Old 04-12-2010, 05:14 AM   #13936
cannon's Avatar
Trader Rating: 35 (100%+)
Originally Posted by LOSI123 View Post
Yes Cannon Sorry mate , you did give me the idea to try after i told you all the issues. thanks again I will edit the post to credit you
Dont edit .. it was an informative post
www.feralbatteries.com ........... new website
cannon is offline   Reply With Quote
Old 04-12-2010, 05:26 AM   #13937
marcel p's Avatar
Send a message via MSN to marcel p
Originally Posted by cannon View Post
Did you calibrate the throttle and brake at 90% and then move it up to 110%?
jup thanks
PR racing
Powerstar/futaba 4px
Absima /vr racing
marcel p is offline   Reply With Quote
Old 04-12-2010, 06:41 AM   #13938
Benzaah's Avatar
Trader Rating: 21 (96%+)
Hey all.
Im a bit confused regarding more speed from the Tekin. Im going pretty fast as is with help from Local tekin drivers but on the weekend i wanted to get a bit more speed and couldn't find it. My motor was coming off at 65c so I geared up but when i did so i lost punch down low which cost me time over 5 minutes. Im talking a jump from 7.6 fdr to 6.8 fdr I started with a 21tooth pinion and got faster up to a 24 tooth but a 25 and 26 were slower. It was suggested i try something like a 8.4 ratio to really get the speedy working more than the motor but i didn't. Sorry Ant
Will changing the start and end rpm help this issue?
What can i do to get the extra top speed the gearing brings without sacrificing bottom end grunt?
Cheers Benzaah.
Adelaide RC - XRAY Xb216de & Xb416
Walter Rc Hobby - Serpent 4X
Nosram - R1wurks - Sanwa - Hudy - Muchmore
Benzaah is offline   Reply With Quote
Old 04-12-2010, 06:52 AM   #13939
Had a meeting yesterday and was suprised that I was outpaced top and bottom end by the new GM 120 Speedo.
I was racing 10.5 and would get caught up on the straight (40m) and the GM had more rip out of the corners.
Any help would be grateful these are my settings :-
LRP X12 fully retarded (4 dot insert)
Boost 50
Turbo 15
T. Delay 0.1
Ramp Rate 2
Start RPM 5443
End RPM 20000
Throttle Profile 5
No Drag Brake
FDR 7.75
Temp after 5min run 160 F
It looks a really aggressive set up but had to be done to keep up. Incidently brakes were very poor. (On 100%)
Jamie
JamieV is offline   Reply With Quote
Old 04-12-2010, 07:47 AM   #13940
Originally Posted by marcel p View Post
jup thanks
Weird marcel , my brakes are amazing 100% in the tekin and 70% on my transmitter
are you working tommorrow ?? If not come to Real80 i will be there from 10 in the morning and we can try some things
sidecarphil1 is offline   Reply With Quote
Old 04-12-2010, 08:55 AM   #13941
marcel p's Avatar
tis is not helpful
as i said the brakes were great
stops with squeaking tires but not anymore
and no power anymore after 2 laps
a 19t element can keep up at straigt
PR racing
Absima /vr racing
Old 04-12-2010, 09:01 AM   #13942
marcel p's Avatar
Boost 50
Turbo 15
T. Delay 0.1
Ramp Rate 2
Start RPM 5443
End RPM 20000
Throttle Profile 5
No Drag Brake
FDR 7.75
Jamie
to much timing gives less power and top speed
dont go over 65deg
keep it between 60 an 65
PR racing
Absima /vr racing
Old 04-12-2010, 10:02 AM   #13943
Skiddins's Avatar
Boost 50
Turbo 15
T. Delay 0.1
Ramp Rate 2
Start RPM 5443
End RPM 20000
Throttle Profile 5
No Drag Brake
FDR 7.75
Jamie
Try 0deg insert on motor
40 timing
Putting the motor back to 'standard' timing might give you better results with the taller gearing.
If you want a bit more 'snap' you could try increasing the start rpm to 10,000rpm or so.
Skiddins
Xray T4'18, T4'14 (Wet Car)
Xray X12 2018
Xray X1'16
wlrc.co.uk (West London Racing Centre)
RCDisco.co.uk
Skiddins is offline   Reply With Quote
Old 04-12-2010, 10:23 AM   #13944
tis is not helpful
ok mate
thought we could maybe work through it
how hot have you had it ???
Old 04-12-2010, 12:03 PM   #13945
Questions?? help
hello
I need advice
I have to change my cables Tekin RS pro
which cables should I use?
I use 12 awg cables?
12 GA or cables?
are the same thing?
thanks
biagio23 is offline   Reply With Quote
Old 04-12-2010, 12:55 PM   #13946
Boost 50
Turbo 15
T. Delay 0.1
Ramp Rate 2
Start RPM 5443
End RPM 20000
Throttle Profile 5
No Drag Brake
FDR 7.75
Jamie
i think your motor makes way too much revs. revving up the motor takes a lot of energy too. thats what i experienced driving 10.5T indoors with a high gearing like 9.5. when i lowered it to about 6 it was way faster, also more punchy...
This is my setup for a Epic Nemesis 13.5T maybe comparable...
gearing: 6.0
motor timing: 15
boost: 45
start/end: 5500 / 20.000
turbo: max
turbo delay: 0.2
Turbo ramp: 3.0
brake strength:100 on esc, 65 op remote
Temps: 75C
When i wanted more start punch or infield punch i would add motor timing however this makes the motor too hot, but is very powerful!
gearing down gets the motor more in its designed power range. most of these spec motors just dont like to make this much revs.
with this setup i raced yesterday at our local club race, finished 3rd. 2 guys were running GM ESC's but i had more power in the infield as well as on the straight. however they wouldn't get their motor above 60C.
also brakes were so powerfull i had to put the remoteback to 65,to get a controllable stop.
GL
Mark
Markiempje is offline   Reply With Quote
Old 04-12-2010, 03:24 PM   #13947
msxmre's Avatar
Hi people i'm looking for some advice with the Tekin RS Pro for mod motors. I'm hearing conflicting stories as to how the set up goes, eg do we keep it set up sensored or do we set it up on dual. I've been running this speedo for 2 months and it is absolutely awesome in 10.5 and 13.5 but with our outdoor season starting i'll be running Mod 5.5t.
Thanks in advance for all your help with this and sorry if the questions trivial.
Scotty
Tamiya TRF 201, TRF 416,TEKIN RS PRO (the dogs) Novak Ballistic, LRP X12 Motors, Orion Motors and LIPO (they say it's the future mmmmm) www.falkirkrcc.co.uk/forums
msxmre is offline   Reply With Quote
Old 04-12-2010, 04:09 PM   #13948
Default 10.5 set up with LRP X!2
Hi guys - Thanks for your help.
If I go to the standard timing on the motor this is even more timing - Is this definitely what you mean? I understand about lowering the boost to 40
Basically the main advice is to reduce the timing by lowering the boost and gear from 7.75 to say 6.75?
Moving the Start RPM to say 10,000 will give more punch before the Boost kicks in ?
So have I understood your advice correctly?
Jamie
Old 04-12-2010, 06:09 PM   #13949
Skiddins's Avatar
Jamie
The x12's seem to have a lot of torque, so you should be able to use the gearing to get at that power.
I have found that if I wanted to calm the car down coming out of corners (particularly on cold tarmac) I reduced the start rpm.
I don't know how big your track is but in our 180deg corners the cars are still doing 14mph, which is something like 11,000rpm. The closer I started the rpm to this value the more aggressive it was out of the corners.
I wouldn't jump that far in the gearing in one go, try half that, say 7.25 and check temps.
It's finding that sweet spot that takes the time
Skiddins
Xray X12 2018
Xray X1'16
RCDisco.co.uk
Old 04-12-2010, 07:35 PM   #13950
Jamie
i'm running std timing on the motor
gearing 7.6
boost 40-45
start 9xxx, end 30xxx
turbo 10-15
delay 0.4
ramp 2
i never see below 8000rpm on the data logger even on hairpins
the X12 doesn't like to rev, it just gets hotter and hotter. i've tried running gearing all the way up to 9.5 but somehwere between 7-8 seems to be the sweet spot depending on the track. BTW even geared at 7.6 i see RPM around 55,000 on the data logger at 9.5 it's ummm to the moon! The car is almost as fast as my 4.5t motor just without the punch.
gameover is offline   Reply With Quote
Tekin Redline RS Sensored ESC and motors, opinions for offroad? Cain Electric Off-Road 4230 06-07-2015 04:38 PM
Sensored vs. Sensorless lemansracer Electric On-Road 71 02-14-2009 03:19 AM
New Tekin Redline Sensored Motors are Roar Legal! Randy_Pike Electric On-Road 3 08-05-2008 02:08 AM
Tekin Redline Sensored 10.5 HUCKMAN Electric On-Road 6 07-15-2008 08:50 PM
sensored vs sensorless bprocket Rookie Zone 5 05-16-2008 09:38 AM
Tags
v203, vegas 2.0
