Old 04-17-2010, 03:11 PM   #14071
dawgmeat's Avatar
Big problem
Running LRP 17.5
smc 5200
end 15000
begin 5000
ramp 2
delay .2
profile 3
fdr 6.8
timing 50
turbo 10
motor was running fine all day and all of a sudden thr throttle stop working
1,2,6,7 where flashing which mean wrong motor selected. tried the following:
replaced sensor wire
recalibrated
attach the hotwire and press current settings and i was in duel mode this was not save as duel mode, reset everthing with the hot wire and 1267 are still flashing. is the esc OOC
dawgmeat is offline   Reply With Quote
Old 04-17-2010, 03:22 PM   #14072
danjoy25's Avatar
R/C Tech Charter Subscriber
Trader Rating: 37 (100%+)
same thing happen to me. Tried reloading different version softwares and recalibrate neutral, full and brake position which all still works but still reverts back to those LED's flashing back. still not happy as that proves that it wasn't user fault and had to pay for it to get fix which cost me close to $150 by the time the got it back and now the brakes are too weak.
Awesomatix A800 & A800X/ Mugen MTX-5 / 3 Racing F113 / Kyosho RB5 / Kyosho Mini-Z
danjoy25 is offline   Reply With Quote
Old 04-17-2010, 04:06 PM   #14073
dawgmeat's Avatar
Originally Posted by dawgmeat View Post
Big problem
Running LRP 17.5
smc 5200
end 15000
begin 5000
ramp 2
delay .2
profile 3
fdr 6.8
timing 50
turbo 10
recalibrated
This happen to myself and another seasoned vet today lucky for him he had another rspro but my fl state series is a wrap for this weekend
Old 04-17-2010, 04:20 PM   #14074
Default help
Hi, I contact you because I have a problem with a Tekin RS pro.
Tekin has stopped and the flashing LEDs 1 / 2 End 6 / 7 that yipo engine wrong.
I changed the engine, I changed my cable sensors, I reloaded the softwear Tekin, but the problem remains
I hope I solved the problem Tekin
even though I'm Italian and I do not know how I can send my reply as the Tekin RS Pro, I hope someone help me, otherwise I will remain very much disappointed by Teki, my esc is new.
biagio23 is offline   Reply With Quote
Old 04-17-2010, 04:24 PM   #14075
20 SMOKE's Avatar
Trader Rating: 101 (100%+)
flash back to a old version and then back to 203 see if it cures and make sure there are no solder frags crossing over the wires
Jamie W
*Team Tekin*Tekno-rc*DE Racing*AKA*DDHRC*
20 SMOKE is offline   Reply With Quote
Old 04-17-2010, 04:51 PM   #14076
I tried to put the software 200 and then install the v203, but the problem persists, check all welds redone all, but nothing I do not know what to do.
Old 04-17-2010, 05:11 PM   #14077
Same problem here. I was actually running the car, it stopped suddenly and I have the 12 and 67 lights flashing. Tried resetting, recalibrating and reeverything I could think to try to no avail. Anyone with any ideas please chime in. Thanks.
Dave
dave is offline   Reply With Quote
Old 04-17-2010, 05:23 PM   #14078
Lightbulb
Dave
many are having this problem, I hope Tekin intervene, I always use Tekin and never had problems, but with my last Tekin RS pro I have not been lucky
Old 04-17-2010, 06:16 PM   #14079
20 SMOKE's Avatar
when you go back to a old version try it make sure that everything works and even go back to 180 and then 203
Jamie W
Old 04-17-2010, 06:23 PM   #14080
so.. after pulling my hair for a couple of hours, reading everything I could find on the net and trying all possible combinations of connecting the ESC, Im still stuck with all LEDs dim, and no further reaction from the ESC whatsoever.
To sum up what I believe caused this situation:
The communication from the PC software to the ESC seemed a bit odd from the beginning, by not being able to apply settings, and not being able to update the firmware properly. The flashing chain was 180->200->203->200 and the last step must have messed it up completely.
According to a statement I found somewhere in this thread, the dim lights can be a sensor issue or a bad software installation. The facts that it happened during software installation and that the situation doesnt change when disconnecting the sensor cable let me assume that the firmware isnt installed properly.
Without a properly running firmware, no connection to the PC software can be established, and therefor the firmware cant be rewritten.
I can see two possible solutions:
- an alternative way of "forcing" the firmware onto the device.
- getting a new ESC
As Tekin prefers to deal with customers directly, getting a new ESC (of have Tekin themselves "forcing" the firmware) would mean additional shipping costs and, even worse, a couple of weeks more waiting time.
In addition, this would mean that it could happen again whenever Im updating the firmware in the future.
So if sending it in is the solution here, Im very tempted to return the thing and get anything else.
I know I could just use the Tekin RC without the HotWire, but I make my money with software, and when I have a device that is able to connect to the PC, I HAVE to do it..
Being a novice to the Tekin RS, Im far from a novice in regards to flashing firmware onto all sorts of devices. Doing so is part of my job, and I know that it can be harmful to disconnect a device during the update process. This was also stated in the manual and on the screen during the process.
So, I can asssure the decive was not disconnected during the update, it wasnt even touched.
The only halfway satisfying solution for me in this case would be a way of rewriting the firmware without sending it back to Tekin.
For now, Im putting the whole shiny new car and all related stuff in the garage so I dont have to see it for the rest of the weekend, and make other plan to enjoy it.
Im really sorry for the rant, but Im really frustrated now.
I tried to keep it as objective as I possible could..
a happy racing Sunday to you all!
Last edited by DrBen; 04-17-2010 at 07:19 PM. Reason: typos (doesnt mean that I got them all..)
DrBen is offline   Reply With Quote
Old 04-17-2010, 07:09 PM   #14081
rocketron's Avatar
Trader Rating: 16 (100%+)
You can re-flash the software? I have seen the same and just re-flashed the ESC.
Sounds like your familiar with the process - I wouldn't give up on the Tekin personally.
rocketron is offline   Reply With Quote
Old 04-17-2010, 07:17 PM   #14082
How did you reflash the ESC software when the PC software doesnt open up because it cant detect the ESC?
Thats exactly what Im looking for.
Old 04-17-2010, 07:58 PM   #14083
theisgroup's Avatar
hey guys, when you get the 1,2,6,7 flash, take a look at your motor leads. I had this problem in the past. the motor had been in the car for 4 weeks, but one weekend, I ended up with the 1,2,6,7 flash. i found a loose motor wire. also remember that if you loose motor wire, the speedo no longer can figure if you are running brushed or brushless. just check the motor leads.
yang lai
Team Tamale | Team Tekin | RCAmerica | Speedmerchant | Speedzone RC | EA Motorsports | Ko Propo USA | eXpress Motorsports | Parma/PSE
theisgroup is offline   Reply With Quote
Old 04-17-2010, 08:37 PM   #14084
Geezatec's Avatar
RS manual tells you to look at motor type, brushed or Brushless, in troubleshooting section. You should check the motor leads also. Aslo check LED6 for motor type on RS and also with Hotwire.
Geezatec is offline   Reply With Quote
Old 04-17-2010, 08:53 PM   #14085
rocketman17's Avatar
The same thing happened to me, it was a burned out phase in the motor. I guess I had the timing set too high.
rocketman17 is offline   Reply With Quote
Tekin Redline RS Sensored ESC and motors, opinions for offroad? Cain Electric Off-Road 4230 06-07-2015 04:38 PM
Sensored vs. Sensorless lemansracer Electric On-Road 71 02-14-2009 03:19 AM
New Tekin Redline Sensored Motors are Roar Legal! Randy_Pike Electric On-Road 3 08-05-2008 02:08 AM
Tekin Redline Sensored 10.5 HUCKMAN Electric On-Road 6 07-15-2008 08:50 PM
sensored vs sensorless bprocket Rookie Zone 5 05-16-2008 09:38 AM
Tags
v203, vegas 2.0
