Old 04-20-2010, 04:42 PM   #14131
cyclone x's Avatar
is it true if you run like a 5.5 on 203 the esc will cook
Chase Chandler
Sponsors:HOTBODIES Express .The Track. Stevo Racing
Cars: VE8, F104 PRO, B4.1, HPI BLITZ, Losi SCTE
cyclone x is offline   Reply With Quote
Old 04-20-2010, 04:59 PM   #14132
dawgmeat's Avatar
Originally Posted by 20 SMOKE View Post
10.5,when is that coming,for club
dawgmeat is offline   Reply With Quote
Old 04-20-2010, 06:10 PM   #14133
20 SMOKE's Avatar
Trader Rating: 101 (100%+)
any thing will cook,thats why you start slowly
Jamie W
*Team Tekin*Tekno-rc*DE Racing*AKA*DDHRC*
20 SMOKE is offline   Reply With Quote
Old 04-20-2010, 06:11 PM   #14134
20 SMOKE's Avatar
Originally Posted by dawgmeat View Post
i thought it said 13.5,10.5 on foam would be good
Jamie W
Old 04-20-2010, 06:38 PM   #14135
Originally Posted by Joe Maxey View Post
We have a 17.5 stock class locally and they have a no boost or turbo rule.
My question is what software would be best for my rs in this class v180, v200 or v203 or are all the software the same except for the boost and turbo?
Thanks,
Joe
Has anyone try these differant settings for spec stock racing?
Joe Maxey is online now   Reply With Quote
Old 04-20-2010, 08:18 PM   #14136
macdude's Avatar
I have used the rs with early versions of the software and it is not as good as v203 even without the turbo and boost. Before changing to software v198 I was getting smoked by the GTB controllers. I would have to put 2-3 teeth to make up difference. After 198 there is not as much difference but I would just use v203 with the boost and turbo values at 0.
KO Eurus / Orca / MMP / XB2 / 22-4 /
macdude is offline   Reply With Quote
Old 04-20-2010, 08:38 PM   #14137
Thanks That is exactly what I thought.
Thanks,
Joe
Old 04-20-2010, 09:20 PM   #14138
blanks596's Avatar
Trader Rating: 14 (100%+)
could someone help me with the math. I'm trying to get an estimate on run time. Does anyone know the avg amp draw of a 13.5 redline? If my math is correct (it's probably not) then using a 5 amp/hr battery with a 30 amp motor would only last 10 minutes in theory only as I know I couldn't possibly run 30 amps continuously around the track
thanks in advance
Serpent/Desoto Racing
Max S
blanks596 is offline   Reply With Quote
Old 04-20-2010, 09:41 PM   #14139
theisgroup's Avatar
thanks in advance
things to remember about this calculation.
1. if the batt is rated at 5000mah, then you will only get about 4000mah before the pack hits low voltage (3.0v/cell)
2. i can tell you that on one of our layouts, I was averaging 28amps in 1s 13.5
3. the 5000mah is actually 5 amp*hours. not amps per hour (amp/hour) this nuance is important if you ever learn what they use to call factor label method. which I hear they don't teach in school these days
but here is the math
(ah x 3600) / avg Amps = # seconds
yang lai
Team Tamale | Team Tekin | RCAmerica | Speedmerchant | Speedzone RC | EA Motorsports | Ko Propo USA | eXpress Motorsports | Parma/PSE
theisgroup is offline   Reply With Quote
Old 04-20-2010, 10:01 PM   #14140
blanks596's Avatar
or 4 amp/30amps x 60min thanks just trying figure it out so 4amp x 3600/(201watts/7.4v)=8 min 51 sec if my avg amp were 27. So in all, maybe a run time of only 10-12 minutes
Max S
Old 04-20-2010, 10:05 PM   #14141
blanks596's Avatar
out of curiosity, how much run time are the 1/8 scale buggies getting with all that power?
Max S
Old 04-20-2010, 10:53 PM   #14142
YR4Dude's Avatar
Trader Rating: 44 (100%+)
Max, are you trying to run two qualifiers without charging?
If you want to run longer than 10min, just run your nitro instead.
YR4Dude is offline   Reply With Quote
Old 04-20-2010, 11:30 PM   #14143
64buick's Avatar
I ran a 5.3 here at speedworld in cali and the temp never got above 100
tf-5,slash mod,slash spec,hpi 5t,losi comp,mrc,t-maxx(custom electric)
64buick is offline   Reply With Quote
Old 04-21-2010, 01:18 AM   #14144
Hello,
What do you think about this setup for a 10.5 on a big track ?
timing boost: 48
turbo boost: 18
4800rpm - 10000rpm
turbo delay: 0.2
turbo ramp 3
Manu_05' is offline   Reply With Quote
Old 04-21-2010, 02:41 AM   #14145
Originally Posted by Manu_05' View Post
Hello,
timing boost: 48
turbo boost: 18
4800rpm - 10000rpm
turbo delay: 0.2
turbo ramp 3
On a big track, maybe you can space out rpm for boost and increase the delay, depending on the straight:
try:
s: 35xx
e: 16xxx
delay: 0.4 to 0.6
with this setting, your motor will not be as hot.
hardmankam is offline   Reply With Quote
Tekin Redline RS Sensored ESC and motors, opinions for offroad? Cain Electric Off-Road 4230 06-07-2015 04:38 PM
Sensored vs. Sensorless lemansracer Electric On-Road 71 02-14-2009 03:19 AM
New Tekin Redline Sensored Motors are Roar Legal! Randy_Pike Electric On-Road 3 08-05-2008 02:08 AM
Tekin Redline Sensored 10.5 HUCKMAN Electric On-Road 6 07-15-2008 08:50 PM
sensored vs sensorless bprocket Rookie Zone 5 05-16-2008 09:38 AM
Tags
v203, vegas 2.0
