Old 04-15-2010, 03:21 AM   #13996
GSM Storm's Avatar
Trader Rating: 112 (100%+)
Originally Posted by FLATMAN View Post
HEY BUD
Had this problem yesterday try and unpluging it and plug it back in again!
with mine the red wire was off in the inside of the speedo,but fixed it and it was 100 again. hope u get it fixed
I have tryed it a few times, no luck, when it is pluged into the receiver the speedy works fine so I don,t think there is a loose wire.
Thanks for the input.
Regards
Gary
Driver Gazza
Offroad - RC10 B64 (soon)
Vintage - Kyosho Tomahawk
Fantom Racing, JConcepts, Ace Hobbies/Reedy,
WTF, Plaig Bearings.
GSM Storm is offline   Reply With Quote
Old 04-15-2010, 03:38 AM   #13997
Skitee's Avatar
What are you unplugging ? Are you unplugging the RS from the hotwire or are you unplugging the hotwire from the usb port ?
Xray T4 2018 ~ HobbyWing Xerun XR10 Pro ~ Motiv RC 4.5
Xray X12 2018 ~ ORCA Vritra VX3 1S ~ Speedzone 4.5
POWERED BY SPEEDZONE USA
Skitee is offline   Reply With Quote
Old 04-15-2010, 04:07 AM   #13998
FLATMAN's Avatar
so if u plug it back into the resever then the speedo is working fine? try giving the speedo a sqeez whith your fingers while the speedo is pluged in the hotwire and see if the middel red LED comes on?
FLATMAN is offline   Reply With Quote
Old 04-15-2010, 06:25 AM   #13999
20 SMOKE's Avatar
Trader Rating: 101 (100%+)
HEY BUD
good to hear you got it working
Jamie W
*Team Tekin*Tekno-rc*DE Racing*AKA*DDHRC*
20 SMOKE is offline   Reply With Quote
Old 04-15-2010, 06:27 AM   #14000
hijinx's Avatar
Trader Rating: 47 (100%+)
Default set up for a LRP X11 17.5
Hey there guys just wondering what is a good setup for a LRP X11 17.5 with the Tekin RS, the track i run on is out door asphalt with medium grip, some tight coners with a long very fast back straight if this helps.
Cheers
Sponsored by Yokomo Australia Team Hearns Hobbies, AKA Tires from Ryper Hobbies.Fantom batteries and motors. Hobbywing,Pro Amps servos,Wild Turbo Fans,TWT. Yokomo BMax2 Hobbywing Fantom Ion4 8.5t. Yokomo BMax4 III Hobbywing Fantom Ion4 6.5t. Yokomo BD7 2016 Hobbywing Fantom FR-1 4.5. S2H BODIES for all your custom RC paint jobs.
hijinx is offline   Reply With Quote
Old 04-15-2010, 06:45 AM   #14001
FLATMAN's Avatar
yip is work again.
thank for the help.
Old 04-15-2010, 07:08 AM   #14002
20 SMOKE's Avatar
Cheers
fdr 6
45 timing boost
10 turbo
delay 5
ramp 1
start 3xxx
end 14000
does the motor have adjustable timing? i run redlines
Jamie W
Old 04-15-2010, 08:57 AM   #14003
wstuart's Avatar
Trader Rating: 112 (98%+)
Send a message via AIM to wstuart
I just got my hotwire and set up my esc but now when I go to calibrate my radio it doesnt "see" my forward throttle position. It will see it though if I reverse my throttle in the radio, but then it doesnt sound like there is any turbo or boost
I have a 3pk
turbo 50
timing 12
ramp 3
delay .1
start rpm 1475
throttle profile 4
ive tried expanding the neutral position to 4
also tried turning my throttle epa in the radio down to 90%
Yokomo Yz-2 x2
Yokomo B-max4iii
Awesomatix a700 evo
Team El Cajon Hobbies
wstuart is offline   Reply With Quote
Old 04-15-2010, 09:30 AM   #14004
Trader Rating: 114 (100%+)
When is the iPhone app and hardware coming?
Chris Furman is offline   Reply With Quote
Old 04-15-2010, 09:35 AM   #14005
Krio's Avatar
Trader Rating: 150 (99%+)
I have a 3pk
turbo 50
timing 12
ramp 3
delay .1
start rpm 1475
throttle profile 4
With Futaba radios you need to swap the throttle channel to "reverse" if you haven't already.
www.kriostasis.com
Krio is offline   Reply With Quote
Old 04-15-2010, 10:16 AM   #14006
wstuart's Avatar
Thanks man - i thought that may have been it. Do you guys se anything in my settings above that would explain the lack of timing and boost when i run the car?
I have a 3pk
turbo 50
timing 12
ramp 3
delay .1
start rpm 1475
throttle profile 4
Yokomo Yz-2 x2
Yokomo B-max4iii
Awesomatix a700 evo
Old 04-15-2010, 10:56 AM   #14007
Default 21.5 ?
Can't find any 21.5 motor settings here, anyone have recommendations for the RS with a 21.5t? We're allowed to run this setup in VTA at our indoor carpet track, which has an approx. 80 ft. straight. What theoretical differences should there be with the settings vs. a lower turn (17.5) motor?
Gris is offline   Reply With Quote
Old 04-15-2010, 11:04 AM   #14008
20 SMOKE's Avatar
try the same but the end around 12000 and star 2xxx or 3-4xxx tjust play with it
Jamie W
Old 04-15-2010, 04:18 PM   #14009
Originally Posted by lupin_au View Post
OK I'm having kittens here.
Just took my car out for a lunch time blast. First real run.
Set my timer for 5 mins and all was well.
Pulled the car up to see how hot it was, felt hot but only had 2 lights on. Put it on the ground, it cogged, and the motor started squealing.
I don't think if its hit the battery cut off, as when I got back to the office, I disabled it and its still doing the same thing.
Also I can turn the motor freely by hand so I dont think anything is jammed.
Problem is I have nothing here to test it with, don't have another battery to try, but I'm hoping something hasn't failed.
Has anyone else had a similar problem and what was the outcome?
it sounds like the magnet on the stator shaft has exploded, my trinity nemisis 13.5 did the same thing after about 10 minutes of run time on my rs
ed
Edwin Pibal is offline   Reply With Quote
Old 04-15-2010, 04:24 PM   #14010
Wednesday evening try out the RS pro with 4.0t CS motor on the Heemstede track.
It was very powerfull and very quick also on the straigth.
Despite that som teamwave fellows talked about the RS PRO was melting
when you drive it mod 4.0t.
I must admit that the ESC temp light's indicate 2 or 3 leds the ESC worked fine and every lap the same trottle respons and big, very big punch all the way, this without a cooling fan the ESC did reach temps over 85degr C, with runtimes over 7 minutes and topspeed between 92 to 99 km/h.
This for me is the most powerfull ESC i've ever had.
Maybe is there somebody with a good set-up for mod.
I welcome any good suggestions.
Ed
eded1 is offline   Reply With Quote
Tekin Redline RS Sensored ESC and motors, opinions for offroad? Cain Electric Off-Road 4230 06-07-2015 04:38 PM
Sensored vs. Sensorless lemansracer Electric On-Road 71 02-14-2009 03:19 AM
New Tekin Redline Sensored Motors are Roar Legal! Randy_Pike Electric On-Road 3 08-05-2008 02:08 AM
Tekin Redline Sensored 10.5 HUCKMAN Electric On-Road 6 07-15-2008 08:50 PM
sensored vs sensorless bprocket Rookie Zone 5 05-16-2008 09:38 AM
Tags
v203, vegas 2.0
