Old 11-10-2008, 01:32 PM   #1381
Regional Moderator
CarbonJoe's Avatar
Originally Posted by rsperson View Post
Hmm - what do I use for a Spektrum cap - None of my receivers came with one
They were sealed packages - SPM1210 - Just got my new RS - need to hook it up.
http://www.amainhobbies.com/product_...oducts_id/6570
*** The Gate - Celebrating 8 years at the same location ***
The difference between genius and stupidity is that genius has its limits. - Albert Einstein
Understeer is when you hit the wall with the front of the car and oversteer is when you hit the wall with the rear of the car
CarbonJoe is offline   Reply With Quote
Old 11-10-2008, 04:27 PM   #1382
energyracing's Avatar
Hello everyone, I have just purchased a new RS and I must say the service from Tekin was excellent. I had a set up issue, the ESC would not detect throttle neutral, I called them up and in 2 minutes it was fixed.
Other companies would have asked me to send it back for inspection.
Thanks Tekin for a great product and great service.
George B.
[email protected]
Sponsored by Serpent / SRX2 MM, RM, SC / Serpent SRX4
MoFo paints
energyracing is offline   Reply With Quote
Old 11-10-2008, 04:47 PM   #1383
todd8603's Avatar
Come on Georgey...get it together would ya?
Seriously though, you are going to love that product. Don't forget I have the hotwire.
todd8603 is offline   Reply With Quote
Old 11-10-2008, 08:06 PM   #1384
AndrewNicholas's Avatar
Default Broken case :-(
Broken case :-(
I am going through my car for tomorrow nights club race and noticed that the case on my RS Pro is cracked.
Does Tekin sell the cases as a replacement part or will I have to send it in for repair?
It's my only speedo and I would rather not have to part with it for to long.
Andrew.
AndrewNicholas is offline   Reply With Quote
Old 11-10-2008, 08:12 PM   #1385
ChrisP's Avatar
You can contact Tekin directly to inquire at:
http://teamtekin.com/service.html
ChrisP is online now   Reply With Quote
Old 11-10-2008, 09:10 PM   #1386
kennyl, thanks for the great baseline rs setup for 17.5 12th scale, worked awesome, car was easily the fastest on all areas of the track(just wish the driver had been). but thanks again.
shaggy1 is offline   Reply With Quote
Old 11-10-2008, 09:20 PM   #1387
Krio's Avatar
Trader Rating: 150 (99%+)
Originally Posted by AndrewNicholas View Post
Broken case :-(
Andrew.
Earlier on this thread someone had a broken case...I believe tekin sold them one direct for like 7 bux.
www.kriostasis.com
Krio is offline   Reply With Quote
Old 11-10-2008, 11:08 PM   #1388
SammyZ's Avatar
Trader Rating: 138 (100%+)
Broken case :-(
Andrew.
I called them up, talked to Jim, total sweetheart They sent me a new case for $7 and it took me 5 minutes to do it.
SammyZ is offline   Reply With Quote
Old 11-11-2008, 05:14 PM   #1389
doriftu's Avatar
Originally Posted by Randy_Pike View Post
Guys with the Futaba radios. Try resetting your radio. Also make sure that you set your epas to equal amounts on throttle and brake.
Spectrum users running 1/12 with 4 cell or any other 4 cell car for that matter. Make sure to run the sepctrum cap on the reciever. The spectrum will drop out under accelearation long before the RS turns off. If we don't get a signal we kinda wait briefly on the receiver. This is where you can "feel" a delay or you can get a throttle shot.
I urge anyone using the Futaba radio to email me so we can work out your problems. [email protected] I can share this info with our engineers so we can get them documented.
Wires falling off an esc can be from excessive heat and or a bad connection to begin with. I strongly recomend makin sure that the wires have enough length to not be taught as simple fatigue of a joint can cause them to fall off as well. Posting some pictures of your wire/esc set up may let another set of eyes seem something yours do not.
Any cogging with the RS: Make sure that you use the sensor checker function on the esc. Roll the motor over with your finger and watch for the dimly lit led's. They will cycle between the three of them as the sensors are "seen." If you have an erratic sensor, or one missing completely that is your issue. Sensors in the motors can and do go bad but I've found more bad harness's than motors. Harness's are easy to swap out and are the first thing to check. Let's face it guys, any connection in an electronics system needs to be scrutenized.
Hi Randy,
What kind of issues encountered using Futaba radios? I am running 1/10 on Futaba 3pk with Spektrum.
Btw, any sponsored drivers using the RS in the World's? Would be interesting to keep an eye on
six-shifter.blogspot.com
supercharged-e36.blogspot.com
doriftu is offline   Reply With Quote
Old 11-15-2008, 08:19 PM   #1390
racing_jason's Avatar
was there a bad run of these ESC's? i have two one in my touring car and one that is in my twelth. the touring car does not go to full throtle. and the one that is in the twelth does not stay programed to the radio? are there any fixes?
Thank you to my sponsors-
Team Associated-Reedy-ProLine-B&B Hobbies Racing
racing_jason is offline   Reply With Quote
Old 11-15-2008, 11:00 PM   #1391
Team Tekin
Randy_Pike's Avatar
Send a message via Yahoo to Randy_Pike
Jason,
Make sure you don't have a stuck button on the esc, it happens on rare occasion.
When you're checking your esc for full throttle, do you get the entire led tree to light up and flash?
What radio/receiver are you using? I can help get you settled. [email protected]
"Things may come to those who wait, but only the things left by those who hustle." Abraham Lincoln
Tekin,Protek,A-Main Hobbies,JConcepts,Avid RC,Yokomo,MIP,SikLidz,FactoryRC, www.randypikerc.com
Randy_Pike is offline   Reply With Quote
Old 11-15-2008, 11:18 PM   #1392
Originally Posted by doriftu View Post
Hi Randy,
No issues at all using the RS Pro with my 3PK or PKS and Spektrum SR3000, SR3001 and SR3500 receivers. I also have a FX and FX-R Pro with no issues.
AreCee is offline   Reply With Quote
Old 11-16-2008, 12:01 AM   #1393
Trader Rating: 1 (60%+)
hi,,
tekin rs pro 3.5 turn suitable capacitors ?
cico is offline   Reply With Quote
Old 11-16-2008, 12:51 AM   #1394
mangoman's Avatar
I've used the Roche one on the R1 with 3.5
Part No.:ROC-R4SC - http://www.roche.hk/roche-products.htm
Or two of the standard tekin ones....
Hot Bodies Cyclone!!!
www.smaracing.org
www.rchobbies.com.au - www.feralbatteries.com.au
craig mcphee ( WHERE'S MY BEER )
mangoman is offline   Reply With Quote
Old 11-16-2008, 02:46 AM   #1395
thanks dude
Tekin Redline RS Sensored ESC and motors, opinions for offroad? Cain Electric Off-Road 4230 06-07-2015 04:38 PM
Sensored vs. Sensorless lemansracer Electric On-Road 71 02-14-2009 03:19 AM
New Tekin Redline Sensored Motors are Roar Legal! Randy_Pike Electric On-Road 3 08-05-2008 02:08 AM
Tekin Redline Sensored 10.5 HUCKMAN Electric On-Road 6 07-15-2008 08:50 PM
sensored vs sensorless bprocket Rookie Zone 5 05-16-2008 09:38 AM
Tags
v203, vegas 2.0
