Old 04-27-2010, 07:14 PM   #14236
Originally Posted by VenturaDC View Post
Any one have drag brake issues? i have drag brake turned off but it still acts like there is some drag brake, drive train is free smooth and mesh is set perfectly. the weird thing is that after full throttle if i lightly tap the brake, not even enough to slow the car down it'll roll for a heck of alot longer then just letting off to neutral, ive tried different radios, motors, setups, ect to no avail and i have a friend with the same exact issue, this wasnt an issue with 200.
I have the same issue,I tried to solve it but couldn't find the solution.
grouchy is offline   Reply With Quote
Old 04-27-2010, 07:15 PM   #14237
CCristo's Avatar
Trader Rating: 55 (100%+)
What do you have your neutral width set at?
Chris Cristo
Pro-Line RacingHobbywingMIPBOOMrcFutabaPT RC Racing Oils
CCristo is offline   Reply With Quote
Old 04-27-2010, 07:19 PM   #14238
theisgroup's Avatar
if you want less drag brake effect, then turn it off and run push control. i always run push in 17.5 and 13.5. the motor just has soo much drag to it internally
yang lai
Team Tamale | Team Tekin | RCAmerica | Speedmerchant | Speedzone RC | EA Motorsports | Ko Propo USA | eXpress Motorsports | Parma/PSE
theisgroup is offline   Reply With Quote
Old 04-27-2010, 07:43 PM   #14239
20 SMOKE's Avatar
Trader Rating: 101 (100%+)
i did see this this weekend i tried some push control and it free rolled alot more but went back to 0 untill i can get a feel for it
Jamie W
*Team Tekin*Tekno-rc*DE Racing*AKA*DDHRC*
20 SMOKE is offline   Reply With Quote
Old 04-27-2010, 08:41 PM   #14240
VenturaDC's Avatar
Trader Rating: 32 (100%+)
The neutral width is set in the middle, ill check later what exactly, but the weird thing is like i said if i just touch the brakes a little bit and then let go it will free roll like normal so its not the motor having to much drag. it sucks im so used to having a free rolling car and now even running push control set even kinda high it just doesnt feel the same.
Dustin Colt45 Aguirre
Kyosho RB6--Futaba--HW--Shuurspeed 17.5
Kyosho SCR--Hitec--Lrp--Yeah 13.5
Durango Dex210--Futaba--Trakpower--Tacon 8.5
VenturaDC is offline   Reply With Quote
Old 04-27-2010, 09:04 PM   #14241
theisgroup's Avatar
what is kinda high. I run 40-45 push and i have not had the problem you are seeing. the car rolls forever. the higher you run in gearing the higher push you will run to get the same effect. but that just makes sense. with a higher roll out, it takes much more energy to make the car roll. push control is like running roll in your transmitter. the higher the gear the more "roll" you have to apply to keep the car rolling. one thing to know is that the effects of push control is affected by the amount of "on throttle" you run between the corners. the more you are on throttle the more effective the push control is.
brushless motors have much more drag then they did when they first started showing up on the shelf. the technology is just getting better. but the higher the wind the more drag the motor has. 17.5 and 13.5 motors have quite a bit of drag.
yang lai
Old 04-27-2010, 09:22 PM   #14242
Originally Posted by Skiddins View Post
Any gearing and settings advice on the following track;
It would be on the following layout;
http://www.youtube.com/watch?v=do0FIidbXvs
Last year I ran an FDR of 4.5 with a 10.5 LRPx11 using the LRP SPX speedo on setting 8.
I will be using an RS Pro with an LRP x12 on standard timing. What's the highest combination of settings I could use on that combo?
Skiddins
Try drop 6-8 teeth (64pitch) or 4-6 teeth (48pitch) in your pinion compared to SPX+10.5 and set the following on your Tekin:
Sensored mode
Boost = 45
Turbo = 5
Delay = 0.5
Start = 3,xxx
End = 15,xxx
Ramp = 2.0
These settings are quite conservative.
However, remember to temp your motor after 2 minutes or so.
IF the motor is cool/warm (like ~40C) , then add more boost/turbo/add pinion.
IF the motor is too hot (like >85C) then reduce boost/turbo/drop pinion.
For LRP, I think the optimal temp is around 65-70C. good luck.
hardmankam is offline   Reply With Quote
Old 04-27-2010, 11:20 PM   #14243
VenturaDC's Avatar
Well let me simplify, same car, same motor, same battery, same gearing same everything. ver200 let off throttle to neutral and the wheels free spin, ver203 let off throttle wheels stop quite suddenly even with drag brake turned off, like stated before if i lightly tap the brakes after full throttle on ver203 the wheels will free spin like they do on ver200 and if i do not the car slows down pretty quick. ive been around long enough to know what the motors where like when they first started showing up and what they are now. Right now when i lift off it feels like a brushed 27t.
Old 04-27-2010, 11:45 PM   #14244
VenturaDC's Avatar
well i removed push control, uped the neutral width to 25, changed a few other settings, recalibrated and has gotten much better
Old 04-28-2010, 03:12 AM   #14245
tc3team's Avatar
Skiddins
I hope there's not a 21.5 class, or the pinion will be almost as big as the spur gear....
I think that trying the same gear ratio (4.5) and a small amount of motor timing might be worth trying, then temp check after 2 and then 4 minutes.
Usually boost is more effective on small/medium tracks, turbo could be overkill and over rev an already fast motor, although my logic could well be flawed..
Fusion Hobbies / www.horshamrc.org
The wife stops me being sane and the r/c stops me from going insane....
tc3team is offline   Reply With Quote
Old 04-28-2010, 02:11 PM   #14246
Skiddins's Avatar
You say medium track, but if the full back straight was used it would be one of the fastest tracks in Europe, possible the world.
They regularly blow 1/8 engines on that straight.
The big corner leading onto the straight is banked
Skiddins
Xray T4'18, T4'14 (Wet Car)
Xray X12 2018
Xray X1'16
wlrc.co.uk (West London Racing Centre)
RCDisco.co.uk
Skiddins is offline   Reply With Quote
Old 04-28-2010, 02:58 PM   #14247
marcel p's Avatar
Send a message via MSN to marcel p
Skiddins
this is now way the fastest track.
come race in holand at least 3 tracks way faster as that
PR racing
Powerstar/futaba 4px
Absima /vr racing
marcel p is offline   Reply With Quote
Old 04-28-2010, 03:20 PM   #14248
2wdrive's Avatar
Probably Lostallo in Switzerland has the biggest rc track in the world
http://www.youtube.com/watch?v=Zq88b...eature=related
2wdrive is offline   Reply With Quote
Old 04-28-2010, 03:46 PM   #14249
What setting are people finding to work well with the X12 17.5? I run on a 90x50 track.
I use a Dou2 17.5 now geared 5.6. Max boost and turbo. also what timing setting on the x12?
Thanks for the help,
Joe
Joe Maxey is offline   Reply With Quote
Old 04-28-2010, 05:16 PM   #14250
Skiddins's Avatar
Lostallo is a longer circuit (403m), but only 43m longer as a track.
Baring in mind that Lostallo has a bigger infield, that meansd the straigh6t at Brookland must be at least the same.
Skiddins
Xray X12 2018
Xray X1'16
RCDisco.co.uk
Tekin Redline RS Sensored ESC and motors, opinions for offroad? Cain Electric Off-Road 4230 06-07-2015 04:38 PM
Sensored vs. Sensorless lemansracer Electric On-Road 71 02-14-2009 03:19 AM
New Tekin Redline Sensored Motors are Roar Legal! Randy_Pike Electric On-Road 3 08-05-2008 02:08 AM
Tekin Redline Sensored 10.5 HUCKMAN Electric On-Road 6 07-15-2008 08:50 PM
sensored vs sensorless bprocket Rookie Zone 5 05-16-2008 09:38 AM
Tags
v203, vegas 2.0
