Old 03-15-2010, 07:06 AM   #13276
Originally Posted by CarbonJoe View Post
This was with an RS, but I've also heard of it happening with a Pro as well (apparently, the base control board is the same between the two). Just a software bug with the upgrade process.
but, this bugs can be solved right?? (with downgrade and upgrade the firmware??)
deadball is offline   Reply With Quote
Old 03-15-2010, 07:13 AM   #13277
Regional Moderator
CarbonJoe's Avatar
It did for us. Your Mileage May Vary.
*** The Gate - Celebrating 8 years at the same location ***
The difference between genius and stupidity is that genius has its limits. - Albert Einstein
Understeer is when you hit the wall with the front of the car and oversteer is when you hit the wall with the rear of the car
CarbonJoe is offline   Reply With Quote
Old 03-15-2010, 07:29 AM   #13278
hope i get the good copy..... thanks for ur explanation....
TEKIN RS here i comeeeeeeeeeeeeeeeeeeeeeeeeeeee................... ................................
Old 03-15-2010, 07:55 AM   #13279
Regional Moderator
Jon Carlson's Avatar
Trader Rating: 48 (100%+)
I just want to remind people that this isn't the norm. I've done many updates for me and others and have seen others do them as well without any of these issues.
1. Remember to remove all of the older version of Hotwire from your computer before installing the newest one.
2. If you update to v203 a radio recalibration might be a good thing to do anyway. After adjustments this shouldn't be necessary though, just when changing version in the ESC.
Jon Carlson
Team Associated, Reedy
Futaba, OS Engines, O'Donnell Racing Fuel
Jon Carlson is offline   Reply With Quote
Old 03-15-2010, 08:07 AM   #13280
dizzy1's Avatar
Trader Rating: 24 (100%+)
This was in a SCT 2wd vehicle. Using some of the settings suggested in the team driver setups, I was getting a problem where as you drive the vehicle from a dead stop, it would often "hang" where you could pull almost full throttle and it wouldn't go. It was as if it was searching for something. I tried a different motor that worked with a different brand of esc, and had the same issues.
Had the same thing happen, if you check your settings you'll see something from v203 didn't take. In my truck was the same thing you had, hooked it up again and no beginning RPM took, so assumed it confused the RS. Reflashed it and kept checking the current settings to make sure. Took about 8-9 tries for some reason to get it to take. No issues like that since.
No more hot pockets, Russian rocket time again.
Hobbywing- Schuurspeed
dizzy1 is offline   Reply With Quote
Old 03-15-2010, 08:11 AM   #13281
CCristo's Avatar
Trader Rating: 55 (100%+)
Also, be sure to have the hotwire plugged directly into the USB port on the computer. Don't use a USB hub.
Chris Cristo
Pro-Line RacingHobbywingMIPBOOMrcFutabaPT RC Racing Oils
CCristo is offline   Reply With Quote
Old 03-15-2010, 08:15 AM   #13282
Regional Moderator
I have seen this happen when you don't remove the old versions of hotwire from the computer. I go into the control panel and use the "Uninstall Program" function to make sure there are no previous versions of Hotwire installed before I download and install a fresh one.
Jon Carlson
Old 03-15-2010, 08:32 AM   #13283
Tech Legend
Cain's Avatar
Trader Rating: 240 (100%+)
For my situation the hotwire install was a brand new one from the Tekin website.
USB wire was plugged directly into the laptop.
I am going to try the following when I get a chance:
- Uinstall hotwire software and go with a fresh install
- Go back to firmware 180 and then back up to 203
- Start with minimal timing boost , 15000 End RPM and 5000ish start RPM
- Walk timing boost up to max of novak motor timing slowly.
As a side question, how bright should be the lights on the ESC if there is a problem?
If you have any reception issues with the radio, does the lights constantly blink on the ESC?
As a side note, just want to say a big thanks to Swen. He did his best to help me sort the issues at the track while he was getting himself ready for his races. Unforunately we couldn't solve them, hopefully can in the future.
< Tekno EB48SL / SCT410.3 | Tekno EB410 x 2 | Yokomo YZ-2 DTM x 2 | LC Racing EMB-1 Buggies and Truggies >
Old 03-15-2010, 11:45 AM   #13284
What is the faster and better overall motor to get for the tekin rs v203. Lrp x-12 10.5 or tekin redline 10.5?
HoboShop is offline   Reply With Quote
Old 03-15-2010, 11:50 AM   #13285
20 SMOKE's Avatar
Trader Rating: 101 (100%+)
thats like asking whats the best esc,i like tekin motors
Jamie W
*Team Tekin*Tekno-rc*DE Racing*AKA*DDHRC*
20 SMOKE is offline   Reply With Quote
Old 03-15-2010, 11:58 AM   #13286
I think that the speed is about the same but my choice is also the Tekin motor.
I have a 10,5T Tekin motor and I love it.
I hope this week to receive my Tekin 13,5T motor.
Just wonderful motors. Fast and reliable. I like the feeling of the motor. It drives very smooth.
http://www.mikky32.com
Tekin RS pro
TOP racing Photon
Tekin Redline 10,5
Protoform LTC-R
mikky32 is offline   Reply With Quote
Old 03-15-2010, 12:02 PM   #13287
wats the best way to smooth these settings out and make it more drivable?
the motor is the new gm 13.5 starwind
drag break off
reverse off
break strenth 100
neutral width 56
motor type bl-dl
trottle profile 3
volt cut off off
push control off
timing boast 45
turbo boast 10
start rpm 5580
end rpm 20000
turbo delay 0.2
turbo ramp 1.0
gearing 6.48
also has anyone got a link for the blank setup sheets?
thanks
stcc ssb tires, ko ,gm motors, demon products lipos, hobbywing speedo
mwoods is offline   Reply With Quote
Old 03-15-2010, 12:11 PM   #13288
drag break off
reverse off
break strenth 100
neutral width 56
motor type bl-dl
trottle profile 3
volt cut off off
push control off
timing boast 45
turbo boast 10
start rpm 5580
end rpm 20000
turbo delay 0.2
turbo ramp 1.0
gearing 6.48
thanks
Try this.
break strenth 85%
neutral width 10
motor type bl-fw
trottle profile 3
timing boast 45
turbo boast 10
start rpm ~5000+
end rpm 24000
turbo delay 0.5
turbo ramp 2.0
gearing 6.48
Your neutral width was way to high. This way your car reacts better when you pull your throttle.
I think that this was the biggest problem.
I also think that as you set Boost on 50 and Turbo on 5 that it will work better.
Your Turbo delay was low. Use from 0,4 and higher. on smaller tracks you don't need the Turbo. Just use it to ad some extra top speed.
What is the timing on the motor?
Tekin RS pro
TOP racing Photon
Tekin Redline 10,5
Protoform LTC-R
Old 03-15-2010, 12:13 PM   #13289
Tech Legend
Cain's Avatar
Anyone here using a Spektrum DX3S? if so, have you noticed that the neutral width has some "play" at the 56 setting? even when I go down to say 15 it still seems like there is some play there.
Old 03-15-2010, 12:20 PM   #13290
Originally Posted by mikky32 View Post
Try this.
break strenth 85%
neutral width 10
motor type bl-fw
trottle profile 3
timing boast 45
turbo boast 10
start rpm ~5000+
end rpm 24000
turbo delay 0.5
turbo ramp 2.0
gearing 6.48
im not sure wat the timing is ill find out and get back to u ,
thanks for the help ....
Tekin Redline RS Sensored ESC and motors, opinions for offroad? Cain Electric Off-Road 4230 06-07-2015 04:38 PM
Sensored vs. Sensorless lemansracer Electric On-Road 71 02-14-2009 03:19 AM
New Tekin Redline Sensored Motors are Roar Legal! Randy_Pike Electric On-Road 3 08-05-2008 02:08 AM
Tekin Redline Sensored 10.5 HUCKMAN Electric On-Road 6 07-15-2008 08:50 PM
sensored vs sensorless bprocket Rookie Zone 5 05-16-2008 09:38 AM
Tags
v203, vegas 2.0
