Old 04-11-2010, 08:30 PM   #13921
clparsons123's Avatar
what motor were you using with these setups?
EAM (TEAM EA MOTORSPORTS),ORCA, RC AMERICA, XRAY,HUDY,EZ CUSTOMS, RSD (REFLEX RACING) , JEFFS RC STUDIO, RCTVLIVE
Cory parsons
clparsons123 is offline   Reply With Quote
Old 04-11-2010, 08:47 PM   #13922
Senna Racing's Avatar
I was using very close to your 17.5
set up this weekend
But I was running a lower fdr with good snap
try reducing your end piont 12000
and use a little more turbo
Originally Posted by 20 SMOKE;
i could be off alittle on my setting as i was working on 5-6 esc setups and was getting a little lost on what my own where
17.5 TC
fdr 6.5
motor 12
timing boost 52
turbo 7
delay .4
ramp 2
start 3xxx
end TC
fdr 6.5
motor 15
timing boost 50
turbo 7
ramp 2
start 4xxx
end needs a little bottom snap and try gearing ran in the main worked as good second setup with more straightaway speed
fdr 6.5
motor 18
timing boost 50
turbo 10
start 5xxx
end 16500
all with 0.4 delay
fdr 37/87 full BSR tire (62.xx roll out i think)
motor 12
timing boost 50
start 3xxx
end 8000
turbo 6
delay .4
ramp 2
moderate to low temp i only got to run for practice i had issue's and ran TC but it was very fast
Feral Batteries for all your on road needs
TRF 416, Fantom Batteries, Sorex, Tekin
Senna Racing is offline   Reply With Quote
Old 04-11-2010, 09:00 PM   #13923
Also some great results for tekin downunder
in the first round of our challange cup
Wirh tekin taken out at least the first
3 places in 21.5 , all 10 places in 17.5 and
second in 10.5
Old 04-11-2010, 09:09 PM   #13924
Pablo Diablo's Avatar
Send a message via Skype™ to Pablo Diablo
second in 10.5
What ESC took the win in 10.5?
Paul H
Losi Type R | Xray T3 | CRC Gen XL | CRC Gen X 10 ME(Messiah Edition) | Black Diamond
www.FlyingFoxRC.com | Advanced Electronics | Team CRC | Factory Messiah
Pablo Diablo is offline   Reply With Quote
Old 04-11-2010, 10:50 PM   #13925
just drove my rc12r5 with RSpro and sensored 2.5 in dual mode and on 2s lipo at the local "nitro" on-road track. OMG NERDGASM. was geared 96-16 with some worn out wheels that were about 40mm diameter. the 200ft straight was like a squirt. just one yank and let off. had my eagletree in it. rpm sensor didnt work but i got 93 amps peak. using a 7.4v 20c 3100 maxamps pack i tickled 6v a few times. lowest was 5.88v. this was in the top half of the battery. according to the eagle tree i only took 1300mah out in the 6min run. will dbl check tomorow by draining the battery. but my driving is awful so i wasnt pushing the car. i saw the speedo blink 5 lights of temp. lost my radar gun or i would tell you what top speed i got.
if my driving was better i could have given the O.S. team driver from japan a run for his money that was practicing for the 200mm worlds coming in july.
benben10 is offline   Reply With Quote
Old 04-11-2010, 11:52 PM   #13926
pakk's Avatar
Trader Rating: 79 (100%+)
You put a 2s pack in a 12r5?
*Photon* *SC10 4x4*
RCRD
pakk is offline   Reply With Quote
Old 04-12-2010, 12:38 AM   #13927
its a soft case
just barely clears the locknut under the shock
http://www.maxamps.com/Lipo-3100-74-Pack.htm
Old 04-12-2010, 01:18 AM   #13928
wstuart's Avatar
Trader Rating: 112 (98%+)
Send a message via AIM to wstuart
Anybody know where I can find a good setup for Duo2 17.5 (ver. 203)
Yokomo Yz-2 x2
Yokomo B-max4iii
Awesomatix a700 evo
Team El Cajon Hobbies
wstuart is offline   Reply With Quote
Old 04-12-2010, 03:15 AM   #13929
FLATMAN's Avatar
[QUOTE=20 SMOKE;7250238]it is not installing properly,some one just had this problem and was posting on tekin forum.watch the video it should help and it is for the vista but should help
Hey 20 smoke thanks for the help my notebook is sorted!
thanks bud
FLATMAN is offline   Reply With Quote
Old 04-12-2010, 04:56 AM   #13930
marcel p's Avatar
Send a message via MSN to marcel p
hello
need som help with my tekin rs
it ran great al winter indoor season.
my first outdoor on a big outdoor track was the first 2 quaifiers good
with plenty of brakes.
dith a bit of fine tuning with the boost and turbo.
and my next run i had almost no brakes anymore
went back to my old setings stil no brakes.
now a weekend later tryed almost evryting .
also compleet update and reprograming speedo and transmitter.
now i also have that my power is gone after 2 laps
can somone give some tips
ps already placed a new motor .also a sp 3.0 13,5t
PR racing
Powerstar/futaba 4px
Absima /vr racing
marcel p is offline   Reply With Quote
Old 04-12-2010, 04:57 AM   #13931
20 SMOKE's Avatar
Trader Rating: 101 (100%+)
redline and duo 2
set up this weekend
tried it and dont need more turbo
Jamie W
*Team Tekin*Tekno-rc*DE Racing*AKA*DDHRC*
20 SMOKE is offline   Reply With Quote
Old 04-12-2010, 04:58 AM   #13932
LOSI123's Avatar
Trader Rating: 63 (100%+)
Default Trinity Nemesis 17.5 & RS Pro
Just thought id post my findings with the Nemesis 17.5 in TC.
After spending about 2 days trying to figure out, It getting hot after only a couple of minutes (luckly i checked it at every minute or the motor would be toasted).
It also would jerk on and off at full throtle very Violent after only 1 or 2 mins.
which was very bad and concerning to me
With these settings it was faullting
Motor- 0 to 10 didnt matter always faulted
Boost- 50
turbo - 8 or 10 didnt matter
delay- didnt matter what i set it to
FDR - 6.5 to 7.2 didnt matter still faulted.
Start - 5XXX
End - 15000
Throtle- 3
Ramp- 2.0
Drag - 0
I was shocked that it got hot so quik and started to jerk and fail on /off at full throtle.
I tryed every posible thing and setting and new cables, batterys radio , virtually every thing, to no avail.
Tried Tekin motor on same everything and it went perfect.
Since Trinitys warranty is virtually non existing and i only had the motor 2 days and it did this fault from the first time out I was persistent not to give up on solving it.
I put the motor to -5 deg and all problems went away (Fixed!!! ), well i havnt raced it yet, but i put a full pack through the car, and it went fast and never got above 54C temp and it also sounded fast as well as going fast
I have come to my own conclusion that the markings on the Nemesis Can are very very wrong, worse than any other motor i have used.
I am geussing that -5 on motor is most likely +10 or more???
I hope others can maybe use this info to not cook motor straigh away or just use it as a door stop.
Many people in this forum seem to have totally hated this motor, maybe this is the problem????
Credit Given to Greg (Cannon) for pointing me in the right direction in regards to motor timing. & my spellings bad, I know
Cheers
LOSI123 is offline   Reply With Quote
Old 04-12-2010, 05:03 AM   #13933
cannon's Avatar
Trader Rating: 35 (100%+)
Originally Posted by marcel p View Post
hello
Did you calibrate the throttle and brake at 90% and then move it up to 110%?
www.feralbatteries.com ........... new website
cannon is offline   Reply With Quote
Old 04-12-2010, 05:06 AM   #13934
cannon's Avatar
Boost- 50
turbo - 8
Start - 5XXX
End - 15000
Throtle- 3
Ramp- 2.0
Drag - 0
Since Trinitys warranty is virtually non existing and i had only had the motor 2 days and it did this fault from the first time out I was persistent not to give up on solving it.
I am geussing that -5 on motor is most likely +5 or +10 or 0 approx
Cheers
Good solution. I wonder where the idea came from
Old 04-12-2010, 05:12 AM   #13935
LOSI123's Avatar
Yes Cannon Sorry mate , you did give me the idea to try after i told you all the issues. thanks again I will edit the post to credit you
Tekin Redline RS Sensored ESC and motors, opinions for offroad? Cain Electric Off-Road 4230 06-07-2015 04:38 PM
Sensored vs. Sensorless lemansracer Electric On-Road 71 02-14-2009 03:19 AM
New Tekin Redline Sensored Motors are Roar Legal! Randy_Pike Electric On-Road 3 08-05-2008 02:08 AM
Tekin Redline Sensored 10.5 HUCKMAN Electric On-Road 6 07-15-2008 08:50 PM
sensored vs sensorless bprocket Rookie Zone 5 05-16-2008 09:38 AM
Tags
v203, vegas 2.0
