Tekin RS ESC sensored >
Old 03-31-2010, 03:15 AM
  #13696
B4james's Avatar
Originally Posted by FLATMAN View Post
THANKS BUD!!
A lot of hours went into that paintjob, I'm almost too scared to run it lol
B4james is offline
Old 03-31-2010, 03:39 AM
  #13697
Default info
hello, currently use rs Tekin Motor Tekin Redline 10.5, but I wanted to try some other engine.
I thought the nemesis 10.5
give me some advice?
biagio23 is offline
Old 03-31-2010, 04:26 AM
  #13698
Originally Posted by s13evo View Post
ran my brand new Tekin RS/17.5 combo today in my TRF416 and i cant get a good gearing on it.
Ive used so far final gear ratio of 7.10, 6.56, and 4.8 and they all reach the same 230 degrees on the motor. why is my motor getting so hot after a 3 minute run. do i need to run maybe a 8.00-9.00 on the 17.5 or the opposite or is my motor just a bad batch?
thanks in advance
thanks heres my setup on the RS:
DB:13
TP:2
BR:75
Turbo:8
Boost:48
5200:18000
Ramp:3
Delay:0
Try this.
Boost 50
Turbo 5
Turbo delay 0,3
Turbo ramp 2
Start RPM 2500
End RPM 7000
Gearing 5.0FDR
It's better not to use the Turbo ramp of 3, This causes more motor head and a specially by a low Turbo delay.
Gear 5.0FDR to start with.
After changing your setups on the speedo, check it by pressing current settings if your RPM settings are still ok.
Set drag brake as you like it but set it lower like 15 or 17.
Brake strength 80 to 85% is enough.
Originally Posted by HVFracingwilly View Post
Here are some race results from the weekend.
Willy(me)=Tekin
Brian=GTB or Havock
Davin= Tekin
Dave=??
Mark=Tekin
this is my second weekend with the Tekin(came from a Havock) i typically would run 7.9-8.1 lap times and as you can see with no other changes my laptimes dropped .2-.4 tenths per lap.
-- S STOCK SEDAN - A Main --
Pos Car Laps time name
1 1 39 5:05.50 WILLY MAGRITZ
2 3 35 5:02.40 BRIAN HILDEBRAND
3 4 35 5:06.51 DAVIN FORSBERG
4 5 31 5:02.19 DAVE GAWARESKY
5 2 22 2:53.96 MARK KOLLOCK
I see that you rule in that class.
Nice.
Originally Posted by Benzaah View Post
The irony...
Some posts back Schreffs set up was mentioned as having the Turbo come on first then the timing boost second. Anyone care to explain that a little?
This setup gives you an other feeling with the car.
Instead of that the Turbo will be ad for extra top speed it is used to get an other feeling of driving. It isn't faster than a setup with the Turbo for extra top speed.
The advantage is, is that as you don't give full throttle you have a lower acceleration speed so for very technical parts of the track you can drive very smooth and when you need the power it's there.
Set the start RPM higher. This to prevent that you have o much timing ad the start.
Than you lose torque and your motor gets hotter.
Set it ad least ad 5000.
On larger tracks is a start RPM of 7000 to 9000 better.
mikky32 is offline
Old 03-31-2010, 04:36 AM
  #13699
We have 2 Nemesis drivers now ad the club.
I use the Tekin motor and the Speedpassion V3.
The Speedpassion and the Nemesis aren't that smooth as the Tekin motor.
I prefer the Tekin motor above the SP3.0.
Also do I have lower motor temps than the Nemesis and the speed is the same. i have also a better acceleration speed. Top speed the same.
mikky32 is offline
Old 03-31-2010, 05:39 AM
  #13700
FLATMAN's Avatar
HEEHEHHEH!! I'LL ALSO BE TO SCARED TO RUN IT!! BEST PAID JOB EVER!!
FLATMAN is offline
Old 03-31-2010, 05:44 AM
  #13701
Skitee's Avatar
Do you know that the use of CAPS is considered as shouting
Skitee is offline
Old 03-31-2010, 05:51 AM
  #13702
FLATMAN's Avatar
sorry for souting
FLATMAN is offline
Old 03-31-2010, 06:02 AM
  #13703
Skitee's Avatar
Just doing my bit to protect those sensitive forum ears
Skitee is offline
Old 03-31-2010, 09:48 AM
  #13704
niznai's Avatar
Here's one for team tekin.
I have managed to tune the RSPro so I have great speed, great infield punch, but my car takes off rather leisurely at the start. Suggestions?
The setup:
boost start/end 6k/12k
turbo 12, delay .5, ramp 1
FDR 5.95
motor SP V3 no timing on motor.
Keep in mind if you want to recommend something that I prefer boost first, turbo after.
I would go with ligther gearing, but am afraid to lose my top speed edge. At the moment, I am on pace speedwise in the tight section, and on the stretch my car is the fastest in the field (by a small margin, but there is no doubt about it).
niznai is offline
Old 03-31-2010, 09:55 AM
  #13705
20 SMOKE's Avatar
Trader Rating: 103 (100%+)
one thing i have seen during my runs is that with a higher start some motor timing works good,play with motor timing
20 SMOKE is offline
Old 03-31-2010, 10:15 AM
  #13706
theisgroup's Avatar
i gear and setup for infield. I find that I may loose 2-3 ft on the straight, but if my setup is spot on, I will easily make that up in the infield sections. i really don't even care if my car is fastest on the straight. it is all about infield speed.
theisgroup is offline
Old 03-31-2010, 10:24 AM
  #13707
Trader Rating: 16 (94%+)
How long is this straight? You are probably down the entire straight in less than a second, so gear down.
I've never seen any of the fast guys out there worrying about maintaining their top-end speed down the staight, as pretty much everyone can drive a straight line well. If you are losing time, focus on the setup for higher corner speed and better punch out of the corners.
In the end - I think you are taking the wrong approach by worrying about being the fastest car down the straight. The race is lost and won in the corners.
Yep - I think I pretty much repeated what Yang said.
kn7671 is offline
Old 03-31-2010, 11:02 AM
  #13708
Akudou's Avatar
Am goin to use lrp 4.5t octa x12 with rs pro. Anyone kind enuff to share a good setting for this combination? 1/10 tc igr 2.055
Akudou is offline
Old 03-31-2010, 01:46 PM
  #13709
The setup:
FDR 5.95
Set the motor on max timing
than find the place for the Boost to kick in.
This is what the Speedpassion 13,5T V3.0 drivers run on my track with a Tekin RS speedo.
Boost max
Turbo 5
Turbo delay 0,3
Turbo ramp 2
Start RPM 3600
End RPM 7000
FDR 5,6 to 5,8
Max motor timing.
As you set the Turbo on 10 set the delay a bit higher to about 0,5sec delay.
mikky32 is offline
Old 03-31-2010, 02:22 PM
  #13710
Benzaah's Avatar
Trader Rating: 24 (96%+)
Who painted that wicked scheme for you man? Props to them...
Benzaah is offline
