Tekin RS ESC sensored >
Old 04-06-2010, 12:56 AM
  #13801
mjc168's Avatar
Trader Rating: 25 (100%+)
Originally Posted by Akudou View Post
Am goin to try my tekin rs pro on my 1/10 buggy offroad. Can anyone give me a basic setup setiing and firmware for my 5.5t sensorless motor and also recommended fdr please? i only have 3 hrs to setup before i try it out. Thank you to those who reply swiftly.
I think using a sensorless motor should easy to setting up. due to you can only use dual mode and timing boost only. the rest start rpm, end rpm, turbo and turbo ramp is not applicable to this mode. correct me, if i am wrong.
mjc168 is offline
Old 04-06-2010, 02:06 AM
  #13802
Akudou's Avatar
Stil have finding the right setting. plan to use 11.5t sensor to practise first. cant seem to find the right setting for 5.5t sensorless
Akudou is offline
Old 04-06-2010, 03:11 AM
  #13803
eded1 is offline
Old 04-06-2010, 03:28 AM
  #13804
Benzaah's Avatar
Trader Rating: 24 (96%+)
Originally Posted by Markiempje View Post
I have a little problem when releasing the throttle at high speed. It seems that the car would decelerate very quickly when just releasing the throttle, and only at high speeds. No drag-brake or push control is set.
When i added 10 push control this feeling went away. I think its because all the timing gets dumped fast from the motor when you release the throttle and the high gearing we run it pulls up un-naturally. Zero delay also helps so that when you do get right back on the gas it comes on strong straight away.
You also have 80 degrees of timing which is too much. Back of 10 degrees on either motor, boost or turbo and your temp issues should go away.
Benzaah is offline
Old 04-06-2010, 03:30 AM
  #13805
Originally Posted by eded1 View Post
You dont know how slow I am.
I do like it to see times and to compaire++
Thanks for your transponder no.
what is your transponder nummer i will see what your times are
whats your fastest time on MACH ??
sidecarphil1 is offline
Old 04-06-2010, 03:37 AM
  #13806
eded1 is offline
Old 04-06-2010, 03:46 AM
  #13807
eded1 is offline
Old 04-06-2010, 05:33 AM
  #13808
Joep's Avatar
......little correction the fastest time was 17.04(Bart W).....
Correct Ed. Peter Meurs did the same laptime. Peter had Pole.
One more correction. The highest speed was 91 km/h.
Mine was 90.5 km/h and my best laptime was 17.9 sec (4th in B-final).
The setup used by me and also most of the A en B final drivers with a Tekin and SP 3.0 was:
Drag brake: 0
Brake strength: 100
Neutral width: 10
Throttle profile: 3 to 5 (5 for me)
Timing Boost: Max
Turbo Boost: 12 to 14 (12 for me)
Turbo Delay: 0,4
Turbo Ramp: 2
Start RPM: 8500
End RPM: 20000
And 10 degrees timing on the motor. But not to the outer edge otherwise the wires can get damaged by the sensor connector
Without cooling my motor didn’t exceed 70 degrees C (outside temp was 12 degrees C). With cooling it didn’t ran hotter than 45 degrees C. The real thing that matters is how hot the rotor and windings get. But I don’t have data on that.
I think the wiring in the motor is the problem. These are a few facts:
-All three the fields are created by a random bunch of wires. Which are loose near the connectors. I’m sure they move.
-The wires are (to) thin.
-The wires are bad insulated.
Add some heat and some sudden movement and the cause of build of heat in one specific place is there.
Add to that, that we are running 7 minutes and disaster strikes randomly.
Hand wound motors and maybe a little thicker wires would help.
Just my 2 cents.
Joep is offline
Old 04-06-2010, 06:10 AM
  #13809
Can someone tell what pinion I would need to par with a 100t spur gear to get a fdr of 4.1000 on my x-12 17.5. Also what I'd the max timing boost and turbo boost that can be used with the x-12 17.5 without blowing it up?
HoboShop is offline
Old 04-06-2010, 06:27 AM
  #13810
eded1 is offline
Old 04-06-2010, 09:09 AM
  #13811
Akudou's Avatar
Default Reallly need help please
been trying lots of setting for our local buggy track. Can anyone share some simple setting like which firmware, push, boost, drag brake, fdr etc.. and even the advance option. Am running a 1/10 buggy with a igr of 2.39 with an rs pro and sensoreless ezrun 5.5T 6000kv. Anyone who can guide me will be a big help for me as the rs pro is taking more time to set than just simoke push button in the lrp. But i still love my tekin rs pro and thats why i need the settings real bad. Thanks in advance for anyone who can help me ouit.
The following url is the our offroad track here.
http://www.rctech.net/forum/brunei-r...oad-track.html
Akudou is offline
Old 04-06-2010, 09:28 AM
  #13812
dameetz's Avatar
Just a suggestion jeng.........Maybe you can try post at the Electric offroad thread, I m sure many of them are using RS Pro for their buggies....manatau ada luck dapat answers d sana...
dameetz is offline
Old 04-06-2010, 10:05 AM
  #13813
Joep's Avatar
And for your notice the brushless motors are all hand wounded but not that carefully as needed to prevent motor coocking.
Hand wounded??? Haha. They throw a bunch of wires in the direction of the motor and then close it And that concerns ALL brands of motors.
Joep is offline
Old 04-06-2010, 10:16 AM
  #13814
what gearing were you running Joep ???
your car was quick at the weekend
think i need some more training time at MACH , see if i can launch my T3 higher
Old 04-06-2010, 10:29 AM
  #13815
Joep's Avatar
I ran the qualifiers and the first final with 5.0 and the last two finals I went up a little to 5.5 to get a little more punch in the infield. I lost some topspeed with that. (89 km/h) and I gained in laptime
Joep is offline
