Old 10-17-2008, 12:09 AM   #1261
Trips's Avatar
Trader Rating: 16 (100%+)
Geez,
While the default mode is indeed hybrid, it is my understanding that checking the box ono the hotwire screen locks you into sensored only mode, disabling the "sensorless" part of hybrid mode. To my knowledge, there isn't any pure sensorless mode on the RS (although you could force one by leaving the sensor cable disconnected if you really wanted it)
I could be mistaken, but I believe this is correct... someone from Tekin feel free to correct me...
By the way, this past weekend, I got my best times yet with the car, going from 112/53 to 114/53 seemed to do it... A tenth better on my best laps, and motor temp 164 after five minutes. Feels like I'm in the sweet spot now... Car is a Losi type R running rubber tires on carpet. Final drive is 3.93
for anyone interested:
Motor Tekin 17.5 Redline
Speedo RS
Hybrid mode
drag brake 45
brake strength 80
deadband 10
fwd only
throttle curve 3
cutoff 6v (2c lipo)
push control 0
timing 100
MARSHAL!!
Trips is offline   Reply With Quote
Old 10-18-2008, 04:45 AM   #1262
mazmo's Avatar
Default Orion Vortex 10.5T
Hey guys / Randy,
Anyone used an Orion Vortex 10.5T, if so would appreciate profile details for RS Pro.
Had my 1st run with RS Pro with Orion Vortex 10.5T yesterday, some issues with heat.
Initially used sensored only mode with full motor timing & fdr 5.13, quick but too hot ... 190f.
A guy at same track used same set up with Redline 10.5T ... no issues with max temp 135f. Perhaps the Orion has more motor timing built in ?
Ended up using Hybrid mode with temp of 165f ... but felt a bit "soft".
Would appreciate any advice
This is the last profile I used:
5.70fdr
Orion Vortex 10.5 w/with motor timing set "middle"
hybrid mode
drag = 80
rev = 0
brake = 90
neutral = 10
blfw
throt = 5
volt = 2
push = 0
timing = 100
current = off
Cheers
Alan
mazmo is offline   Reply With Quote
Old 10-18-2008, 06:39 AM   #1263
mangoman's Avatar
Mazmo, i think you will find that 10.5s do no like being run at 100 timing. I suggest you change the timing so it is a maximum of 90, but you will need to play with the setting.
I think you will find that the ideal timing will be somewhere around 80-90
Hot Bodies Cyclone!!!
www.smaracing.org
www.rchobbies.com.au - www.feralbatteries.com.au
craig mcphee ( WHERE'S MY BEER )
mangoman is offline   Reply With Quote
Old 10-18-2008, 05:15 PM   #1264
mazmo's Avatar
Thanks mangoman,
Will give that a try I did try the hotwire default of 72% for 10.5T but seemed to lack punch.
On another note, the RS Pro temp was about 135f. Not sure if this is normal as other esc's I have tried don't seem to get that warm.
Old 10-18-2008, 05:17 PM   #1265
RC MARKET's Avatar
Tekin will ready release alum case for keep lower temp .
RC MARKET is offline   Reply With Quote
Old 10-18-2008, 07:29 PM   #1266
mangoman's Avatar
To me 135F isnt that hot, but have you checked the lights flashing for temperature after a run?
It seems that a little heat seems to get trapped in the case (hence the aluminium one which is in the works, but should only be necessary for mod) however i can tell you now my R1 Pro (which is kind of like the RS) when i ran it in mod was a LOT hotter than that!
Keep in mind that most other escs have active cooling in the way of fans. In fact if you end up running mod you really should be running a fan over the solder posts (which act as heat sinks for cooling).
www.smaracing.org
Old 10-19-2008, 03:03 AM   #1267
mazmo's Avatar
Default Rollout & fdr 10.5T
Just starting up ion 10.5T.
What fdr & rollout would be best suited to 10.5T on small track ... approx 20m x 90 m ?
I am using RS Pro in hybrid mode.
Old 10-19-2008, 03:11 AM   #1268
mazmo's Avatar
I have been checking the esc after each run but have not seen any lights flashing. Will the esc do this on it's own ?
Old 10-19-2008, 05:44 AM   #1269
1M
1M's Avatar
Trader Rating: 35 (100%+)
Had good night of racing on the dirt oval. I ran rs pro with a redline 17.5 in EDM big block and rs with 13.5 redline in The sprint car. Both cars TQ'd in each class and finished 1st. Proud of my 10 year old son who finished 2nd in sprint car class. He is still running orange but as soon as I get a replacement he will be driving Tekin ESC and motor.
http://www.dirtoval.com/forums/showthread.php?t=33359
Bob
1M is offline   Reply With Quote
Old 10-19-2008, 07:31 AM   #1270
Trips's Avatar
You're actually going to replace your kid for running a Novak?? Wow, that's HARSH...
MARSHAL!!
Old 10-19-2008, 07:34 AM   #1271
1M
1M's Avatar
LOL not really. I will be replacing his ESC and motor soon.
Old 10-20-2008, 04:04 PM   #1272
Trips's Avatar
Randy, it's been quite some time now, any chance you can answer this??
http://www.rctech.net/forum/4948223-post1256.html
MARSHAL!!
Old 10-20-2008, 04:06 PM   #1273
Super Moderator
Kraig's Avatar
Trader Rating: 71 (100%+)
Randy was at the iHobby show in Chicago for the past couple of days. Probably needs a couple more days to get situated.
There is great need for a sarcasm font.
You never know when it will strike, but there comes a moment at work when you know that you just aren't going to do anything productive for the rest of the day.
Sometimes I post just to look at my avatar.
Kraig is offline   Reply With Quote
Old 10-20-2008, 06:51 PM   #1274
Jsaves's Avatar
Put in my new RS this last weekend. I raced it with a 17.5 redline in a TC5.
I was on the phone with the tekin techs twice, they were great and very helpful and great hours. I was a little nervous about programing it, no hot wire, but it went very smooth. I am a big tekin fan now. In fact a racing buddy who got the RS pro says he is now a tekin fan also.
Thanks guys for a great product.
God Bless
Proud member of Magic City RC Racers
Magic City R/C (Facebook)
CRC GT-R
CRC WTF-1
Jsaves is offline   Reply With Quote
Old 10-20-2008, 09:13 PM   #1275
Team Tekin
Randy_Pike's Avatar
Send a message via Yahoo to Randy_Pike
Sorry for the delays guys. I was indeed in Chicago at the Ihobby expo.
Just to clarify. Some people though you needed to use a profile that wasn't "on" so to speak simply to make adjustments. That's not true.
If you are in TP 3 and want to change ANY of the functions(except for TP's of course) you can and it will change in the esc IF you see the window pop up asking for verification of the change. This has to be done. If you don't see the window pop up it won't take.
TP settings change the linearity of the throttle ramp. 3 being linear.
So bottom line is to change 'em all you want. The TP settings that are "open" are left for full customizable profiles to be switched back and forth via not only the Hotwire but the esc itself on the fly.
Hope that clears it up.
And yes if you want a "true" sensorless you have to choices. Run a sensorless motor or unplug the sensor harness.
"Things may come to those who wait, but only the things left by those who hustle." Abraham Lincoln
Tekin,Protek,A-Main Hobbies,JConcepts,Avid RC,Yokomo,MIP,SikLidz,FactoryRC, www.randypikerc.com
Randy_Pike is offline   Reply With Quote
Tekin Redline RS Sensored ESC and motors, opinions for offroad? Cain Electric Off-Road 4230 06-07-2015 04:38 PM
Sensored vs. Sensorless lemansracer Electric On-Road 71 02-14-2009 03:19 AM
New Tekin Redline Sensored Motors are Roar Legal! Randy_Pike Electric On-Road 3 08-05-2008 02:08 AM
Tekin Redline Sensored 10.5 HUCKMAN Electric On-Road 6 07-15-2008 08:50 PM
sensored vs sensorless bprocket Rookie Zone 5 05-16-2008 09:38 AM
Tags
v203, vegas 2.0
