Tekin RS ESC sensored > Tekin RS ESC sensored
Old 03-06-2010, 01:14 PM
  #13036
Trader Rating: 26 (100%+)
Default 12th scale 17.5
Can someone post a starting setup for the RS for 12th scale 17.5 1s lipo? Will be running on new Carpet 90 x 45.
svines1972 is offline
Old 03-06-2010, 06:10 PM
  #13037
dameetz's Avatar
Originally Posted by mikky32 View Post
A very short track for a 11,5T.
I use on a bit bigger track and a 10,5T this setup.
Boost 50
Turbo 10
Turbo delay 0
Turbo ramp 3
Start RPM 5000
End RPM 24000
7,8FDR
Watch the motor temp.
If it is to much power lower the Turbo ramp to 2 and the Boost to 45
I did this so I could hold it on the track.
Thanks Mikky, will try it out today.
dameetz is offline
Old 03-06-2010, 06:34 PM
  #13038
avs
avs's Avatar
check tekin's website, there are some good starting points there. also there is a 1s tekin thread with a lot of good info
avs is offline
Old 03-06-2010, 09:26 PM
  #13039
carcrazy699's Avatar
Trader Rating: 48 (100%+)
ok need alittle help. i just installed a duo2 17.5 motor and tomarrow im going to be running it.
the track size is 170x70 i beleve.
esc settings are
throttle 5
timing 45
turbo max
turbo ramp 3.0
delay .1
start rpm 1275 (i think)
end rpm 8500
so i was woundering if this sounds ok on a cyclone s with 18t pullies and 96/40 gears.
i just got this motor so my settings are for my old motor
carcrazy699 is offline
Old 03-06-2010, 11:15 PM
  #13040
I have just purchased a new Tekin RS which I intend on connecting a Speedpassion Ultra sportsman 17.5.
Question if I upgrade to the latest 203 software what is a safe place to start, the car I use is a Corally Phi 09.
The Track is approx 110x45 .
Thanks in advance
Michael
miku is offline
Old 03-07-2010, 04:35 AM
  #13041
20 SMOKE's Avatar
Trader Rating: 101 (100%+)
esc settings are
throttle 5
timing 45
turbo max
turbo ramp 3.0
delay .1
end rpm 8500
motor middle-first line
timing boost 45
turbo boost 10
delay 4
ramp 2
start 2xxx
end 12500
fdr 5.7-6.0
20 SMOKE is offline
Old 03-07-2010, 05:58 AM
  #13042
defcone's Avatar
Trader Rating: 15 (100%+)
timing boost 45
turbo boost 10
delay 4
ramp 2
start 2xxx
end 12500
fdr 5.7-6.0
Would this set up be good for duo 1's as well?
defcone is offline
Old 03-07-2010, 07:02 AM
  #13043
pcar951's Avatar
Trader Rating: 20 (100%+)
Anyone getting any real speed out of the Nemesis 13.5 / 17.5's without cooking them. I'm running V203, I've tried everything but, the Nemesis for me is slow and gets real hot. Any help would be appreciated.
pcar951 is offline
Old 03-07-2010, 07:24 AM
  #13044
wingracer's Avatar
Trader Rating: 24 (100%+)
Try less timing. If that cools it off but it still isn't fast, go up on the pinion.
I still prefer the duos and Tekins myself.
wingracer is offline
Old 03-07-2010, 08:09 AM
  #13045
How is the Tekin compared to the DUO?
mikky32 is offline
Old 03-07-2010, 08:24 AM
  #13046
Trader Rating: 23 (100%+)
they are amazing. Ice cold on min after 5 min and it runs so insane that it just is a rocket down the straight
tdt1805 is offline
Old 03-07-2010, 08:32 AM
  #13047
mangoman's Avatar
Theres a nemesis thread somewhere. They say that the nemesis does NOT like high timing (including esc timing). It also says they do not like heat, not sure if that means they die permanently when they get hot or just go soft real quick for the rest of the run.
mangoman is offline
Old 03-07-2010, 09:44 AM
  #13048
20 SMOKE's Avatar
try it,just temp half way through a run,what is the timing on the duo 1 i never ran one
20 SMOKE is offline
Old 03-07-2010, 10:05 AM
  #13049
wingracer's Avatar
So far, I find the Duo can take a bit more gear, giving me better straight speeds without the laptimes falling off. On my track's current fast layout, it's a bit quicker. The Tekin seems to have great infield rip which may be the way to go when they go with a super twisty layout. I'm still experimenting though.
Old 03-07-2010, 10:25 AM
  #13050
Ok so they are very close to each other.
The Duo wins on the straight and the Tekin in the infield.
I'm going to order a Tekin 13,5T. We have a technical track. My 10,5T went good but I heard good things about the DUO motors so that's why I asked.
mikky32 is offline
