Tekin RS ESC sensored
X12 17.5 with RS V203
Medium size asphalt track, high bite
Touring car (Cyclone TC)
Rubber tire
I will be running this combo tonight for the first time, any insight into a starting point is appreciated.
You guys wanting the x12 17.5 might try to send a pm to bigdogracing.
Local guy where I race from was using the LRP with the Tekin the other weekend. Give him a try.
Nope. The only time you have to recalibrate is if you change the firmware (going from version 200 to 203).
problem
I have a problem with the tekin rs pro
The problem is this:
use the v203 tekin with software and with these values:
4 trottle profile
Timing boast 35
turbo boast 10
Dealy 0.2 turbo
3.0 turbo ramp
Start RMP 4678
end rpm 12500th
Final Report 6.5
The problem is that the regulator is very strong, but after 3 minutes significantly diminish the performance as if any further attacks on the turbo, I tried various things but I do not know what the problem is, my friend uses tekin like me and with the same settings and has no problems, and how I use ezpower lipo 50c
give me a hand to understand the problem, thank you.
4 trottle profile
Timing boast 35
turbo boast 10
Dealy 0.2 turbo
3.0 turbo ramp
Start RMP 4678
end rpm 12500th
Final Report 6.5
The X12 has a high motor timing so start with 30 to 35 Boost.
Use max about 40 Boost.
watch the motor temp.
Turbo delay ad least 0,4 sec. 0,6 is better.
Turbo around the 5.
Gearing for the infield.
Start RPM 5000
End RPM 10000
Turbo ramp2
Turbo around the 5.
Start RPM 5000
End RPM 10000
Turbo ramp2
post..
Castle creations swears by sensorless operation and i have heard that at higher currents and rpm's that the sensor readings can drift or become erratic. is sensorless still too imprecise to add the cool timing tricks to dual mode?
4 trottle profile
Timing boast 35
turbo boast 10
Dealy 0.2 turbo
3.0 turbo ramp
Start RMP 4678
end rpm 12500th
Final Report 6.5
4 trottle profile
Timing boast 35
turbo boast 10
Dealy 0.2 turbo
3.0 turbo ramp
Start RMP 4678
end rpm 12500th
Final Report 6.5
X12, Novak, Tekin, Duo 2?
What is the motor timing and how many turns?
13,5T?
I am currently running only sensorless motors in my mod 4WD buggy and having no issues at all keeping up or beating the people running sensored motors. And yes you can even give it a timing boost, but the amount is not the same as when using the sensors to apply timing.
When I get some time I will be making a comparison of running in hybrid mode in stock vs running in sensored mode with timing and turbo.
4 trottle profile
Timing boast 35
turbo boast 10
Dealy 0.2 turbo
3.0 turbo ramp
Start RMP 4678
end rpm 12500th
Final Report 6.5
4 trottle profile
Timing boast 35
turbo boast 10
Dealy 0.2 turbo
3.0 turbo ramp
Start RMP 4678
end rpm 12500th
Final Report 6.5
hope this helps.
problem
used te esc tekin rs pro end tekin motor 10,5
4 trottle profile
Timing boast 35
turbo boast 10
Dealy 0.2 turbo
3.0 turbo ramp
Start RMP 4678
end rpm 12500th
Final Report 6.5
No welds are fine
No welds are fine
No welds are fine
4 trottle profile
Timing boast 35
turbo boast 10
Dealy 0.2 turbo
3.0 turbo ramp
Start RMP 4678
end rpm 12500th
Final Report 6.5
No welds are fine
No welds are fine
No welds are fine
4 trottle profile
Timing boast 35
turbo boast 10
Dealy 0.2 turbo
3.0 turbo ramp
Start RMP 4678
end rpm 12500th
Final Report 6.5
No welds are fine
No welds are fine
No welds are fine
4 trottle profile
Timing boast 35
turbo boast 10
Dealy 0.2 turbo
3.0 turbo ramp
Start RMP 4678
end rpm 12500th
Final Report 6.5
No welds are fine
No welds are fine
No welds are fine
Set the motor timing on 5
Timing Boost on 50
Turbo on 5
Turbo delay 0,4
Turbo ramp 2
Keep those RPM settings and gear a bit lighter.
I think that the timing is to high and to much ad once with the low Turbo delay.
What is the motor temp?
Location: Somewhere between raising hell and Amazing Grace
Trader Rating: 38 (100%+)
Looks like I am now that I've been called out on one of the most active threads on RC Tech
May 14-16 B...I don't know about the personal jet, better bring the hovercraft!
-rocky b
-rocky b
