Old 03-09-2010, 06:34 AM   #13126
dameetz's Avatar
Default Voltage cuttoff
I m using mine in 2 cells Lipo TC car 11.5t class, I m just wondering, will there be any performance difference if I set the voltage cutoff to OFF? Or should I always use it on 6.0V minimun set? The default set was to OFF though.
Dudududududuuuuuu.....
dameetz is offline   Reply With Quote
Old 03-09-2010, 06:35 AM   #13127
Skiddins's Avatar
Originally Posted by 20 SMOKE View Post
skid,did you use a data logger
No, maths and a speedgun
Originally Posted by niznai View Post
And what motor? Was it the same as twk-b?
BL motors are vastly different these days. Using the data logging equipment is only half of the equation. Knowing what the motor needs/wants is the other half. Unfortunately this is up to the motor manufacturers to tell us. With so many motors with very different timing settings that don't transfer directly from one motor to the next, ESC setups are wildly different too. Manufacturers would help greatly to give some dyno sheets with their motors even if not completely accurate. At least some generic dyno sheet for each motor class they sell and it would be better than leaving it up to us to guess.
Nosram Spec 10.5, which is an LRP x12 but a different colour.
0 timing on the motor, 40 timing and 10 turbo.
Hardly ever got to use the turbo as grip was down and had tobe carefull of wheelspin!
Xray T4'18, T4'14 (Wet Car)
Xray X12 2018
Xray X1'16
wlrc.co.uk (West London Racing Centre)
RCDisco.co.uk
Skiddins is offline   Reply With Quote
Old 03-09-2010, 06:39 AM   #13128
niznai's Avatar
the default is probably set to OFF because some people might use it with a one cell lipo.
The reason is that if dump you stuff your battery. Even if normally you wouldn't dump, it's easy to overlook this setting and engage in a race where your battery will dump. To me it happened when we extended the race time to 7 minutes instead of the usual 5. Fortunately, I had the voltage cutoff set on.
Team Greasy Weasel
The best upgrade to any car is some driver skill.
niznai is offline   Reply With Quote
Old 03-09-2010, 07:13 AM   #13129
spencehotbodies's Avatar
Default SPEED GUN TIMES
Hello Skiddens
Who was the quickest? and what class? and what chassis?
Cheers
Spence
spencehotbodies is offline   Reply With Quote
Old 03-09-2010, 07:28 AM   #13130
dameetz's Avatar
So there is no performance gain or lost, right? My setting at the moment is using Turbo and Timing firmware 203.
Old 03-09-2010, 07:40 AM   #13131
No the lipo cutoff is only for safety.
http://www.mikky32.com
Tekin RS pro
TOP racing Photon
Tekin Redline 10,5
Protoform LTC-R
mikky32 is offline   Reply With Quote
Old 03-09-2010, 07:53 AM   #13132
Sounds like you had fun
just one thing though... "0 timing on the motor" isn't 0 timing, which insert were you using ?
CPD Racing
chris_dono is offline   Reply With Quote
Old 03-09-2010, 10:38 AM   #13133
Where should I have the voltage cutoff set to. I run tekin rs v203 with lrp x-12 17.5 and a thunderpower 2s 5200mah 50c battery?
HoboShop is offline   Reply With Quote
Old 03-09-2010, 10:42 AM   #13134
on 2
you will see the number to above the bar.
Tekin RS pro
TOP racing Photon
Tekin Redline 10,5
Protoform LTC-R
Old 03-09-2010, 01:38 PM   #13135
TheCoolCanFanMan's Avatar
Originally Posted by spencehotbodies View Post
Hello Skiddens
Cheers
Spence
Ya Mum was lmffao
ARC 2013 model ZEN Racing, MM-UK, HW 3.1, Rich Paints, MM UK Rug Racers win13.5 2007/8
2nd in 2008/9/10 Win Ansman GP 2010 Schumacher GP. 17.5 blinky Winner of STCC 2009/10 13.5 WLRC 2010 Summer series. Winner of EWS Winter. 17.5 Blinky Winner of 2012/13/14 Rug Racers. 17.5 Blinky 2013 WLRC summer series. Newbury RCC GP 2014 17.5 Blinky 2015 3rd in 17.5 Rug Racers
TheCoolCanFanMan is offline   Reply With Quote
Old 03-09-2010, 01:46 PM   #13136
razzor's Avatar
There was talk from Tekin not long after v203 was released about a revised software version with a better display, layout.
Any news on that Randy or Prez ???
Casterracing ZX1.5R
casterracing EX-1 Pro, SP Silver Arrow
TOP Racing Scythe, SP 17.5, SP GT Pro 2.0
TOP Racing Scythe, SP 4.5 V2, Hobbywing Xerun 120SD 2.0
TOP Racing Scythe, SP 13.5, Hobbywing Xerun 120SD 2.0
razzor is offline   Reply With Quote
Old 03-09-2010, 01:57 PM   #13137
Trader Rating: 26 (100%+)
Default Lipo cutoff
I have version 203, running 1s lipo and Life 6.6 rec pack. I have been advised to set the lipo cutoff at 3.2. Do I check the 1s lipo box in the programming or leave it unchecked?
svines1972 is offline   Reply With Quote
Old 03-09-2010, 02:07 PM   #13138
this would be great, the current UI is not very good.
gameover is offline   Reply With Quote
Old 03-09-2010, 02:16 PM   #13139
Hi mikky32
This has probably been asked before, but please can you tell me why, after around 3 to 3.5 mins does my car seem to die down the straight, it seems that the turbo dissapears.
My techs are:
Trinity Duo2 at 1 mark to the right of centre, which I believe to be 16+ degrees?
Geared at 7.9 on a 100ft length straight
Start RPM 4270
End 10000
Brake strength 75
Neutral width Min
Voltage cut off 2
Motor Type BL-FW
Throtel profile 3
Timing boost 45
Turbo Boost 15
Delay 0
The motor came off arnd 53 degrees at 3 mins, but I have heard that if you reduce the throtel EPA on on the handset from 150 to around 120 it cures this problem, is this true? as I have not had a chance to try this. Are there any other things I can do?
Cheers Malc
Old 03-09-2010, 02:19 PM   #13140
And would be good if you could save previous setup in a folder, instead of writing yet another tech sheet out.
Cheers Malc
Tekin Redline RS Sensored ESC and motors, opinions for offroad? Cain Electric Off-Road 4230 06-07-2015 04:38 PM
Sensored vs. Sensorless lemansracer Electric On-Road 71 02-14-2009 03:19 AM
New Tekin Redline Sensored Motors are Roar Legal! Randy_Pike Electric On-Road 3 08-05-2008 02:08 AM
Tekin Redline Sensored 10.5 HUCKMAN Electric On-Road 6 07-15-2008 08:50 PM
sensored vs sensorless bprocket Rookie Zone 5 05-16-2008 09:38 AM
Tags
v203, vegas 2.0
