Old 02-26-2010, 02:22 AM   #12676
hacker's Avatar
Trader Rating: 141 (100%+)
Originally Posted by rx7ttlm View Post
Check your motor temp, radio brake epa, etc. I ran a 17.5 tonight, in the race had plenty of brake with 6.4 fdr and 175 degrees on a novak..
as said before, brake epa has been calibrated at 100, then 80 and bumped up to 100, and then bumped up to 150.
temps are not the cause in my problem as it will be weak from start to finish. When I mean weak, I mean they are not 'fantastic'. I can get around, just have to break a little earlier than others using lrp's.
hacker is offline   Reply With Quote
Old 02-26-2010, 02:48 AM   #12677
tc3team's Avatar
im guessing you've already tried a different brake strength setting on the hotwire, yes? Or has it always been at max?
Fusion Hobbies / www.horshamrc.org
The wife stops me being sane and the r/c stops me from going insane....
tc3team is offline   Reply With Quote
Old 02-26-2010, 02:50 AM   #12678
hacker's Avatar
its at 100 on hotwire.
Old 02-26-2010, 02:51 AM   #12679
tc3team's Avatar
just try it 2 or 3 less if you havnt done so before, and see if it jolts it into making a difference. No harm in trying...
Old 02-26-2010, 04:56 AM   #12680
hi, does anyone no of a shop that has the rs pro and hotwire in stock that will ship to the uk?
thanks
stcc ssb tires, ko ,gm motors, demon products lipos, hobbywing speedo
mwoods is offline   Reply With Quote
Old 02-26-2010, 05:36 AM   #12681
Trader Rating: 23 (100%+)
thanks
http://www.superiorhobbies.com/istar...d=TEKTT1153!SH
http://www.superiorhobbies.com/istar...t=TEKTT1153!SH
tdt1805 is offline   Reply With Quote
Old 02-26-2010, 06:05 AM   #12682
Default Tekin RS 1S 10.5 and 13.5 1/12th pan car settings
Tekin RS profiles HELP Needed
Im putting together a data base of RS settings 1S lipo Motor Type ,motor timing if known.Rollout etc. Comments.
Contributors so far.
Kenny Lambert USA
KRob
Peter Craig
Chris Odonoho.
If you want too contribute please PM with info.
Txs in advance.
tellan is offline   Reply With Quote
Old 02-26-2010, 06:18 AM   #12683
rcgen's Avatar
I just bought a RS. I run two classes 17.5 and rcgt, but not at the same race day. Our 17.5 is not limited to software unlike our rcgt. Am I able to download the software(s) and switch back and forth?
rcgen is offline   Reply With Quote
Old 02-26-2010, 06:20 AM   #12684
Regional Moderator
Jon Carlson's Avatar
Trader Rating: 48 (100%+)
If you have a Hotwire you can change it in about 2 minutes.
Jon Carlson
Team Associated, Reedy
Futaba, OS Engines, O'Donnell Racing Fuel
Jon Carlson is offline   Reply With Quote
Old 02-26-2010, 07:46 AM   #12685
thanks but they dont ship to the uk.
Old 02-26-2010, 07:57 AM   #12686
Hello guys would anybody have a good set-up for the tekin rs with redline 17.5. I run a tamiya 416 with a 100 spur and 29-30 pinion thunderpower 5200 mah 2s 50c battery. I have a lrp x12 17.5 on the way a set up for that would be nice also. Thanks alot
HoboShop is offline   Reply With Quote
Old 02-26-2010, 08:00 AM   #12687
RedBullFiXX's Avatar
Trader Rating: 34 (100%+)
thanks
http://rcmarket.com.hk/index.php?cPa...a&filter_id=49
--> 12th scale Information Source <--
"Men do not quit playing because they grow old; they grow old because they quit playing."
― Oliver Wendell Holmes Jr.
Old 02-26-2010, 09:15 AM   #12688
Originally Posted by todb View Post
I need some help figuring out the motor timing marks on my tekin 10.5, 13.5 17.5 motors. I have rotated my motor endbells all the way to the right to lower the timing. Is this correct? None of the notches on the motorbell go all the way to the zero degree mark on the label. I want to temps down that is why I adjusted them. I know that to much motor timing is bad so I went the opposite way. Any help will be greatly appreciated. Thanks.
As you turn them all the way right, watch were the line of the 0 is on the end plate. You can mark it but it will be some were with the little marking on the end plate. It will not be in the center but on 1 side. Use that as marking.
Standard they are 12 timing. So watch were the marking is on the 12 and you now were to look ad if you didn't turn the end plate.
As you set the timing between the 0 and the 10 you are always ok.
Start low with the timing or gear lighter in the beginning.
http://www.mikky32.com
Tekin RS pro
TOP racing Photon
Tekin Redline 10,5
Protoform LTC-R
mikky32 is offline   Reply With Quote
Old 02-26-2010, 09:22 AM   #12689
Originally Posted by RedBullFiXX View Post
just been on there due date is march 6th....
cheers
Old 02-26-2010, 10:23 AM   #12690
cheers
www.hanglooseracingproducts.nl has the RS and the hotwire bud I don't now if he ships it to the UK.
You can always mail him.
Tekin RS pro
TOP racing Photon
Tekin Redline 10,5
Protoform LTC-R
Tekin Redline RS Sensored ESC and motors, opinions for offroad? Cain Electric Off-Road 4230 06-07-2015 04:38 PM
Sensored vs. Sensorless lemansracer Electric On-Road 71 02-14-2009 03:19 AM
New Tekin Redline Sensored Motors are Roar Legal! Randy_Pike Electric On-Road 3 08-05-2008 02:08 AM
Tekin Redline Sensored 10.5 HUCKMAN Electric On-Road 6 07-15-2008 08:50 PM
sensored vs sensorless bprocket Rookie Zone 5 05-16-2008 09:38 AM
Tags
v203, vegas 2.0
