Old 03-01-2010, 08:27 PM   #12796
Still Bill's Avatar
Originally Posted by xray2050 View Post
Yes I reset the radio. I originally thought it was a radio problem so I tried it with another guys radio at the track that was running an RS and it still had no punch.
Did you then set the RS to the radio?
Constantly evolving CRC WGT and WGT-R/T...Carpet & Asphalt...All thanks to Team CRC.
And a pair of Associated B6 buggies for turf and clay tracks.
Still Bill is offline   Reply With Quote
Old 03-01-2010, 08:50 PM   #12797
Regional Moderator
Jon Carlson's Avatar
Trader Rating: 48 (100%+)
Originally Posted by mike ivy View Post
Anyone have a 13.5 WGT setup? The motor im using is a Duo 1 on a 100x40 ish track.
Middle hole on the motor, 45 Boost, no turbo, throttle profile 3 or 4, 100 brake, 10 nuetral threshold, rollout at 2.558
Anything I missed?
Jon Carlson
Team Associated, Reedy
Futaba, OS Engines, O'Donnell Racing Fuel
Jon Carlson is offline   Reply With Quote
Old 03-01-2010, 09:07 PM   #12798
xray2050's Avatar
Trader Rating: 14 (100%+)
If you mean the neutral/full forward/full brake, set-up. Yes
Pete Elphinstone
RC America, HUDY, XRAY, JACO, Performance Hobbies, WERKS RACING, www.speedzoneusa.com, Sweep Racing USA
xray2050 is offline   Reply With Quote
Old 03-01-2010, 09:22 PM   #12799
Still Bill's Avatar
Anything I missed?
IMO...Don't agree with the middle hole on the Duo 1 for WGT. Let the RS do the timing advancing.
The rest is doable; but, turbo can be easily used on a 80' plus long track...Come to NorCal. We will be happy to show you...LOL
Drag brake?
Voltage cutoff (Off; but, always unplug the battery after a run for safety.)
Push control?
1S lipo (Checked)
Turbo delay?
Sensored (Checked)
End RPM?
Start RM?
Turbo ramp?
Use a servo battery pack. I like the Trinity/Epic 220mah Li-Fe battery pack (Unplug it too.)
It's a package!
Bill
Old 03-01-2010, 09:28 PM   #12800
Still Bill's Avatar
Your signature list says KO. Is that your radio? Where is the HighPoint set when you are setting your RS?
Still just going through the possibilities...LOL
Bill
Old 03-01-2010, 09:38 PM   #12801
Regional Moderator
I liked the 10 degrees on the motor, I feel that it pulled just a little harder than 0. I may experiment more but with these settings I got alot of compliments on how fast the car was and I never lost a step to anyone on the infield.
Yes, I was just giving my settings off the top of my head. On 100' you could use turbo, I'd start with 5.
I'll put my settings here. Why didn't you give yours Bill?
Drag brake?
Push control?
1S lipo (Checked)
Turbo delay?
Sensored (Checked)
End RPM?
Start RM?
Turbo ramp?
It's a package!
Bill
DB None.
Voltage Cutoff is off.
Push Control None.
1s Checked
Turbo Delay 2-3 but since I wasn't using turbo this was irrelevant.
Sensored Checked for sure.
End Rpm 7500
Start Rpm First option... like 800 I think it was.
Turbo Ramp 1
Yes I also use a receiver pack, I may try one of the RCDynamics boosters out when I can get one though. Any other questions feel free to ask.
Jon Carlson
Old 03-01-2010, 10:30 PM   #12802
303slowdown's Avatar
Trader Rating: 24 (100%+)
Im having a problem with one of my RS's ,what it does is sometimes at the start of the race it wont go at all and all the lights will be flashing , other times its fine. I've tried changing neutral with and recalibrating my radio too. What else can i try before i send it in. By the way its in a 13.5 1/12th scale running a reciever pack.
Thanks Ryan
303slowdown is offline   Reply With Quote
Old 03-01-2010, 10:35 PM   #12803
Still Bill's Avatar
Jon,
I was trying a address Mike Ivy's stated WGT car and track description (which is comparable to my local carpet track at NorCal Hobbies).
What WGT car do you have and general size of track are you running on? Asking because I have not yet run on anything shorter or longer...And I do expect big differences in RS settings between track sizes.
Bill
Old 03-01-2010, 11:15 PM   #12804
Still Bill's Avatar
I already tried Novak and TQ boosters. Both are convenient; but, I have had better 6 minute run stats after switching to the Li-Fe pack.
Bill
Old 03-01-2010, 11:19 PM   #12805
xray2050's Avatar
Bill
The first time I did it I dropped the high point to 140 (max is 150) Each time after reseting I would drop it even lower. I got as low as 115. There doesn't seem to be a problem with it going fast and having the boost once the car gets going it is really fast but that initial punch no matter if it is from a dead stop or rolling through a corner the car just has no punch. Almost as if the current limiter is set to max limit, but I have that set to zero so there should be no limiter. Everything that limits initial punch or neutral dead band has been set so there is no delay. When we did adjust for some delay it was even worse.
Pete Elphinstone
Old 03-01-2010, 11:42 PM   #12806
Krio's Avatar
Trader Rating: 150 (99%+)
Thanks Ryan
All the lights flashing means the esc is not seeing any signal coming from the receiver. How are you powering up every race?
www.kriostasis.com
Krio is online now   Reply With Quote
Old 03-01-2010, 11:43 PM   #12807
Still Bill's Avatar
Pete,
I initially set my HiPoint to 140 and then to 150 after setting the RS.
That's per Robert at KO.
Bill
Old 03-01-2010, 11:46 PM   #12808
Regional Moderator
Jon,
Bill
I am running the CRC GenX 10, 75x40 track. I wasn't running Turbo at that track but after you mentioned it I remembered that Mike's was 100' and I agreed that Turbo would work there.
Bill
I've heard too many bad things about the Novak and the TQ is ok, although I haven't tried it. I'm running a lipo with a regulator now. I've heard very good things about the RC Dynamics booster though. It's worth a shot.
Jon Carlson
Old 03-01-2010, 11:47 PM   #12809
Krio thanks for the reply. The reciever pack has a switch on it i dont turn the switch on on the speedo. This only happens sometimes do you think i should try a different reciever?
Old 03-02-2010, 12:09 AM   #12810
Still Bill's Avatar
With a bit of a flyer onto a 75 foot straight, you can engage turbo.
Off topic...Is your RS ESC to one side (and car balanced side-to-side) or directly behind the battery (in-line). Just went away from the in-line layout with great results...and lower lap times.
I want every bit of the juice coming out of my 1S pack through my RS and on to the motor. Not powering servos, ESCs or booster boards. Makes a big difference for lap times during the later part of a run. Li-Fe pack is a great solution.
Bill
Tekin Redline RS Sensored ESC and motors, opinions for offroad? Cain Electric Off-Road 4230 06-07-2015 04:38 PM
Sensored vs. Sensorless lemansracer Electric On-Road 71 02-14-2009 03:19 AM
New Tekin Redline Sensored Motors are Roar Legal! Randy_Pike Electric On-Road 3 08-05-2008 02:08 AM
Tekin Redline Sensored 10.5 HUCKMAN Electric On-Road 6 07-15-2008 08:50 PM
sensored vs sensorless bprocket Rookie Zone 5 05-16-2008 09:38 AM
Tags
v203, vegas 2.0
