Old 02-25-2010, 12:54 PM   #12661
Originally Posted by 2wdrive View Post
well i was thinking that as well but for a 11.5t they are fast! Look at the acceleration of the orange/red car that the camera is following!. Looks more like a 7.5t or something.
The 11,5T is fast.
It is as fast if not faster than the 7,5T with the new speedo's.
http://www.mikky32.com
Tekin RS pro
TOP racing Photon
Tekin Redline 10,5
Protoform LTC-R
mikky32 is offline   Reply With Quote
Old 02-25-2010, 01:45 PM   #12662
Originally Posted by Krio View Post
The "torque" rotors have a smaller diameter shaft where the magnet is. ROAR specifies a 7mm or so inner diameter on the magnet in addition to the outer 12.5mm limit.
I looked ad the rules from the EFRA.
The shaft outside diameter where the magnet is mounted will be 7,25mm +/- 0,15mm, whit this diameter extending beyond the magnet to facilitate measurement.
Magnet outside diameter will be 12.20/12,51mm (min./max. with no further tolerance) for the entire length of the magnet.
So the the rotor is also not EFRA legal
Tekin RS pro
TOP racing Photon
Tekin Redline 10,5
Protoform LTC-R
Old 02-25-2010, 05:53 PM   #12663
RacinJ's Avatar
Default Snowbird V 2.03 Setups
After the Snowbirds Randy said he was going put together the setups run by the factory guys and post them. Is this going to happen?
Roche P12 '16 & '17; Team Scream 17.5 & 13.5
1/12th scale, just 1/12th scale.
I love to go like hell for 8 minutes.
RacinJ is offline   Reply With Quote
Old 02-25-2010, 06:26 PM   #12664
Trader Rating: 114 (100%+)
how about the new GUI Interface.. the "netbook" interface?
Chris Furman is offline   Reply With Quote
Old 02-25-2010, 08:00 PM   #12665
bukil's Avatar
Trader Rating: 39 (100%+)
I did some testing today, and got confused with a few things. Trying to re-educate myself again with the basics of start rpm and end rpm.
Let's say I have 50 timing boost; 4000 start and 12000 end rpm on a 13.5 motor. Does the "50" timing boost endat the end rpm, and gradually declines as your rpm goes up? Or does it consistently hold it at 50 until the rpm comes back down to less than 12000?
bukil is offline   Reply With Quote
Old 02-25-2010, 08:27 PM   #12666
Krio's Avatar
Trader Rating: 150 (99%+)
Boost holds steady above the end rpm at whatever you have selected for boost, or 50 in your case.
www.kriostasis.com
Krio is offline   Reply With Quote
Old 02-25-2010, 09:14 PM   #12667
Team Tekin
Randy_Pike's Avatar
Send a message via Yahoo to Randy_Pike
Guys,
Apologies on not getting all of the birds setups posted yet. I have been moving for the past week and have had no internet. Bare with me, I'll get them posted.
Rp
"Things may come to those who wait, but only the things left by those who hustle." Abraham Lincoln
Tekin,Protek,A-Main Hobbies,JConcepts,Avid RC,Yokomo,MIP,SikLidz,FactoryRC, www.randypikerc.com
Randy_Pike is offline   Reply With Quote
Old 02-25-2010, 09:24 PM   #12668
Cameron Kellogg's Avatar
Trader Rating: 45 (100%+)
Originally Posted by Randy_Pike View Post
Guys,
Rp
Moving ranks right up there with getting teeth pulled.
Cameron Kellogg is offline   Reply With Quote
Old 02-25-2010, 10:47 PM   #12669
vazzo's Avatar
Trader Rating: 100 (100%+)
All I can say is F********************************K!!!
For the first time ever I ran the RS Pro 203 with 17.5 and swear it was as fast as my 6.5 and I had a ton of brakes. Love your work guys.
Gone riding, cya.........
vazzo is offline   Reply With Quote
Old 02-25-2010, 11:04 PM   #12670
hacker's Avatar
Trader Rating: 141 (100%+)
I still cant get brakes like everyone else.
they are not locking up, not that I want them to!
even with radio calibrated to 80%, and then bumped up to 100% afterwards. Running sensored mode, fdr 6 on novak 17.5
might have to try other motors
hacker is offline   Reply With Quote
Old 02-26-2010, 12:37 AM   #12671
L.Fairtrace's Avatar
Trader Rating: 23 (100%+)
Send a message via AIM to L.Fairtrace
Guys I ran the same setups as Schreff did at the birds in both 13.5 and mod.
The 13.5 setup is about as fast as you could hope for and the 10.5 setup is fast as most mod motors. Give them a try.
Awesomatix USA - EaMotorsports - RocheUSA - MonTech - Sanwa - BSR Racing Tires - TQ Wire - Solaris Racing Tires - Side Piece Racing
180 and 360 Raceway. Best on the East Coast. Take your pick
L.Fairtrace is offline   Reply With Quote
Old 02-26-2010, 01:57 AM   #12672
You dont have an m11 radio by chance? I had issues with the brake feel and turns out I had the ABS brake feature turned on and it made the brakes work real soft.
Old 02-26-2010, 02:10 AM   #12673
rx7ttlm's Avatar
Trader Rating: 30 (100%+)
Check your motor temp, radio brake epa, etc. I ran a 17.5 tonight, in the race had plenty of brake with 6.4 fdr and 175 degrees on a novak..
|Team Xray | RC America |MAX Engines | Hudy |Jaco | KO PROPO |"From Slovakia with Love" T3 | Team Timezone |
Timezone Raceway & Hobbies - http://www.timezonehobbies.com
rx7ttlm is offline   Reply With Quote
Old 02-26-2010, 02:16 AM   #12674
Trader Rating: 59 (100%+)
Send a message via AIM to todb
I need some help figuring out the motor timing marks on my tekin 10.5, 13.5 17.5 motors. I have rotated my motor endbells all the way to the right to lower the timing. Is this correct? None of the notches on the motorbell go all the way to the zero degree mark on the label. I want to temps down that is why I adjusted them. I know that to much motor timing is bad so I went the opposite way. Any help will be greatly appreciated. Thanks.
todb is offline   Reply With Quote
Old 02-26-2010, 02:17 AM   #12675
hacker's Avatar
no, I have a spektrum dx3r and doesnt have any super dooper features like abs. Also use a KO helios, with abs turned off. Even tried refreshing the transmitter model modes with a unused memory location still no help.
Tekin Redline RS Sensored ESC and motors, opinions for offroad? Cain Electric Off-Road 4230 06-07-2015 04:38 PM
Sensored vs. Sensorless lemansracer Electric On-Road 71 02-14-2009 03:19 AM
New Tekin Redline Sensored Motors are Roar Legal! Randy_Pike Electric On-Road 3 08-05-2008 02:08 AM
Tekin Redline Sensored 10.5 HUCKMAN Electric On-Road 6 07-15-2008 08:50 PM
sensored vs sensorless bprocket Rookie Zone 5 05-16-2008 09:38 AM
Tags
v203, vegas 2.0
