Old 04-05-2010, 12:28 PM   #13786
bigbank66's Avatar
FELLAS IM RUNNING A RS WIT A NOVAK BALLISTIC 17.5....AN ITS JUST THAT...CRAZY FAST...WILL A RS TAKE A 5.5??? IM RUNNING A TOPS PHOTON..ALL STOCK..100 GEAR SPUR..WOULD LIKE TO KNOW WHAT PINION TO RUN AN THE BEST PROFILE TO HAVE???? THANKS
bigbank66 is offline   Reply With Quote
Old 04-05-2010, 12:55 PM   #13787
RC MARKET's Avatar
I'm think this is no.1 topic ?
920 page.
RC MARKET is offline   Reply With Quote
Old 04-05-2010, 01:15 PM   #13788
YmeBP's Avatar
Trader Rating: 32 (100%+)
check your caps lock
Yes it will work w/ a 5.5, BUT i would strongly suggest you put 2 tekin caps on it and have a fan blowing on the posts as a just in case.
www.skyrocketracing.com quality RC gear!
http://www.rctech.net/forum/racing-forum/555071-2011-skyrocket-invitational-blue-diamond-raceway-october-15-16-a.html <- Great race!
YmeBP is offline   Reply With Quote
Old 04-05-2010, 01:23 PM   #13789
YmeBP's Avatar
Originally Posted by blanks596 View Post
thank you. Hobby people has a 35c 5000mah battery right now for $69. would you consider this not for bashing, but for racing?
I race w/ a 25c Fantom 5400.
Old 04-05-2010, 01:34 PM   #13790
oeoeo327's Avatar
Trader Rating: 74 (100%+)
While the extra capacitor and a fan cooling the posts isn't a bad idea, if you plan on using a 5.5 in a TC chassis I'd look into upgrading to an RS Pro. Touring cars will draw a lot of current when used with low turn motors, and might cause the ESC to fail prematurely due to the high current demand.
Founding member of the Solid Gold Racing Team - Mediocrity, redefined...
oeoeo327 is offline   Reply With Quote
Old 04-05-2010, 01:46 PM   #13791
i was racing at MACH heemstede today with my Tekin RS and Tekin 13.5
i had a top speed of 81.6 kph
this was my settings
Timing MAX
Turbo 12
Turbo delay 0.0
Throttle profile 5
Start revs 4xxx
End revs 10,xxx
Motor end bell timing 4 degrees
gearing of 6.44
fastest lap of 18.477
straight was around 80m long with a balls out fast as you like sweeper onto the straight
the top speeds of the day was 90kph and a best lap off 17.4 , the other guys were running the SP 13.5 v3 motors and i watched 5 of them cook today , they were about 60 degrees C and all stopped in smoke and smelling but not hot , weird !!!! all on Tekin RS speedos too
my motor didnt get above 70 degrees C although i had good punch out of the corners i missed a little top speed but over i was happy with my 1st visit to the MACH , difficult track with some HEAVY braking zones !!!
Good day , Thanks guys
sidecarphil1 is offline   Reply With Quote
Old 04-05-2010, 01:51 PM   #13792
Hi, anyone got suggestions for my setup? I have a little problem when releasing the throttle at high speed. It seems that the car would decellerate very quickly when just releasing the throttle, and only at high speeds. No drag-brake or push control is set. lowering the gearing 3 pinions helped a bit but now im coping with high temperatures, 90degree C. I want the car to roll like a brushless motor can do. At low speeds there is no problem.
here is my setup:
Boost: Max
Turbo: 15
Turbo Ramp: 2
Turbo lag: 0.2
Motor Timing: 15
FDR: 5.87
Boost start: 5447
Boost end: 20068
motor temp: +-90
track: 160ft straight and flowing technical sections.
thanks
Markiempje is offline   Reply With Quote
Old 04-05-2010, 02:02 PM   #13793
Tubaboy's Avatar
I would check for mechanical issues first since you are noticing it at high speeds. Check the bearings, diff smoothness etc. Make sure the belts aren't to tight, etc.
www.wyomingrc.com | www.wyomingmodelerspark.com
Tubaboy is offline   Reply With Quote
Old 04-05-2010, 02:15 PM   #13794
razzor's Avatar
Timing MAX
Turbo 12
Turbo delay 0.0
Throttle profile 5
Start revs 4xxx
End revs 10,xxx
gearing of 6.44
most likely from being overtimed.
Have experienced this with out the motors getting hot.
would be great if there was a way to check max timing to prevent this.
Casterracing ZX1.5R
casterracing EX-1 Pro, SP Silver Arrow
TOP Racing Scythe, SP 17.5, SP GT Pro 2.0
TOP Racing Scythe, SP 4.5 V2, Hobbywing Xerun 120SD 2.0
TOP Racing Scythe, SP 13.5, Hobbywing Xerun 120SD 2.0
razzor is offline   Reply With Quote
Old 04-05-2010, 02:22 PM   #13795
Timing MAX
Turbo 12
Turbo delay 0.0
Throttle profile 5
Start revs 4xxx
End revs 10,xxx
gearing of 6.44
i would try spreading the boost to a wider band, like to 20k rpm. this gave me a more linear acceleration. i also found that using a little turbo delay somehow you get more acceleration in the infield, i assume i dont full throttle in the technical sections but apparently i do. i gues this would keep your motor cooler. Also increasing the motor timing gives a Lot more punch and topspeed as well, give it a try!
Mark
Old 04-05-2010, 02:34 PM   #13796
2wdrive's Avatar
Do you know the setups of those that had damaged motors? Would be interessting as i drive there as well .
Did they use the 0 delay turbo with high start rpm's or did they use the delay on the straight?
Timing MAX
Turbo 12
Turbo delay 0.0
Throttle profile 5
Start revs 4xxx
End revs 10,xxx
gearing of 6.44
2wdrive is offline   Reply With Quote
Old 04-05-2010, 03:30 PM   #13797
One of the guys was defenatly running 0 turbo delay and i think Eric was too
i heard that the V3 is ok but they were all adding 10 degrees motor timing on the end bell the marcels motor stopped , strange really because it wasn't hot
My only major car problem today was a little lack of top speed this i will experement with and try higher start and end revs , overall a good day for me and i think i get a trophey for the biggest air of the day , if xray start to make airplanes i think they need to call it the T3 phil edition
Old 04-05-2010, 03:34 PM   #13798
eded1 is offline   Reply With Quote
Old 04-05-2010, 11:35 PM   #13799
Originally Posted by eded1 View Post
Hi, SidecarPhil.
Nice speed you have, little correction the fastest time was 17.04(Bart W) I gues, btw wat is your transponder nummer then i can watch your times.
If you want this not public you can send me by mail.
I have to do off-road today otherwise a raced today at Heemstede.
Pitty that I not have been there, I draie 17 April zac see you there maybe.
Ed IJzerman
Transponder 4105098
no problems with people seeing my times i have nothing to hide i know i am slow !!!
I want to try
some differant settings in my speedo , think i will start and end revs higher and try that ,
i will never keep up with bart w but a bit more speed would be nice
Old 04-06-2010, 12:39 AM   #13800
Akudou's Avatar
Default need help on setup for 5.5t offroad 1/10 buggy
Am goin to try my tekin rs pro on my 1/10 buggy offroad. Can anyone give me a basic setup setiing and firmware for my 5.5t sensorless motor and also recommended fdr please? i only have 3 hrs to setup before i try it out. Thank you to those who reply swiftly.
Akudou is offline   Reply With Quote
Tekin Redline RS Sensored ESC and motors, opinions for offroad? Cain Electric Off-Road 4230 06-07-2015 04:38 PM
Sensored vs. Sensorless lemansracer Electric On-Road 71 02-14-2009 03:19 AM
New Tekin Redline Sensored Motors are Roar Legal! Randy_Pike Electric On-Road 3 08-05-2008 02:08 AM
Tekin Redline Sensored 10.5 HUCKMAN Electric On-Road 6 07-15-2008 08:50 PM
sensored vs sensorless bprocket Rookie Zone 5 05-16-2008 09:38 AM
Tags
v203, vegas 2.0
