FASST though. YMMV.
SMC ( www.smc-racing.com the only place to order your batteries online.), Awesomatix, Gonzo Paints, BN Racing
"Imitation is the sincerest form of flattery."
Advil is offline   Reply With Quote
Old 04-30-2010, 12:34 PM   #14278
M-Technic's Avatar
Trader Rating: 15 (100%+)
How does the start RPM affect what kind of final drive you run?
Let's say for 17.5 (stock) you are running a 6.5 final drive with a 3,000 start RPM. You then raise the start RPM to 6,000. Would you want to move the start RPM a ~6.0 final, or the other way to a ~7.0 final? I don't know which direction to take the final drive when making changes to the start RPM.
RCAmerica | Xray | Hudy | Radiopost | Speed Passion USA | Trinity | P3 Graphics
M-Technic is offline   Reply With Quote
Old 04-30-2010, 01:01 PM   #14279
Krio's Avatar
Trader Rating: 150 (99%+)
In your example you would want to move closer to the 6.0 FDR. When you increase the start rpm you are applying less timing at any rpm lower than your end rpm. *all assuming you have a properly set end rpm.
www.kriostasis.com
Krio is offline   Reply With Quote
Old 04-30-2010, 01:07 PM   #14280
[QUOTE=Skiddins;7328322]Any gearing and settings advice on the following track;
It would be on the following layout;
http://www.youtube.com/watch?v=do0FIidbXvs
same queston as skiddins but ill b using a gm13.5 motor
my settings as of now are
version 203
start 4873
end 13996
brake strenth 95
neutral width 5
motor type bl-fl
trottle profile 3
voltage cutoff off
push control off
timing boost max
turbo boost 10
turbo delay 2.0
turbo ramp 2.0
gearing 6.0
thanks
stcc ssb tires, ko ,gm motors, demon products lipos, hobbywing speedo
mwoods is offline   Reply With Quote
Tekin Redline RS Sensored ESC and motors, opinions for offroad? Cain Electric Off-Road 4230 06-07-2015 04:38 PM
Sensored vs. Sensorless lemansracer Electric On-Road 71 02-14-2009 03:19 AM
New Tekin Redline Sensored Motors are Roar Legal! Randy_Pike Electric On-Road 3 08-05-2008 02:08 AM
Tekin Redline Sensored 10.5 HUCKMAN Electric On-Road 6 07-15-2008 08:50 PM
sensored vs sensorless bprocket Rookie Zone 5 05-16-2008 09:38 AM
Tags
v203, vegas 2.0
