Tekin RS ESC sensored
LIPO with TEkin Rs
Could someone point in the right direction for LIPO's with the tekin rs 13.5 setup? I'm running sedan (TC5) w/fdr around 7. My track is a good size maybe 120ft straight or so. I don't want to buy the most expensive LIPO if it's overkill and I'm fairly new to LIPO's and don't want to make a foolish buy
Is 40c 5000 enough. I'm don't understand the numbers all that well but isn't the battery supposed to be enough to cover the max burst power. I think max burst is 312amps for the TEkin rs so this battery would only cover 200amps- sorry if this sounds dumb, but i'm very confused I was told that your battery needs to be able to cover this max burst power thing
That being said...You are looking for 7.4V packs with discharge rating of 28C/40C/50C. For TC, I would suggest at least 5000 mahr packs. You may experience some power drop off with packs with only 4000 mahr. I use high end ThunderPower and SMC lipos depending on which has the better numbers at the time of purchase. According to some very fast drivers in NorCal...A-Main Hobbies has less costly packs sold under the name of Pro-Tek that seem to perform very well.
Hope that you have a lipo-capable charger because that is a fairly big issue too.
THIS TOPIC REALLY DOESN'T BELONG ON THIS THREAD...MY BAD.
Bill
thank you. Hobby people has a 35c 5000mah battery right now for $69. would you consider this not for bashing, but for racing?
So........ when is the next update? GUI update that is.
Thanks for replys, Mikky, Randy and Jamming, i have 2 caps in ESC, and another 1 in receiver, (Tekin cap), The fan in solder to battery directly in the posts of esc, my system are Sanwa M11 (not X) and the receiver are RX-441DS, never have any problem similar to this.
The saturday, day before to race, i dont have any problem, and in the tests in my track, only sunday in the 2nd heat and in the rest of race.
My batteries are news Nosram 5900 50C, and the voltage are 7.3-7.5 at final of heats.
Greetings, Luis C.
PS: Well, with the problem i can clasiffy to A final, i finish 10, with only 4 minutes race in heats, very fast setup.
Greetings, Luis C.
1 of them is just to much power and I changed back to my favorite setup.
I tried 3 setups.
This is the one that makes your car still drivable.
Boost max
Turbo 5
Turbo delay 0,4
Turbo ramp 2
Throttle 5
Start RPM 8000
End RPM 20000
Gearing 6,7FDR
Motor timing 10
The car accelerates very good.
I tried also 3600-7000 RPM but this was slower.
The car accelerated a bit slower. I think with the timing on the motor on max, that this was to much ad once.
Than I changed to this.
Boost max
Turbo 10
Turbo delay 0
Turbo ramp 2
Throttle 5
Start RPM 8000
End RPM 20000
Motor timing max
Gearing 6,7FDR
This was way to much power.
The car was like a rocked. I didn't came of the spot. I pulled black lines thanks to wheel spin. 2 meter long stripes and than I got of the Throttle.
This was incredible fast but hard to drive.
I field that with a higher start RPM that the car accelerated better even without the Turbo.
Greetings, Luis C.
Greetings, Luis C.
Greetings, Luis C.
which motor to get
hi guys.
what would be the best 13.5 motor to run with the rs ? reading through the 800 odd pages the popular choice seems to be the sp v3 or the x12
ive been told the tekin likes motors that can sit at 0's but reading i see the x12 timing is set at 40's
Ed
Ed
which 13.5 to buy
opps.. double post sorry
