Old 04-15-2010, 07:49 PM   #14026
Trader Rating: 114 (100%+)
Originally Posted by HarryLeach View Post
What in the world are you running? The newest version [203] has the broadest setup/gearing "sweet spot" to date that I've run.
200 was fast but could be touchy when it comes to being fast without burning up
198 was quick, but pretty narrow on setup to keep heat under control
189 was quick, but you'd better temp often and adjust quickly to keep the heat down
183 is pretty much a no-brainer on setup, but a lot like a GTB when it comes to stock class power
We could NOT run 203 for TCS. We had to run 200 or earlier versions.
Chris Furman is offline   Reply With Quote
Old 04-15-2010, 09:05 PM   #14027
HarryLeach's Avatar
Send a message via AIM to HarryLeach
Ah, gotcha.
I still stand by my answer though, 200 would be your best bet. The best way I found with v200 was to tweak it in is with zero turbo, gear and boost for best infield, then use enough turbo to see a difference, adjust your turbo delay for a consistent engagement point on the straight, then adjust turbo up or down until you're happy with the temps. I saw a few motors get toasted on v200 from people scrapping their entire hotwire profile and gearing to try and shortcut by using someone else's profile without matching gearing or driving style. I made the same mistake briefly and caught my motor at around 200* but luckily before it fried
198 was extremely touchy to dial in for me. Just changing driving line or being more aggressive on my driving could sometimes jump the temps up 40* with no other gearing or setup changes.
189 would be too slow on anything but a very slick track, IMO.
What kind of motor and settings were you losing motors with?
Privateer racing lots of stuff.
Remember kids, racing isn't fair!
HarryLeach is offline   Reply With Quote
Old 04-16-2010, 01:48 AM   #14028
GSM Storm's Avatar
Trader Rating: 112 (100%+)
Originally Posted by FLATMAN View Post
HEY BUD
Had this problem yesterday try and unpluging it and plug it back in again!
with mine the red wire was off in the inside of the speedo,but fixed it and it was 100 again. hope u get it fixed
You were right, the white wire had broken in the receiver plug but the wire insulation was still crimped in the terminal, must have been just touching when I pluged it into the receiver.
I soldered it to the terminal and all is working correct now.
Thanks for your help.
Regards
Gary
Driver Gazza
Offroad - RC10 B64 (soon)
Vintage - Kyosho Tomahawk
Fantom Racing, JConcepts, Ace Hobbies/Reedy,
WTF, Plaig Bearings.
GSM Storm is offline   Reply With Quote
Old 04-16-2010, 01:53 AM   #14029
FLATMAN's Avatar
Regards
Gary
Dont thank me just burn rubber buddy!!
glad u are sorted!!
FLATMAN is offline   Reply With Quote
Old 04-16-2010, 02:36 AM   #14030
spencehotbodies's Avatar
Default NEW SOFTWARE FOR TEKIN
Hello
Hope some one can help, I heard wispers about v209 coming out, true or false?
Cheers Inadvance
Spence
spencehotbodies is offline   Reply With Quote
Old 04-16-2010, 04:18 AM   #14031
hijinx's Avatar
Trader Rating: 47 (100%+)
nope the X11 17.5 dont have adjustable timing, what throttle profile should i run it at?
Originally Posted by 20 SMOKE View Post
fdr 6
45 timing boost
10 turbo
delay 5
ramp 1
start 3xxx
end 14000
does the motor have adjustable timing? i run redlines
Sponsored by Yokomo Australia Team Hearns Hobbies, AKA Tires from Ryper Hobbies.Fantom batteries and motors. Hobbywing,Pro Amps servos,Wild Turbo Fans,TWT. Yokomo BMax2 Hobbywing Fantom Ion4 8.5t. Yokomo BMax4 III Hobbywing Fantom Ion4 6.5t. Yokomo BD7 2016 Hobbywing Fantom FR-1 4.5. S2H BODIES for all your custom RC paint jobs.
hijinx is offline   Reply With Quote
Old 04-16-2010, 05:02 AM   #14032
hijinx's Avatar
Hey there guys whats good settings for the redline 17.5, engine timing on the motor itself and the settings on the Tekin rs, my fdr is 6.5, should i go to 6.0 or leave it at 6.5.
Cheers
Old 04-16-2010, 06:01 AM   #14033
20 SMOKE's Avatar
Trader Rating: 101 (100%+)
your preference
i could be off alittle on my setting as i was working on 5-6 esc setups and was getting a little lost on what my own where
17.5 TC
fdr 6.5
motor 12
timing boost 52
turbo 7
delay .4
ramp 2
start 3xxx
end 14500
17.5 TC
fdr 6.5
motor 15
timing boost 50
turbo 7
ramp 2
start 4xxx
end 15500
17.5 needs a little bottom snap and try gearing ran in the main worked as good second setup with more straightaway speed
fdr 6.5
motor 18
timing boost 50
turbo 10
start 5xxx
end 16500
all with 0.4 delay
13.5 1/12
fdr 37/87 full BSR tire (62.xx roll out i think)
motor 12
timing boost 50
start 3xxx
end 8000
turbo 6
delay .4
ramp 2
moderate to low temp i only got to run for practice i had issue's and ran TC but it was very fast
Cheers
gearing depends on the sizeof the track but 6-6.5 is ok
Jamie W
*Team Tekin*Tekno-rc*DE Racing*AKA*DDHRC*
20 SMOKE is offline   Reply With Quote
Old 04-16-2010, 07:02 AM   #14034
Originally Posted by tallyrc View Post
yes. you hardly have any timing. what yoou have is a bunch of turbo.. set the timing to more like 40-45 and the turbo to more like 10.. then when you recalibrate your speedo after applying the settings, set your epa to 90% of full, calibrate, then turn it up to 100%... also your not showing an end rpm and your start is a wee low..
Ooh err. Are you meant to recalibrate your speedo (to the transmitter??) every time you change an ESC setting? I thought you only had to do this after making a change in Transmitter settings. I must say I have made changes that have made a difference but am I not getting the full benefit?
yellowshark is offline   Reply With Quote
Old 04-16-2010, 07:26 AM   #14035
20 SMOKE's Avatar
you only calibrate when you change to versions,what he is saying is to set the endpoint at 90* calibrate then add 10 to the endpoint
Jamie W
Old 04-16-2010, 07:58 AM   #14036
Need setup asap for novak ballistic 17.5 on carpet track 80x30 with high grip
nitroguy408 is offline   Reply With Quote
Old 04-16-2010, 09:48 AM   #14037
wstuart's Avatar
Trader Rating: 112 (98%+)
Send a message via AIM to wstuart
Got my system working on my 17.5 Duo 2
WAY FAST!!!
just wondering how do i get more bottom end punch
right now i have
FDR 7.8
end rpm 7500
start 1500
TP 4
turbo 12
timing 50
ramp - 3
delay .1
i turned up the ramp, lowered the delay and upped the gearing and that helped alot with the bottom end - just wondering if there is anything else I can do - I guess im just trying to get it to "feel" like my spx but still have tis insane top end
Yokomo Yz-2 x2
Yokomo B-max4iii
Awesomatix a700 evo
Team El Cajon Hobbies
wstuart is offline   Reply With Quote
Old 04-16-2010, 10:02 AM   #14038
Raise your start to 3000. That should give you you what you are looking for.
WAY FAST!!!
right now i have
FDR 7.8
end rpm 7500
start 1500
TP 4
turbo 12
timing 50
ramp - 3
delay .1
Steve Walter
Sweep Racing USA/ Speed Passion USA/ Karens Famous Cookies (Transporter)
SRW141 is offline   Reply With Quote
Old 04-16-2010, 10:02 AM   #14039
Skitee's Avatar
WAY FAST!!!
right now i have
FDR 7.8
end rpm 7500
start 1500
TP 4
turbo 12
timing 50
ramp - 3
delay .1
I think you're over timing the motor at the bottom end, you want the motor to start off using it's torque to get going and by starting to apply the timing at 1500rpm you're robbing the motor of start up torque. Maybe try this and see how it feels.
End RPM 10500 - 12000
Start RPM 5500 - 7000
TP 5
Turbo Boost 12
Timing Advance 50
Turbo Ramp - 2
Turbo Delay .5
OR
End RPM 15000
Start RPM 5000
TP 4
Turbo Boost 12
Timing Advance 50
Turbo Ramp - 2
Turbo Delay 0
Xray T4 2018 ~ HobbyWing Xerun XR10 Pro ~ Motiv RC 4.5
Xray X12 2018 ~ ORCA Vritra VX3 1S ~ Speedzone 4.5
POWERED BY SPEEDZONE USA
Skitee is offline   Reply With Quote
Old 04-16-2010, 11:02 AM   #14040
Senna Racing's Avatar
Feral Batteries for all your on road needs
TRF 416, Fantom Batteries, Sorex, Tekin
Senna Racing is offline   Reply With Quote
Tekin Redline RS Sensored ESC and motors, opinions for offroad? Cain Electric Off-Road 4230 06-07-2015 04:38 PM
Sensored vs. Sensorless lemansracer Electric On-Road 71 02-14-2009 03:19 AM
New Tekin Redline Sensored Motors are Roar Legal! Randy_Pike Electric On-Road 3 08-05-2008 02:08 AM
Tekin Redline Sensored 10.5 HUCKMAN Electric On-Road 6 07-15-2008 08:50 PM
sensored vs sensorless bprocket Rookie Zone 5 05-16-2008 09:38 AM
Tags
v203, vegas 2.0
