Old 03-07-2010, 01:50 PM   #13051
WIITA's Avatar
Trader Rating: 42 (100%+)
Originally Posted by pcar951 View Post
Anyone getting any real speed out of the Nemesis 13.5 / 17.5's without cooking them. I'm running V203, I've tried everything but, the Nemesis for me is slow and gets real hot. Any help would be appreciated.
IMO sell it and buy a duo 2 or ballistic. I've been through the same thing.
Team CRC / Sanwa / Team scream / Genesis RC / Hobbywing / TQ Wire / Schelle / MIP / RC^2 / TEKNO / BoomRC
WIITA is offline   Reply With Quote
Old 03-07-2010, 02:09 PM   #13052
Originally Posted by 20 SMOKE View Post
motor middle-first line
What do you mean by this sentence? There is marks on motor that goes to + sign and there is one mark on motor end plate. So where should that mark be for good results?
I found my problem for no punch... it was one broken power cap leg... My mistake...
But now I have heat problem (I think so). Today on practice I was driving fast and my temps went to ~65C. I am using 2S LiPo with RS Pro and Duo 2 17.5 motor in WGT car and at the moment my settings are:
timing boost 35
turbo boost 5
delay 0,4
ramp 2
start ~1700
end ~10000
My roll out is about 52mm. If I do turbo 0 there is maybe 2-4 degrees lower motor temp but I loose speed on straight... There were some suggestions to go to 40-50 on timing boost but I chose to test lower numbers first and not cook motor or esc...
So I am looking how to lower motor temperature and not to loose speed. Any suggestions? Or maybe 60-70C is ok for Duo 2 motors?
Audrius
www.rc-cars.lt - offroad in Lithuania
www.lasa.lt - onroad in Lithuania
audriusv is offline   Reply With Quote
Old 03-07-2010, 02:13 PM   #13053
timing boost 35
turbo boost 5
delay 0,4
ramp 2
start ~1700
end ~10000
Motor temp may go up to 80C so no problem.
You have now a good motor temp.
http://www.mikky32.com
Tekin RS pro
TOP racing Photon
Tekin Redline 10,5
Protoform LTC-R
mikky32 is offline   Reply With Quote
Old 03-07-2010, 02:18 PM   #13054
20 SMOKE's Avatar
Trader Rating: 101 (100%+)
timing boost 35
turbo boost 5
delay 0,4
ramp 2
start ~1700
end ~10000
the marks were for a duo2 around 5-10deg motor what are the timing marks for a duo 1,try and move the start to the 2xxx,those temps are around 140 thats good
Jamie W
*Team Tekin*Tekno-rc*DE Racing*AKA*DDHRC*
20 SMOKE is offline   Reply With Quote
Old 03-07-2010, 02:19 PM   #13055
Trader Rating: 18 (100%+)
Send a message via AIM to Roberto Falcon
I'm not like this tekin. I've been having a problem with my car completly slowing down 3-4 min in a race or whatever. What's the deal about this ?
Roberto Falcon is offline   Reply With Quote
Old 03-07-2010, 02:20 PM   #13056
20 SMOKE's Avatar
do you mean you loose straight away speed,it may be the turbo add 10 to your throttle end point
Jamie W
Old 03-07-2010, 02:21 PM   #13057
O, I see. Sorry for being lazy. I just start to race. Today I can keep up with 4th guy in our club... I was so exited!
Thank you Tekin for very good products and thank you guys for answering even lazy questions!
Audrius
Old 03-07-2010, 02:33 PM   #13058
As it not is that the Turbo falls away than post here your setup and motor info and what you drive.
No problem.
Tekin RS pro
TOP racing Photon
Tekin Redline 10,5
Protoform LTC-R
Old 03-07-2010, 03:11 PM   #13059
2wdrive's Avatar
Like i already suggested a page or so back, lose the turbo, put 50 boost and lower your rollout to first 40mm or something and watch temperture. When it spools up too fast out of corner then the rollout is too low and you can put a bigger pinion on.
use the start ~1700 till 9000-10000 end rpm. As long as you lower your rollout it will be fine. Believe me, i drove 7 minute race and only had 45-50 degrees motor temp afterwards and had plenty of speed and out of the corners it just hammerd. I had throtle profile 4 on the esc. I am not a guy that likes to cook his motor and would never suggest anyone to use something that would do that. If you are still afraid to cook your motor then temp your motor after 2 minutes and do it after every 2 minutes or so while practising with this setting. You will see.
timing boost 35
turbo boost 5
delay 0,4
ramp 2
start ~1700
end ~10000
2wdrive is offline   Reply With Quote
Old 03-07-2010, 03:36 PM   #13060
it is fine and fast through the first 3 mins or so but falls on its face bad like litterly slows down completly like if your gonna blow up the motor but the motor is only about 160 deg at that point ..
tekin pro with a lrp x12 13.5
profile 5 .. turbo timing at 40 and boost at 10 end rpm at 12000 and start at 4600
ramp at 3
Old 03-07-2010, 03:42 PM   #13061
ramp at 3
As if you have no top speed any more?
If so set your EPA ad 90% recalibrate your radio and than set the EPA back to 100%. If not what is your Turbo delay?
And what is the timing on the LRP X12 motor standard?
Tekin RS pro
TOP racing Photon
Tekin Redline 10,5
Protoform LTC-R
Old 03-07-2010, 03:50 PM   #13062
Mark506's Avatar
ramp at 3
That seems a little to warm to any 1/12 around 160* at only 4 minutes.
Mark Ament
l MOMO USA l OZ Racing l Willwood Brakes | Dunlop Tires |
The Raceway at Beaver: Forever In Blue Jeans
Mark506 is offline   Reply With Quote
Old 03-07-2010, 03:54 PM   #13063
I think a Turbo ramp of 2 is enough and a bit higher turbo delay would do the trick.
Tekin RS pro
TOP racing Photon
Tekin Redline 10,5
Protoform LTC-R
Old 03-07-2010, 04:15 PM   #13064
CSaddict's Avatar
Anyone try to get a castle link working in place of a Hotwire? They are both just serial to USB converters I would think. Can anyone check your port settings that have a hotwire and let me know the baud rate when its hooked up?
Thanks.
TLR 22
Losi SCTE
Blitz Open
Xray T3 RCGT
www.rcmadness.freeforums.org
CSaddict is offline   Reply With Quote
Old 03-07-2010, 04:21 PM   #13065
i have a touring car... no it not just like it doesnt have top speed it just falls on its face like it i had no battery which im running a thunder power 5000 40c and theres a couple guys at the track thats happening to them aswell . my turbo delay is at 0.0
well i have a spectrum and i already did that trick i set my travel for my throttle to 140 and reset everything to radio and the esc then set it back to 150 and it still slowed down .. its like if the speedcontrol is shutting down or somthing.
Tekin Redline RS Sensored ESC and motors, opinions for offroad? Cain Electric Off-Road 4230 06-07-2015 04:38 PM
Sensored vs. Sensorless lemansracer Electric On-Road 71 02-14-2009 03:19 AM
New Tekin Redline Sensored Motors are Roar Legal! Randy_Pike Electric On-Road 3 08-05-2008 02:08 AM
Tekin Redline Sensored 10.5 HUCKMAN Electric On-Road 6 07-15-2008 08:50 PM
sensored vs sensorless bprocket Rookie Zone 5 05-16-2008 09:38 AM
Tags
v203, vegas 2.0
