Old 03-02-2010, 12:19 AM   #12811
Krio's Avatar
Trader Rating: 150 (99%+)
Originally Posted by 303slowdown View Post
Krio thanks for the reply. The reciever pack has a switch on it i dont turn the switch on on the speedo. This only happens sometimes do you think i should try a different reciever?
I would suggest looking for a frayed signal or ground wire first between the RS and receiver.
Then I would suggest turning the esc on along with the receiver pack before swapping out the receiver. However, make sure you remove the red pin on the esc so that there aren't two sources of voltage at the receiver. As it sits now you are powering the internals of the RS off the receiver pack since you are not turning the esc on. This also means that the voltage cutoff is not active.
What most people do is create a short jumper cable from the receiver to the lead coming off the RS and just cut the red wire. The black and white wires are all you need for the RS to receive a signal.
www.kriostasis.com
Krio is offline   Reply With Quote
Old 03-02-2010, 12:24 AM   #12812
avs
avs's Avatar
Im having a problem with one of my RS's ,what it does is sometimes at the start of the race it wont go at all and all the lights will be flashing , other times its fine. I've tried changing neutral with and recalibrating my radio too. What else can i try before i send it in. By the way its in a 13.5 1/12th scale running a reciever pack.
Thanks Ryan
i have gotten all lights flashing for 2 reasons, onc i forgot the plug the receiver wire back in. or if the battery voltage cutoff is set too high.
Tony Shimko
avs is offline   Reply With Quote
Old 03-02-2010, 12:30 AM   #12813
Senna Racing's Avatar
Originally Posted by Randy_Pike View Post
I also would love to see those pics: [email protected]
randy i will send you the pics as soon as i land tomorrow
but here is the setup i found worked best
0 drag break
2 lipo
timing 50
turbo max
ramp 2
start 4000
end 10000
8 deg on the can
fdr 6.01 for 416x with a rollout of 32.89mm
fdr was a little higher for the for the t3 xray
Feral Batteries for all your on road needs
TRF 416, Fantom Batteries, Sorex, Tekin
Senna Racing is offline   Reply With Quote
Old 03-02-2010, 12:53 AM   #12814
Dusttt's Avatar
Trader Rating: 123 (100%+)
anyone know the kv ratings on the redline 6.5 and 5.5? I cant find them listed anywhere.
Dusttt is offline   Reply With Quote
Old 03-02-2010, 01:10 AM   #12815
HyperFX's Avatar
Send a message via AIM to HyperFX
Oops. Deleted.
4PK, DEX410, DESC410R, DEX210, Tekin RS/RS Pro/RX8, Ten SCTE, XXX-SCT, XXXT-CR, XXX, XX, JRx2
MOTOCROSS: Because Roller Coasters Are Too Slow!
HyperFX is offline   Reply With Quote
Old 03-02-2010, 06:27 AM   #12816
Regional Moderator
Jon Carlson's Avatar
Trader Rating: 48 (100%+)
Just to clarify, I think he is saying use an extension wire from the receiver to the RS and cut the wire in the extension. I wouldn't cut any wires on the RS lead. Although, I don't think you need to unplug the red wire because it won't hurt the receiver. The two voltage sources are being supplied to the receiver in parallel so the max you'll see at the receiver is the input from the receiver pack.
Jon Carlson
Team Associated, Reedy
Futaba, OS Engines, O'Donnell Racing Fuel
Jon Carlson is offline   Reply With Quote
Old 03-02-2010, 06:55 AM   #12817
theisgroup's Avatar
0 drag break
2 lipo
timing 50
turbo max
ramp 2
start 4000
end 10000
8 deg on the can
that is over 80 degress of timing on the motor. man, i am surprised it is not spinning backwards. lol
yang lai
Team Tamale | Team Tekin | RCAmerica | Speedmerchant | Speedzone RC | EA Motorsports | Ko Propo USA | eXpress Motorsports | Parma/PSE
theisgroup is offline   Reply With Quote
Old 03-02-2010, 06:55 AM   #12818
Satish's Avatar
Hello,
Have a few questions.
Is anyone having problems regestering on tekin forum today?
I enter in all the info but then it just goes back to registration page, no errors on page?? I'll try again later, but just wondering.
My issue is with myTekin RS.
I am running 1cell lipo, with novak booster and Tekin 10.5 redline in 12scale.
Hooked it up lastnight and am getting intermitant throttle, I pin it and the leds move like there are supposed to but the motor does not move.
If i squeeze trigger slowly the motor kinda moves but stutters.
Steering servo works fine.
Leds on RS are not blinking in any pattern, i checked the troubleshooting page.
I changed my receiver same problem, tryed another motor and sensor wire, same issue.
Checked all wires, motor wires connected correctly etc. I just used the car 1 week ago with no problems
Reset to factory defaults- same prob
Re-calibrated my DX3R didnt resolve issue.
Am I looking at a return and repair, did i miss something?
thoughts, suggestions??
Thanks in Advance,
Satish
Satish is offline   Reply With Quote
Old 03-02-2010, 07:19 AM   #12819
Stephtruc's Avatar
Hi,
Just received my new esc (and hotwire)
Updated to 203
Searching for good starting point set up for 1/10 touring indoor carpet medium to large track, medium to hight grip, SP V3 10.5T Motor (5.60 ratio), rubber sweep 36 tires...
If you could help me....
Thx
Stephtruc is offline   Reply With Quote
Old 03-02-2010, 07:31 AM   #12820
Originally Posted by cannon View Post
Randy
One of the guys has it on his phone. When we get back I will get it off him and post. Hopefully it is clear enough.
I believe Scoty Ernst also saw it
great
0 drag break
2 lipo
timing 50
turbo max
ramp 2
start 4000
end 10000
8 deg on the can
What was your Turbo delay?
I now that the Speedpassion V3 works ad it's best with a high motor timing, but with so much total timing I didn't now.
What was the motor temp?
http://www.mikky32.com
Tekin RS pro
TOP racing Photon
Tekin Redline 10,5
Protoform LTC-R
mikky32 is offline   Reply With Quote
Old 03-02-2010, 07:59 AM   #12821
hacker's Avatar
Trader Rating: 141 (100%+)
Default duo2 gearing
do duo2's require different gearing compared to novaks, sp etc?
I've been running a novak 17.5 at 6fdr, last night bolted in a duo2 17.5 and it ran hot and slower. Played around with motor timing(0-40) but still feels lacking compared to my novak.
normal setup
4/12krpm, 0 delay, 3ramp, 50boost, 10 turbo.
Lowering boost, ramp, turbo, widened rpm band help bring the temps down abit, but obviously ran alot softer than the already slow duo2.
I'm hoping I didnt get a friday motor, cos of all the good feedback ive heard from duos/2.
hacker is offline   Reply With Quote
Old 03-02-2010, 08:43 AM   #12822
TrevCoult's Avatar
Originally Posted by Satish View Post
Hello,
Thanks in Advance,
Satish
People have been having problems with the Novak booster. It might be the cause of your problem. Try either an RX pack, TQ booster or better still RC Dynamics booster.
Trev
Schumacher Atom GT12
Schumacher Eclipse 12th
www.carsrcracing.co.uk
CARSrcracing.co.uk Webmaster
Schumacher Racing
TrevCoult is offline   Reply With Quote
Old 03-02-2010, 08:58 AM   #12823
Satish's Avatar
Trev
Even though LEDS are working correctly? Could it still not work and the LEDS function as per normal?
Old 03-02-2010, 08:58 AM   #12824
M-Technic's Avatar
Trader Rating: 15 (100%+)
normal setup
Duo2's are typically setup different than Novak motors. I have a good setup for a Duo2 17.5 for a large (150x80ft.) asphalt track posted here:
http://www.rctech.net/forum/7039252-post12511.html
RCAmerica | Xray | Hudy | Radiopost | Speed Passion USA | Trinity | P3 Graphics
M-Technic is offline   Reply With Quote
Old 03-02-2010, 09:05 AM   #12825
Trader Rating: 10 (92%+)
wrong post
captain stacker is offline   Reply With Quote
Tekin Redline RS Sensored ESC and motors, opinions for offroad? Cain Electric Off-Road 4230 06-07-2015 04:38 PM
Sensored vs. Sensorless lemansracer Electric On-Road 71 02-14-2009 03:19 AM
New Tekin Redline Sensored Motors are Roar Legal! Randy_Pike Electric On-Road 3 08-05-2008 02:08 AM
Tekin Redline Sensored 10.5 HUCKMAN Electric On-Road 6 07-15-2008 08:50 PM
sensored vs sensorless bprocket Rookie Zone 5 05-16-2008 09:38 AM
Tags
v203, vegas 2.0
