Old 03-05-2010, 08:08 PM   #13006
Originally Posted by Goingfast View Post
Question;
How fast can the 10.5 with turbo compare to what low turn motor without turbo on?
I have tried this back-to-back for comparsion:
Sensored-mode with Turbo w/ 11.5R (boost:50, turbo:5, delay:0.4s, S:3000ish, E:14000ish)
Dual mode with 7.5R (timing advance:80)
Both motors do not have adjustable timing.
They are about equal in speed. 11.5R was a little easier to drive because it was not as punchy as the 7.5R. However, the temp for 11.5R was about 65C while the 7.5R was about 40C. Outside temp was about 14C.
This was on a medium sized track, touring. Both FDR were about the same, around 7.8ish.
hardmankam is offline   Reply With Quote
Old 03-05-2010, 08:23 PM   #13007
whynot's Avatar
Trader Rating: 18 (100%+)
Hello I will be running v203 for the first time tomorrow at the roar regional championship and was wondering what a good set up would be for this track layout. what would be a good round about roll out to start with also.track size is 90x40 feet
thanks very much in advance
duo 2---17.5
1s 12 scale
tq booster
whynot is offline   Reply With Quote
Old 03-05-2010, 08:46 PM   #13008
Still Bill's Avatar
Originally Posted by theisgroup View Post
i must be dense. how does that relate to 1s math?
Oh boy! Could I have fun with that statement!
Constantly evolving CRC WGT and WGT-R/T...Carpet & Asphalt...All thanks to Team CRC.
And a pair of Associated B6 buggies for turf and clay tracks.
Still Bill is offline   Reply With Quote
Old 03-05-2010, 09:28 PM   #13009
20 SMOKE's Avatar
Trader Rating: 101 (100%+)
Originally Posted by Akudou View Post
Can the RS Pro be able to run sensorless motor?
yes,that is why we set the timing advance to 100 so if we loose a sensor wire we will be in sensorless mode and still get some timing
Jamie W
*Team Tekin*Tekno-rc*DE Racing*AKA*DDHRC*
20 SMOKE is offline   Reply With Quote
Old 03-05-2010, 09:58 PM   #13010
carcrazy699's Avatar
Trader Rating: 48 (100%+)
Originally Posted by Doog View Post
The Cyclone TC has a 39 tooth diff pulley and a 18 tooth layshaft pulley, so this might account for your difference in speed if you have a 17 tooth layshaft pulley. With 39T diff pulley, 17T layshaft pulley, 96T spur and 40T pinion, your FDR is 5.506 while the TC with the same except for 18T layshaft pulley has a 5.2 FDR.
my laysaft pullies on my cyclone are the 3racing pullies where i can change from 16t-17t-18t. im putting the 18 tooth on since i just got the tc belts so i am going to be the same fdr i hope. i know my car weighs alittle more since its the cyclone s. im just starting to think that my motor might be getting tiered or i need to give it a good cleaning
carcrazy699 is offline   Reply With Quote
Old 03-05-2010, 11:26 PM   #13011
It does not ,it relates to the 128, 256, 512 math. As they want fast computation in the unit they are using RPM numbers that work good with computer chips.
goos is offline   Reply With Quote
Old 03-06-2010, 06:17 AM   #13012
theisgroup's Avatar
uhmmm, yeah, i am not talking 1s as in lipo, i ment 1s math as in binary math as in multiple 1's
yang lai
Team Tamale | Team Tekin | RCAmerica | Speedmerchant | Speedzone RC | EA Motorsports | Ko Propo USA | eXpress Motorsports | Parma/PSE
theisgroup is offline   Reply With Quote
Old 03-06-2010, 07:02 AM   #13013
B4james's Avatar
New shell I just painted up for the Xray, all the Tekin logos are hand painted
Follow me on Facebook - James Ainslie Designs or on Instagram - JA_Designs
*HEI International for Protoform/Proline/Spaz Stix
*Bitty Design Australia for Bodies and Liquid Mask
* Airbrushmegastore.com for all paint and airbrush supplies
B4james is offline   Reply With Quote
Old 03-06-2010, 07:19 AM   #13014
Trader Rating: 10 (92%+)
you might need to a new blue body when the sxx ss start popping up around soon
captain stacker is offline   Reply With Quote
Old 03-06-2010, 07:21 AM   #13015
B4james's Avatar
you are right on one thing, that being a new body everytime the LRP goes up in smoke and melts the shell
Old 03-06-2010, 07:49 AM   #13016
20 SMOKE's Avatar
NICE LID JAMES,that should be shelved ts to nice to run
Jamie W
Old 03-06-2010, 08:42 AM   #13017
B4james's Avatar
Thanks Jamie, yeah sometimes it gets like that and you cry the first scrape it gets lol
Old 03-06-2010, 09:08 AM   #13018
wingracer's Avatar
Trader Rating: 24 (100%+)
how do you guys run setups like this? I can barely get 50timing and 10 turbo in a 1/12, how can you do max turbo and 50 boost and not melt down the motor? amazing!!!
Sounds like you are finding the same thing I am. I am running 1/12th 10.5. I find anything over 55 combined boost and turbo does not work for me. This is with both a Tekin motor and a Duo. Sure I could run more but laptimes fall off hard and heat becomes an issue. I have even dumped a couple times. If I drop the rollout to compensate, the car is noticeably slower. More rollout with less timing seems to work much better for me. Here is what I ended up with at the last race. I was leading with it until the car's handling went haywire.
Medium sized carpet track with decent grip and a fairly fast layout.
Duo 1 10.5 in the first hole (least timing)
Boost 45
Turbo 9
Delay .6
ramp 1 (runs cooler and no slower vs. 2 and 3)
Start rpm 2xxx
End rpm 10000
rollout 67mm. Anything under about 64 results in slow straight speeds no matter how much timing I put in it.
I should also point out that the only guy with a faster laptime than me is running even less timing. More timing does not always equal more speed.
Sean. Certified speed crazed mowron.
Team Shepherd USA
www.ashfordhobby.com
wingracer is offline   Reply With Quote
Old 03-06-2010, 10:12 AM   #13019
Very nice body James.
http://www.mikky32.com
Tekin RS pro
TOP racing Photon
Tekin Redline 10,5
Protoform LTC-R
mikky32 is offline   Reply With Quote
Old 03-06-2010, 10:38 AM   #13020
Akudou's Avatar
2 units of Rs pro with the hotwire will be arriving for me n my friend in 2 days. I read alot about it and decide to go for it instead of the LRP Sxx and black diamond. I have the software ready in my pc and am just waiting for it to arrive. Is anyone kind enough to share previous settings on the rs pro hotwire (203) in previous races or setup? I love the function but ofcourse would not like to blow it just incase i did the worng setting to make it fast. Our track here are Asphlat with 50meters straight with lots of technical sharp curves. Motor class race here are Mod, Stock 11.5t and sometimes novice stock 9T. I have succesfully won the novice class using 107 SP firmware with ease and ofcourse i would like to have another victory but using only 11.5t setting on the tekin. So is anyone kind enough to share lots of setting which could help me out please?
Akudou is offline   Reply With Quote
Tekin Redline RS Sensored ESC and motors, opinions for offroad? Cain Electric Off-Road 4230 06-07-2015 04:38 PM
Sensored vs. Sensorless lemansracer Electric On-Road 71 02-14-2009 03:19 AM
New Tekin Redline Sensored Motors are Roar Legal! Randy_Pike Electric On-Road 3 08-05-2008 02:08 AM
Tekin Redline Sensored 10.5 HUCKMAN Electric On-Road 6 07-15-2008 08:50 PM
sensored vs sensorless bprocket Rookie Zone 5 05-16-2008 09:38 AM
Tags
v203, vegas 2.0
