Old 04-07-2010, 08:17 AM   #13846
Yokomo_Ant3's Avatar
Trader Rating: 29 (100%+)
Originally Posted by hacker View Post
believe it or not with my setup, which is nearly the same as above, if I go from 6.0 fdr to 6.6 or higher, my motor gets hotter. Its strange cos normally when your undergeared(high fdr), usually the speedy gets hot and motor gets cooler. Not with the current generation of speedies and software however.
I would drop back on 3-4 on timing & turbo.
We were using the exact setup with duo 1, 10 degrees of motor timing geared at 8.2. Was a rocket and came off at 70d c With a motor fan/heatsink on though.
The red car who wins this race has those settings on
http://www.youtube.com/watch?v=T34mM...eature=related
Just listen to the thing!
Antoni Caretti
Team Yokomo - Racing Performer - Sweep Racing
Yokomo_Ant3 is offline   Reply With Quote
Old 04-07-2010, 08:35 AM   #13847
Originally Posted by bee200sx View Post
Hey guys had a run with the V203 software tonite.
Ran the following:
Xray T3
Tekin RS
Tekin 17.5 with zero timing
FDR: 6.8
Boost: 50
Turbo: 10
End RPM: 7000
Start RPM: 2474
Ramp: 3.0
Delay: 0.4
Drag Brake: 10
Track: roughly 20meters x 60meters, medium traction
The car felt fast but not as fast as others running Black Diamond and tekins. Can someone please give me advice with regards to my setup? The car seems a bit slow coming out of corners and it seems to take a bit of time to reach top speed, it will reach top speed just before I enter a corner so basically by the time it reaches top speed I have to throttle off to go round the corner. It's flowing track so I don't use my brakes, instead I depend on my drag brake to slow me down. Or if I take the drag brake off I usually just roll through the corners. Any help would be appreciated guys.
Also when I first ran the car my initial setup was 5.63 FDR and 12 degree timing on the motor, but it temped at 105C, thought I blew the motor but when it cooled down everything was fine again, hope I didn't do any damage. So then I ran the above setup and final temp was around 75-80C.
Thanks in advance.
i would leave the 12 deg on the motor, this makes it fast on the low speeds!
then like the others said, increase your gearing a little. maybe also increase the end rpm like to 15k.
Markiempje is offline   Reply With Quote
Old 04-07-2010, 10:29 AM   #13848
Senna Racing's Avatar
move your start rpm up
Feral Batteries for all your on road needs
TRF 416, Fantom Batteries, Sorex, Tekin
Senna Racing is offline   Reply With Quote
Old 04-07-2010, 10:40 AM   #13849
Would anybody have a good setup for a lrp x-12 17.5 with tekin rs v203? I am geared at 100t spur , 30t pinion. I will be running outside the track is medium sized with a medium backstraight. The track is fast flowing with little to no slow sections. I have my timing boost set to 50 and the turbo boost set to 10. 0 drag brake, throttle profile 3, brake 90, .0 delay? Help me out if you can.
HoboShop is offline   Reply With Quote
Old 04-07-2010, 11:07 AM   #13850
How much longer do you think the RS/ RS Pro will be able to stay on top of the game? This speedo is 2 years old, How long will reprogramming it last until its internals need to be upgraded? I want to buy an RS Pro but I have a feeling not too long from now a new model will be released..
Double D Donuts is offline   Reply With Quote
Old 04-07-2010, 12:28 PM   #13851
Default Novak Ballistic 10.5
Has any one run a Novak Ballistic 10.5 on tarmac with rubber tyres. I need gearing and setup advise for a really big track with a long straight. Im using an Xray T2 009.
XRAY T4 Hobbywing V3 Sanwa
FLAT OUT is offline   Reply With Quote
Old 04-07-2010, 01:18 PM   #13852
Hello,
My RPM (data logger) are between 10000 and 22000, exept the straight until 34000 on an outdoor asphalt track. How do I set my start and end rpm ? Software is V203. Itīs for an LRP 10.5T motor. Someone a good setup ?
All info welcome.
Tia.
evolution1 is offline   Reply With Quote
Old 04-07-2010, 04:00 PM   #13853
Company Representative
SweepRacingUSA's Avatar
Default RPM calculator
I wrote this tool some time when V203 came out, then I stopped using cause I can't set my mind up between this calculation and data logger's reading.
I dont have a time to experience any more, maybe I will never get a chance to enter a final value for MIN, MAX RPMs, so it is a unfinished formula but it could give you a basic idea what your motor does on your car, or somebody else can come finished for us.
default value was for RCmadness carpet track with Duo2/10deg timing.
good luck!
File Type: zip rpm tool for tekin by sweepracingusa dot com.zip (46.7 KB, 141 views)
SweepRacingUSA is offline   Reply With Quote
Old 04-07-2010, 06:16 PM   #13854
LOSI123's Avatar
Trader Rating: 63 (100%+)
Originally Posted by LOSI123 View Post
Has anyone had any issues with the bec 3amp rating that gives power to rx & servo for steering?
I got a new steering servo
http://www.horizonhobby.com/Products...odID=SPMSH6040
when i steer left to right (a bit fast) it makes my spektrum bind light go out & loose bind for a second or 2,every time. With different brand & model servo it does not do it
I have unpluged the rs pro and just give my sr3000 rx power with a battery pack and problem is solved.
I have also tried running a novak glitch buster cap on rx and it helps but still cuts out. just not as badly.
i have no fans or tranponders pluged at all, & i know this new servo is going to be power hungry but i didnt think it would need more than 3 amp bec?????
Its with 2s li-po.
Anyway I went and got a new & larger Cap 3300uf 16V for the RX, and this fixed it!
Its posible that maybe something was wrong with my other cap.
LOSI123 is offline   Reply With Quote
Old 04-07-2010, 06:18 PM   #13855
Any one ....
Old 04-08-2010, 05:38 AM   #13856
Can someone respond to my? This is why I mainly run 10 scale and 8 scale onroad nitro. Every year they are changeing the classes and rules to cater to the cry babbies last time I checked this is still racing if you can't keep up or afford a certain class move down to a slower one or just quit all together electric racers remind me of the whiny low talent female Indy racer see hasn't won anything yet but see gets more attention then the guys who finished on the podium
Old 04-08-2010, 05:51 AM   #13857
Did you check the set-up sheets on the Tekin site, i am shore they have one for you
eded1 is offline   Reply With Quote
Old 04-08-2010, 06:00 AM   #13858
hacker's Avatar
Trader Rating: 141 (100%+)
who's the cry baby now?
hacker is offline   Reply With Quote
Old 04-08-2010, 06:02 AM   #13859
Regional Moderator
CarbonJoe's Avatar
Run the 4 dot timing insert in the motor. Start RPM 2500, End RPM 9000. Shoot for a rollout around 3.2 inches. Run a couple of minutes and check your temps, then gear accordingly. The X-12 tends to run hot. In 17.5 foam TC on carpet, it ran quite well at around 200 degrees F.
*** The Gate - Celebrating 8 years at the same location ***
The difference between genius and stupidity is that genius has its limits. - Albert Einstein
Understeer is when you hit the wall with the front of the car and oversteer is when you hit the wall with the rear of the car
CarbonJoe is offline   Reply With Quote
Old 04-08-2010, 08:34 AM   #13860
Not all electro drivers are like your statement , and with comments like that there is no wonder no one helped you , there is a set up on tekins site that uses 0 turbo delay on a 17.5 motor maybe this is a bit differant to yours !!!
sidecarphil1 is offline   Reply With Quote
Tekin Redline RS Sensored ESC and motors, opinions for offroad? Cain Electric Off-Road 4230 06-07-2015 04:38 PM
Sensored vs. Sensorless lemansracer Electric On-Road 71 02-14-2009 03:19 AM
New Tekin Redline Sensored Motors are Roar Legal! Randy_Pike Electric On-Road 3 08-05-2008 02:08 AM
Tekin Redline Sensored 10.5 HUCKMAN Electric On-Road 6 07-15-2008 08:50 PM
sensored vs sensorless bprocket Rookie Zone 5 05-16-2008 09:38 AM
Tags
v203, vegas 2.0
