Old 03-16-2010, 02:57 PM   #13336
wstuart's Avatar
Trader Rating: 112 (98%+)
Send a message via AIM to wstuart
what does it take to update to the 203 software? Can my friend with a hotwire update mine for me or do i have to send it in?
Yokomo Yz-2 x2
Yokomo B-max4iii
Awesomatix a700 evo
Team El Cajon Hobbies
wstuart is offline   Reply With Quote
Old 03-16-2010, 02:59 PM   #13337
Krio's Avatar
Trader Rating: 150 (99%+)
You just need a windows computer and the hotwire. Doesn't matter who's it is as anyone can do it for you once they have the latest software on their comp.
www.kriostasis.com
Krio is offline   Reply With Quote
Old 03-16-2010, 03:09 PM   #13338
Dadaman's Avatar
Trader Rating: 20 (100%+)
I would like to thank Tekin for their quick service. Fantastic to see a new speedy to replace my old one that gave up the ghost. Good to see a company back up a fantastic product with fantastic service.
Adam Beniston.
Xray XB4 '16
Yokomo Dogfighter YZ-10 870c
Xray T4 '14
Dadaman is offline   Reply With Quote
Old 03-17-2010, 12:44 AM   #13339
Yokomo_Ant3's Avatar
Trader Rating: 29 (100%+)
Originally Posted by niznai View Post
Great work, congratulations to whomever did it. I used to race at the track there. Still have the old YR4 with its battlescars. I guess it's about as big as the old track?
Yea its the same size. re-painted surface and new layout Lap times are around 21.8 seconds...in mod, 22.6 for 10.5, and 22.8 for stock (Fastest laps). On the layout Benzaah has showed in the picture. Running Anti-clockwise.
On another note tried my Tekin with 10.5 last night. Seems fast, ill see this weekend at the event im travelling too. hope it all goes well
Antoni
Antoni Caretti
Team Yokomo - Racing Performer - Sweep Racing
Yokomo_Ant3 is offline   Reply With Quote
Old 03-17-2010, 09:14 AM   #13340
Jorge G's Avatar
Default Cartpet on Road Nationals
Is there a Tekin sponsored driver attending the Carpet on Road Nationals next week at MD?
TC6
XRAY NT1/ Novarossi 353 Race Engine
F1 F104 Pro V2
Jorge G is offline   Reply With Quote
Old 03-17-2010, 10:46 AM   #13341
Trader Rating: 16 (100%+)
Anyone can share a good indoor carpet (35x90) rubber TC setup for TEKIN RS V203 with (1) Tekin Redline 17.5 and (2) Novak 13.5 SS? Thanks...
Old 03-17-2010, 11:51 AM   #13342
I have an iPhone and I try to download the driver setup sheets off the Tekin website but they come up blank? Anyone have a way to get them to show the settings? Thanks for any help. Love this speedo.
HIGHTYMES is offline   Reply With Quote
Old 03-17-2010, 12:07 PM   #13343
just been training outside for the first time this year ,
all i can say is WOW !!!!!
straight line speed is AWSOME and the punch out of the corners is great
fantastic speedo , keeps amazing me
sidecarphil1 is offline   Reply With Quote
Old 03-17-2010, 04:36 PM   #13344
What was your setup and motor temp?
I go Sunday finally on the outdoor track.
I can't wait.
As I don't have my 13,5 in this week, than it will be the 10,5T motor.
It will be overkill on the track but I also want to see how it goes.
I think that some drivers will be afraid as they see the power.
http://www.mikky32.com
Tekin RS pro
TOP racing Photon
Tekin Redline 10,5
Protoform LTC-R
mikky32 is offline   Reply With Quote
Old 03-17-2010, 07:08 PM   #13345
Send a message via Yahoo to Mr. Paroxysmal
Default Tekin RS solder post
Is it possible to remove the solder post on the Tekin speedo and solder the wire directly to the solder pad? The reason I ask is because there are couple of time on my local tract the that wire got de-solder and burn the speedo. Need responce.
Mr. Paroxysmal is offline   Reply With Quote
Old 03-17-2010, 07:14 PM   #13346
Regional Moderator
CarbonJoe's Avatar
Doubtful. Now that almost all manufacturers are ROHS certified (basically, using lead free processes/materials), the solder used melts at higher temperatures. Without a decent solder rework station, you'll probably damage the circuit board (or at least the traces) trying to remove the posts. And it will void your warranty. Even more of a risk on an RSPro due to the posts being connected to two boards. And the posts are used as a heatsink during normal operation.
*** The Gate - Celebrating 8 years at the same location ***
The difference between genius and stupidity is that genius has its limits. - Albert Einstein
Understeer is when you hit the wall with the front of the car and oversteer is when you hit the wall with the rear of the car
CarbonJoe is offline   Reply With Quote
Old 03-17-2010, 07:17 PM   #13347
RCGaryK's Avatar
I'm using Jesse Munn's SC10 setup as a baseline and had a question. On the setup sheet it says the timing boost was set to 10. Looking in the interface I don't see a timing boost option. However I see a turbo ramp, but that is not on his setup sheet. Are these one and the same? Does the timing boost get set on the ESC and not through the HotWire?
Site Content Specialist- Surface
HorizonHobby.Com
Horizon Hobby is on YouTube with hundreds of different videos! Visit us at
http://www.youtube.com/HorizonRCdotCom
RCGaryK is offline   Reply With Quote
Old 03-17-2010, 07:50 PM   #13348
Regional Moderator
CarbonJoe's Avatar
Is the Sensored Mode box checked, or Dual mode? Once you check the sensored mode box, you get timing boost. You can only select those in Hotwire.
Old 03-17-2010, 07:58 PM   #13349
RCGaryK's Avatar
It was in dual mode. Is that the ticket then? I thought the advantage was doing Dual Mode, that way it kicks it into sensorless and increases the RPM on the top-end.
HorizonHobby.Com
Old 03-17-2010, 08:07 PM   #13350
Regional Moderator
CarbonJoe's Avatar
I think most of the use for dual mode is for modified motors, and maybe off-road. Since in dual mode (or complete sensorless mode), the ESC doesn't know the exact position of the rotor, it has to be a little less aggressive than it can be in pure sensored mode. Thus, it should be turning more RPM in sensored mode because the timing can be more precise as to when to apply power to the poles of the motor.
Tekin Redline RS Sensored ESC and motors, opinions for offroad? Cain Electric Off-Road 4230 06-07-2015 04:38 PM
Sensored vs. Sensorless lemansracer Electric On-Road 71 02-14-2009 03:19 AM
New Tekin Redline Sensored Motors are Roar Legal! Randy_Pike Electric On-Road 3 08-05-2008 02:08 AM
Tekin Redline Sensored 10.5 HUCKMAN Electric On-Road 6 07-15-2008 08:50 PM
sensored vs sensorless bprocket Rookie Zone 5 05-16-2008 09:38 AM
Tags
v203, vegas 2.0
