Old 03-12-2010, 05:34 AM   #13216
Originally Posted by WIITA View Post
Here's a question for all of you seasoned vets. I run 1/12 17.5 1c and I have been fighting the car droping of .8 to a full 1 second in the last 2 min. The frist 4-5 min the car rips like crazy. What is your expirence of fading? some guys at the club seem to be able to knock the fade down to .3 or .4. Here are my settings
Timing 48
Turbo 4
Delay .5
End 7000
Start 2500
rollout 75
Thanks for any help and suggestions guys!
What is the timing on the motor?
http://www.mikky32.com
Tekin RS pro
TOP racing Photon
Tekin Redline 10,5
Protoform LTC-R
mikky32 is offline   Reply With Quote
Old 03-12-2010, 06:13 AM   #13217
theisgroup's Avatar
Timing 48
Turbo 4
Delay .5
End 7000
Start 2500
rollout 75
you are either overtimed or over geared. fall off should be about a half second. the only other thing would be bad setup on the car and you are overdriving the tires and they are using up the traction compound.
yang lai
Team Tamale | Team Tekin | RCAmerica | Speedmerchant | Speedzone RC | EA Motorsports | Ko Propo USA | eXpress Motorsports | Parma/PSE
theisgroup is offline   Reply With Quote
Old 03-12-2010, 07:40 AM   #13218
WIITA's Avatar
Trader Rating: 42 (100%+)
Sorry motor timing is one notch on the duo 2.
Team CRC / Sanwa / Team scream / Genesis RC / Hobbywing / TQ Wire / Schelle / MIP / RC^2 / TEKNO / BoomRC
WIITA is offline   Reply With Quote
Old 03-12-2010, 08:23 AM   #13219
I think that you are geared to heavy.
I don't now what timing is now on the motor but I think that you can better set it lower.
Also this will make that you don't have a to high timing.
I thought ad the standard mark that it was 10 if i'm correct.
Tekin RS pro
TOP racing Photon
Tekin Redline 10,5
Protoform LTC-R
Old 03-12-2010, 08:52 AM   #13220
Tech Legend
Cain's Avatar
Trader Rating: 240 (100%+)
Originally Posted by razzor View Post
you cant get a exact end rpm value. once you set your start rpm choose a end rpm closest to what you want.
There is some calculations done in the software that works of off the start rpm value that kicks out random end rpm selections.
I just took a look again and the only option I have is to enter the end RPM value, and then hit caculate and it gives me a list of starting RPMs.
so I am not sure where you are seeing this at but that is what is going on with hotwire software.
Also when I decheck 1S lipo, and apply settings, it still is retaining the 1S lipo setting as being checked. I got it to go away but I had to pick default setting and reset everything.
I also sometimes get a error with some Debug info from software.
< Tekno EB48SL / SCT410.3 | Tekno EB410 x 2 | Yokomo YZ-2 DTM x 2 | LC Racing EMB-1 Buggies and Truggies >
Old 03-12-2010, 08:53 AM   #13221
WIITA's Avatar
Ok, I'll try decreasing the gearing. Thanks!
Old 03-12-2010, 09:37 AM   #13222
You can also set the start RPM a bit higher and the End RPM Higher.
like 3500 - 10000.
This makes hat you can gear a bit heavier.
But start with a lighter gearing and work from there.
Tekin RS pro
TOP racing Photon
Tekin Redline 10,5
Protoform LTC-R
Old 03-12-2010, 10:15 AM   #13223
Akudou's Avatar
Amyone knows the best setting for orion 11.5t? My fav fdr is 7.7 - 9. Drag brake 0, reverse off, motortype 1, throttle 3-4, limiter 2, push 70, boost 20-30, turbo 15-40, delay 0, ramp 2, start 4xxx end 17xxx -19xxx. Respond on straight is very easy but in the inside corners i felt the lack of torque. My other problem is after acceleration on long straight it felt like theres drag brakes which slowed me down too much where the other cars manage to close down on me. Is the push button doing that cos i know when u off it, the drag brake felt even stronger. So any fine settings to help me out here?. Temps 71degC 5min. Looking to maximise to 80degC
Akudou is offline   Reply With Quote
Old 03-12-2010, 10:42 AM   #13224
Try this.
Boost 50
Turbo 10
Turbo delay 0,5
Turbo ramp 2
Throttle 3
Start RPM 5000
End RPM 16000
Play also with your gearing. A good infield speed will be reached by the right gearing.
You don't have to reach a motor temp of 80C.
The motor temp you have now is good.
I don't now the motor timing but if possible set it a bit lower.
First gear for the infield and play with the Boost around 45 to 50.
Later ad the Turbo. I think 10 will be enough.
Tekin RS pro
TOP racing Photon
Tekin Redline 10,5
Protoform LTC-R
Old 03-12-2010, 10:58 AM   #13225
gubbs3's Avatar
Timing 48
Turbo 4
Delay .5
End 7000
Start 2500
rollout 75
As much as I like beating you, your car was off last night. Next Sunday give this a try:
Timing 30
Turbo Max
Delay .5
Ramp 1.0
End 7500
Start 1500
rollout 75
It wasn't perfect but it didn't fade noticeably at all. The infield was great but I would have liked the turbo to come in a little quicker. I might try lowering the end rpm to 7000 and the delay to .3.
gubbs3 is offline   Reply With Quote
Old 03-12-2010, 11:02 AM   #13226
Akudou's Avatar
Default .Delay
Delays slowed my acceleration on the early straight n accelartion out of corners. Our straights is only 30m.
Old 03-12-2010, 11:09 AM   #13227
Akudou's Avatar
Thinking of using fdr 9-11 . Recmended settings pls?
Old 03-12-2010, 11:23 AM   #13228
20 SMOKE's Avatar
Trader Rating: 101 (100%+)
FLASH THE ESC TO 200 AND THEN GO BACK TO 203 THIS SHOULD FIX THE 1S CHECK BOX,OPPS SORRY FOR THE CAPS
Jamie W
*Team Tekin*Tekno-rc*DE Racing*AKA*DDHRC*
20 SMOKE is offline   Reply With Quote
Old 03-12-2010, 12:52 PM   #13229
mjc168's Avatar
Trader Rating: 25 (100%+)
higher fdr your car will feel drag than a low fdr.... try put 7 fdr, see any help or not...
http://www.pprcc.com/
1/10 On-road Touring: Schumacher MI3 + Tekin RS Pro + Orca RX-1 11.5t BL Motor
1/10 On-road Touring: Xray T3 2011 + Tekin RS Pro + Tekin Redline 10.5t BL Motor
mjc168 is offline   Reply With Quote
Old 03-12-2010, 01:17 PM   #13230
Would anybody have a fast setup that won't fry the motor. I run on a small track with a medium straightaway. I am running a tamiya 416 we with tekin v 203 thunderpower 5200 mah 50c, lrp x-12 17.5, 100t spur, and 30t pinion? Please help me out.
HoboShop is offline   Reply With Quote
Tekin Redline RS Sensored ESC and motors, opinions for offroad? Cain Electric Off-Road 4230 06-07-2015 04:38 PM
Sensored vs. Sensorless lemansracer Electric On-Road 71 02-14-2009 03:19 AM
New Tekin Redline Sensored Motors are Roar Legal! Randy_Pike Electric On-Road 3 08-05-2008 02:08 AM
Tekin Redline Sensored 10.5 HUCKMAN Electric On-Road 6 07-15-2008 08:50 PM
sensored vs sensorless bprocket Rookie Zone 5 05-16-2008 09:38 AM
Tags
v203, vegas 2.0
