Old 03-22-2010, 10:58 AM   #13486
Team Tekin
Randy_Pike's Avatar
Send a message via Yahoo to Randy_Pike
Yup: TT3301
"Things may come to those who wait, but only the things left by those who hustle." Abraham Lincoln
Tekin,Protek,A-Main Hobbies,JConcepts,Avid RC,Yokomo,MIP,SikLidz,FactoryRC, www.randypikerc.com
Randy_Pike is offline   Reply With Quote
Old 03-22-2010, 10:58 AM   #13487
Originally Posted by syndr0me View Post
Yeah, new rotors will typically have more "magneticity*." You'll probably need to gear up a bit.
* Hells yes it's not a real word!
Interesting. Could anyone else confirm this theory as well?
Jeremy Otis is offline   Reply With Quote
Old 03-22-2010, 11:01 AM   #13488
macdude's Avatar
The word you are looking for is gauss. And yes new rotors do usually have more even gauss. But not necessarily stronger gauss. If you take several rotors and test them they will all be pretty close. But if you take matters into your own hands then you know for sure that they are even and strong.
macdude is offline   Reply With Quote
Old 03-22-2010, 11:15 AM   #13489
Randy is there some news about the new software for the pc?
what options will be on it?
will we see the RPM's from the motor after the race?
http://www.mikky32.com
Tekin RS pro
TOP racing Photon
Tekin Redline 10,5
Protoform LTC-R
mikky32 is offline   Reply With Quote
Old 03-22-2010, 11:22 AM   #13490
PitNamedGordie's Avatar
Send a message via AIM to PitNamedGordie Send a message via Yahoo to PitNamedGordie
Just for my understanding...does that mean a larger electric field just not a stronger electric field?
☆ The Track @ Harbor Hobbies ☆ www.harbor-hobby.net ☆
PitNamedGordie is offline   Reply With Quote
Old 03-22-2010, 12:48 PM   #13491
macdude's Avatar
From my understanding gauss is the strength of the magnetic field (I assume this means larger too as magnetic flux increases in density the farther the lines of force move from the object if I remember right. ). So a newer rotor will more than likely be a stronger magnet. From talking to the magnet guy he says what he sees most of the time is that the magnetic field is not always equal from top to bottom. So using their gauss machine(big electro magnet) they can make the field stronger and more even from top to bottom. There is a limit to how strong you can make the field and this is based on the ROAR rules. They have limits on rotor size and gauss strength. I am not sure about other organizations.
Old 03-22-2010, 01:25 PM   #13492
inconceivable's Avatar
900 pages, 13,492 posts in less than 2 years (averaging about 19 posts a day) ..... got to be a record on RCTECH. Sorry for the diversion, just happened to notice this today ..... carry on .....
"And now the Matador shall dance with the blind shoe maker"
"America is all about speed. Hot, nasty, badass speed. - Eleanor Roosevelt, 1936"
inconceivable is offline   Reply With Quote
Old 03-22-2010, 01:48 PM   #13493
jag88's Avatar
Originally Posted by Randy_Pike View Post
Yup: TT3301
Randy, I couldn't find it on your website. How do I order it ?
Also I need a number for a replacement case for the RS.
Thanks.
jag88 is offline   Reply With Quote
Old 03-22-2010, 01:49 PM   #13494
RedBullFiXX's Avatar
Trader Rating: 34 (100%+)
Originally Posted by The Pope NJ View Post
Just got a rs and a lrp x12 17.5 for my 12r5.1 any setup
advice?
Start with Yang Lai 17.5 setup
Maybe with the 4dot timing on your X12
And gear for your track.
What I have found lately is that a good baseline on the RS setting, will work
well at a lot of track layouts, without a gear change.
The sweet spot is fairly broad.
This link is available thru the Hotwire as well.
http://www.teamtekin.com/hotwire/ESCsetups/index.html
--> 12th scale Information Source <--
"Men do not quit playing because they grow old; they grow old because they quit playing."
― Oliver Wendell Holmes Jr.
Old 03-22-2010, 04:10 PM   #13495
Hi friend's, I'm Italian and I compliment for this fantastic forum, I bought an tekin rs pro esc with motor tekin redline 10.5t , I installed the software v. 203, someone can help me to program setting the esc whith hotwire?
my car losi jrxs type r, run on carpet with foam tires on medium track
sorry the translation
thanks leo
leano81 is offline   Reply With Quote
Old 03-22-2010, 04:26 PM   #13496
thanks leo
Did you update the speedo?
and did you recalibrate the speedo after it again?
Than set it in sensord mode and click on the advanced button.
Change the End RPM first and push the button under it. than choose the start RPM.
Choose. As you click on calculate rpm's push on ok. this window opens when you calculate the rpms.
Set the motor timing lower.
With the standard motor timing the motor is fast but it get's hotter fast and you can ad more Boost and Turbo. You will run cooler and go fast.
Tekin RS pro
TOP racing Photon
Tekin Redline 10,5
Protoform LTC-R
Old 03-22-2010, 07:28 PM   #13497
Team Tekin
Randy_Pike's Avatar
There is currently no part # for the case set. If you can't find what you're looking for you can order it from me. Just call me tomorrow at this # 208 634 5559.
Old 03-22-2010, 07:29 PM   #13498
maxepower's Avatar
Exclamation "New software"
I guess somebody has asked this already but if not, then does anybody know if Tekin is going to come out with a software that is compatible with Apple!
Inquiring minds want to know!
maxepower is offline   Reply With Quote
Old 03-22-2010, 09:24 PM   #13499
you guys are all wrong about the ideal torque curve. this is what it should look like.
on a serious note. could current limiting in dual mode cause the speed control to heat up? im running a redline 2.5 in my RC12R5 and running it on a big 200ft outdoor asphalt nitro track and after installing a 2nd cap the speed control dropped from 200F to 170F but the motor is still well under 130F.
im running some 1.5 year old trinity matched ep4600 nimh's. i hear that if the batteries are weak, they can cause the speed control to heat up, is that true?
when i get lipos, what are the things i should do to drop ESC temp a little and get my motor warmer. currently my gearing is 96/20 and total timing is under 20. current limit is at 84.
benben10 is offline   Reply With Quote
Old 03-22-2010, 11:18 PM   #13500
bvoltz's Avatar
Trader Rating: 44 (100%+)
Ok, I just got my new RS speedo, and I'm must be completely retarded, so please forgive my question if is seems so dumb that you are not willing to answer it. But can someone post a picture of the solder job, I see Jeff's on the first page but I can not see how you guys are soldering say Deans Noodle 12 gauge to the posts... It looks like a connector is missing, as in a connector that goes on the wire, and then connector goes on the post. It is going to look really stupid if I solder to the side of the post and heat shrink over it.... Very off set.... or do you dermal off one side of the post... I'm not picking on the speedo, just trying to understand if I'm missing something, because on the instructions, it shows a connector.... Or is 12 gauge wire way to big...
and you are using the cap included, or something bigger for 17.5?
Thanks in advance....
bvoltz is offline   Reply With Quote
Tekin Redline RS Sensored ESC and motors, opinions for offroad? Cain Electric Off-Road 4230 06-07-2015 04:38 PM
Sensored vs. Sensorless lemansracer Electric On-Road 71 02-14-2009 03:19 AM
New Tekin Redline Sensored Motors are Roar Legal! Randy_Pike Electric On-Road 3 08-05-2008 02:08 AM
Tekin Redline Sensored 10.5 HUCKMAN Electric On-Road 6 07-15-2008 08:50 PM
sensored vs sensorless bprocket Rookie Zone 5 05-16-2008 09:38 AM
Tags
v203, vegas 2.0
