Old 03-10-2010, 11:21 AM   #13171
TheCoolCanFanMan's Avatar
Originally Posted by Skiddins View Post
And where were you? Looks like I should be handing out four feathers.
Skiddins
Inside in the warm (eventually) lol. You and Spence don't need me as a bench mark
Malc
ARC 2013 model ZEN Racing, MM-UK, HW 3.1, Rich Paints, MM UK Rug Racers win13.5 2007/8
2nd in 2008/9/10 Win Ansman GP 2010 Schumacher GP. 17.5 blinky Winner of STCC 2009/10 13.5 WLRC 2010 Summer series. Winner of EWS Winter. 17.5 Blinky Winner of 2012/13/14 Rug Racers. 17.5 Blinky 2013 WLRC summer series. Newbury RCC GP 2014 17.5 Blinky 2015 3rd in 17.5 Rug Racers
TheCoolCanFanMan is offline   Reply With Quote
Old 03-10-2010, 11:25 AM   #13172
niznai's Avatar
Default Work in progress
Here's two setups I tried today and some comments.
Track size 16x25m, carpet, medium-low traction.
If I don't use brakes, the speedy comes off at about 80 degC after 5min race. Using the brakes temps go up to 90-95 depending on how much I use them. Race is run counterclockwise, start line halfway down the main straight. The point where I like/need to use the brakes is at the chicane (corner 4). I can do without for the rest.
Second setup was way faster in the infield and acceleration was probably best in class (for the time being at least). Once out of the slalom section I can floor it and nobody can catch up.
I will report further changes and how they go.
Team Greasy Weasel
The best upgrade to any car is some driver skill.
niznai is offline   Reply With Quote
Old 03-10-2010, 11:29 AM   #13173
twk-b's Avatar
Send a message via MSN to twk-b
Originally Posted by Randy_Pike View Post
The new "layout" is coming...
Obviously you are doing a fantastic job, if the best things people can find to suggest have nothing to do with improving track performance, Great Job
coming in weeks, months, years?
mac or iphone/andriod version ever?
any chance of future firmware being able to store max rpm hit?
secretly I am hoping hoping that the delay in getting the new interface has been caused by another firmware as earth shattering as v203
-b
twk-b is offline   Reply With Quote
Old 03-10-2010, 12:18 PM   #13174
Skiddins's Avatar
What about gearing even lower, disabling the turbo and changing the profile down to 3 or 2.
I must confess I don't like having anything that hot in my car. If my motor goes above 60deg C I start to wonder what minor problem could result it suddenly going too high.
Skiddins
Xray T4'18, T4'14 (Wet Car)
Xray X12 2018
Xray X1'16
wlrc.co.uk (West London Racing Centre)
RCDisco.co.uk
Skiddins is offline   Reply With Quote
Old 03-10-2010, 03:00 PM   #13175
Skiddins
With the V200 was the 80C normal but bow I hear a lot of drivers have lower temps with the V3.0 motor.
I would also gear lighter and set the Turbo on 0. As you than come top speed to short ad some Boost.
It can handle it good with a lighter gearing.
http://www.mikky32.com
Tekin RS pro
TOP racing Photon
Tekin Redline 10,5
Protoform LTC-R
mikky32 is offline   Reply With Quote
Old 03-10-2010, 05:49 PM   #13176
Just a question regarding the wires going from the ESC to the motor.
Is it important that all 3 wires are of the same length? Or does it not matter?
Thanks!
rnd_tang is offline   Reply With Quote
Old 03-10-2010, 05:58 PM   #13177
Con
It dosn't matter
Con is offline   Reply With Quote
Old 03-10-2010, 05:58 PM   #13178
JayL's Avatar
where are all the mod setups?
Speedworld
4.5
JayL is offline   Reply With Quote
Old 03-10-2010, 06:10 PM   #13179
hacker's Avatar
Trader Rating: 141 (100%+)
Default 203 bug
ive noticed the rpm ranges dont save sometimes......
and yes I'm doing it correctly, type in rpm, calculate, select start rpm, apply settings, exit properly.
when it doesnt save the current rpm settings, it defaults at 3/4k rpm, a 1000rpm range lol
hacker is offline   Reply With Quote
Old 03-10-2010, 06:30 PM   #13180
Akudou's Avatar
Dameetz and me decide to fine tune the rspro suiting our upcoming race track. We are wondering despite drag brake off, it slowed down too quickly on throttle release just like an initial brake force was on very high. Dameetz tried the push control on max and the initial brake feeling felt much better like it was off. May i know the purpose of push control pls? Dameetz on SP11.5T V3 ran fdr of 8.2, 9. Power felt great and the torque was good Problem is after 2.5min to 3min, the pwer seems to turn soft. Temp was good running 3 different fdrs: 48degC,54degC and 62degC. Dameetz is looking for a temp on atleast 70degC as this meant the power of the motor is in full potential that way.
As for my setting am on Orion vector 11.5T. with FDR of 7.7 and 9. suprisingly both fdrs feels great but we hope to get something better again. Dameetz and me going different fdrs today, hes on the lower while im goin on higher fdr later . on fdr 7.7 i only manage 58degC while on 9.0fdr i only manage 2min 30sec as my tire lost its grip on the chicane and i damage my solid axle end of my session for that time since i didnt bring spareparts at that time.
Any comments or reccomendations?
Akudou is offline   Reply With Quote
Old 03-10-2010, 07:47 PM   #13181
niznai's Avatar
Skiddins
Yes, it seems a bit hot but 80 deg is OK and with just a short stab on the brakes at the point explained above, I can keep it close to 80.
That's where I come from setupwise (lighter gearing, no turbo, profile 3). It didn't have enough final speed, sluggish acceleration, temps were at 80 deg. With v200 my motor was actually closer to 65degC, but that was a Tekin motor (same track).
At the moment I suspect two detrimental things happening. I think the boost comes in too early in the slalom section, so I will try raising the start RPM a tad. The second is boost/turbo overlap after the infield so I will increase the turbo delay.
This is what I am talking about when I argue we need some dyno info on motors.
Soon I will receive my data logger and start working with that.
Team Greasy Weasel
Old 03-10-2010, 08:10 PM   #13182
oeoeo327's Avatar
Trader Rating: 74 (100%+)
I too have seen this happen while trying to change the RPM range for the timing boost function. I think the problem could be tied to the method used to change the end RPM value; if you wanted to change the end RPM figure from 8500 to 8800, make sure that you delete the entire number (8500) before entering a final RPM value of 8800. If you use your cursor controls to navigate to the "5" in 8500, delete the "5" and add an "8", I think you'll see the behavior you've mentioned. I've noticed that this problem happens occasionally when changing a portion of the end RPM value, but it seems that clearing the entire end RPM value before recalculating the start RPM values will prevent the problem from occurring.
Founding member of the Solid Gold Racing Team - Mediocrity, redefined...
oeoeo327 is offline   Reply With Quote
Old 03-10-2010, 08:39 PM   #13183
Great ESC!
rusty4768 is offline   Reply With Quote
Old 03-10-2010, 08:50 PM   #13184
I'm having an issue with the new RS in my 12th scale that has me pulling my hair out. I'm running a Novak SS 10.5 with a Speedzone 1s 5000mah 50c lipo, and I CANNOT get the speed controller to stop cogging from a standing start. It just chirps like a guinea pig and jerks forwards or backwards, depending on which mood it's in (read- totally useless). When I look at the sensor test on the speed controller, I get nothing. When I tried a 13.5 duo, it works fine. When I tried 4 other Novak motors, they didn't work either. Here's the kicker- if I use a 4-cell nimh or 2s lipo, everything works fine with the Novak motors (including the sensor test). I've tried a capacitor in the receiver, a seperate receiver pack, and also unplugging the servo (Futaba 9650).. nothing helps when I'm using the 1s lipo.
I've also played with timing and tried every version of the software from 183 up to 203. NOTHING is making a difference. If I have to buy all new motors just to run this thing, I'm going to send it back and just throw my 4cell GTB back into the car. Is there some known issue with this ESC not being able to detect the sensors in Novak motors when running 1s lipo??
Serzoni is offline   Reply With Quote
Old 03-10-2010, 09:12 PM   #13185
mjc168's Avatar
Trader Rating: 25 (100%+)
I never run a 11.5t motor which higher than 7 FDR. I am running 7 FDR for Orca motor and 6.5 FDR for speedpassion motor with difference boost and end rpm. usually i will put 18000-22000 end rpm.
http://www.pprcc.com/
1/10 On-road Touring: Schumacher MI3 + Tekin RS Pro + Orca RX-1 11.5t BL Motor
1/10 On-road Touring: Xray T3 2011 + Tekin RS Pro + Tekin Redline 10.5t BL Motor
mjc168 is offline   Reply With Quote
Tekin Redline RS Sensored ESC and motors, opinions for offroad? Cain Electric Off-Road 4230 06-07-2015 04:38 PM
Sensored vs. Sensorless lemansracer Electric On-Road 71 02-14-2009 03:19 AM
New Tekin Redline Sensored Motors are Roar Legal! Randy_Pike Electric On-Road 3 08-05-2008 02:08 AM
Tekin Redline Sensored 10.5 HUCKMAN Electric On-Road 6 07-15-2008 08:50 PM
sensored vs sensorless bprocket Rookie Zone 5 05-16-2008 09:38 AM
Tags
v203, vegas 2.0
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
