Old 02-26-2010, 06:39 PM   #12706
Originally Posted by DaredevilD View Post
Anyone have a good profile for a 17.5 rubber on carpet? I am running a Trinity duo. I have geared from a 5.4 to a 6.2. ESC settings are 45 timing 10 turbo,delay.1,ramp speed 2.0,throttle profile 5,end rpm 10000 and start 5800. I am running on a 60x100' track pretty flowing. I can not get out of the 160 to 170 deg temp. I want to cool this motor down a bit. Also seems to fall off quite a bit at the 4 min mark. Any help would be great. Thanks
Higher the Turbo delay to 0,5
Set your start RPM around 2500
end RPM is on 10000 ok
Timing boost on 50.
http://www.mikky32.com
Tekin RS pro
TOP racing Photon
Tekin Redline 10,5
Protoform LTC-R
mikky32 is offline   Reply With Quote
Old 02-26-2010, 06:55 PM   #12707
el salvador's Avatar
Darren, try Jason Schreffler's Snow Birds 13.5 setup on your 17.5 w/the gearing you are using now. My car comes off the track 135-145F, car is plenty fast.
BTW, might just try his Birds setup for the Photon as well, looks interesting.
ARC R8 X2/ Max RP9 or O.S. R2101 ,Capricorn LAB C02-TOP Elite R, ARC R11....
"Every Cemetery in Chicago Votes Democrat!"
el salvador is offline   Reply With Quote
Old 02-26-2010, 07:02 PM   #12708
rx7ttlm's Avatar
Trader Rating: 30 (100%+)
You don't want to ask me for mine....
|Team Xray | RC America |MAX Engines | Hudy |Jaco | KO PROPO |"From Slovakia with Love" T3 | Team Timezone |
Timezone Raceway & Hobbies - http://www.timezonehobbies.com
rx7ttlm is offline   Reply With Quote
Old 02-26-2010, 07:31 PM   #12709
I tried that it was fast and quite aggressive.
eXpress Motorsports
Timezone 2,Timezone Raceway Park,Rose City Scale Racing.
DaredevilD is offline   Reply With Quote
Old 02-26-2010, 09:03 PM   #12710
Fast XXXS's Avatar
Trader Rating: 49 (100%+)
Depending on how old the motor is but my DUO seemed to fade alot towards the end of races, i have also heard of this being a problem other people are having with their DUO's, but then again i see some that are still quick all race but they may be newer.
Fast XXXS is offline   Reply With Quote
Old 02-26-2010, 09:09 PM   #12711
Its 3 weeks old. should I be running the first timing hole or the middle?
eXpress Motorsports
Old 02-26-2010, 09:18 PM   #12712
Fast XXXS's Avatar
It should be working fine then if its 3 weeks old. Im not sure which hole as i haven't used my RS yet but i have found the middle hole, 10 degrees is the sweet spot with LRP ESC's, One of the quickest guys iv seen using a TEKIN and DUO had it set on the middle hole. But if you change to this then you may have to change your speedy settings to allow for the extra timing, temperatures will also increase.
Old 02-26-2010, 10:19 PM   #12713
Send a message via AIM to A-Ko
I would stick with the middle hole. The lower hole is much slower.
Jeffrey
teamgravityrc.com - motivrc.com
USVTA National Points Member #101
A-Ko is offline   Reply With Quote
Old 02-26-2010, 11:34 PM   #12714
hi,
where can you find shreff Birds set up?
grouchy is offline   Reply With Quote
Old 02-26-2010, 11:47 PM   #12715
Originally Posted by grouchy View Post
hi,
on the Tekin site.
eXpress Motorsports
Old 02-27-2010, 01:38 AM   #12716
Thumbs up
So?, if you drive like I do (sleep deprived), It'll "Wake you up!"
Maybe if your using Throttle Profile # 5, (I'm using # 3), try # 2.
I also turned off the Drag Brake. Just some thoughts.
Old 02-27-2010, 01:51 AM   #12717
What final are you running with that setup? I will give it another chance Drag brake is set at 10
eXpress Motorsports
Old 02-27-2010, 02:06 AM   #12718
FDR 5.26. I find, to a point, that a heavier FDR calms the agressiveness down. Drag Brake will increase Heat, I never use it.
Old 02-27-2010, 02:15 AM   #12719
I will give it a try. thanks. If you need any help with the car let me know. I have figured out a thing or two.
eXpress Motorsports
Old 02-27-2010, 02:17 AM   #12720
Drillit's Avatar
Location: Oreganastan Pacific Wonderland home to Indoor Farming
WWDD or better yet, WDDD
Mark Tilley
Got T-Bar ? ......... Oregons No ZigZag rule sucks
Bias the weight to the end you want to hit the wall with first!
Searchin fer answers in the Fog.......that's what I found
Drillit is offline   Reply With Quote
Tekin Redline RS Sensored ESC and motors, opinions for offroad? Cain Electric Off-Road 4230 06-07-2015 04:38 PM
Sensored vs. Sensorless lemansracer Electric On-Road 71 02-14-2009 03:19 AM
New Tekin Redline Sensored Motors are Roar Legal! Randy_Pike Electric On-Road 3 08-05-2008 02:08 AM
Tekin Redline Sensored 10.5 HUCKMAN Electric On-Road 6 07-15-2008 08:50 PM
sensored vs sensorless bprocket Rookie Zone 5 05-16-2008 09:38 AM
Tags
v203, vegas 2.0
