Old 02-21-2010, 04:44 PM   #12481
how do you know what max rpm to use?
Aqualoki is offline   Reply With Quote
Old 02-21-2010, 05:59 PM   #12482
It depends on the track and what you want for a feeling.
A higher End RPM makes the acceleration smoother.
You can gear a bit heavier and you can ad more Boost.
With a lower End RPM your car will accelerate faster.
I play with it till I have a good feeling.
http://www.mikky32.com
Tekin RS pro
TOP racing Photon
Tekin Redline 10,5
Protoform LTC-R
mikky32 is offline   Reply With Quote
Old 02-21-2010, 07:00 PM   #12483
sonic31's Avatar
i want to give a big shout-out to m-technic for helping me out this saturday with my rs setup. my first run with the rs came in at over 200 degrees and after he made some adjustments it temped at under 130!!! i ended the night with an fdr of 4.7 but it still kept temping at 130 and i went up 3 teeth higher than before so i know my 416x could have been faster
thanks tj
Tamiya TRF418 SAMIX / KO Propo / Tekin RS Pro / Spektrum
sonic31 is offline   Reply With Quote
Old 02-21-2010, 08:36 PM   #12484
kp-61's Avatar
Originally Posted by kp-61 View Post
Sounds like a plan .. i should have asked for help earlier .. hope its not too late... now i understand why starting turbo at 5.
With trying 6 - 6.5 - 7 fdr temps in theory should go down if i dont make any changes on the esc ?
Mikky32 i will also try your suggestion. I will keep note of temps and report back.. maybe this may help other newbies like me.
thanks !
Just an update that might help other newbies..
here was my setup during the final qualifying. 6 min
FDR : SRPM : ERPM : TIMING : TURBO : DELAY : RAMP : Final Temp
6.551470588 2000 10000 50 5 0.3 3 130
i find that the car was more on the smooth side and did flat out almost 1/8 before the end of the straight.. it was not too bad. it made me calmer infield puch was average but controllable
Final Setting i only put the timing to max and turbo to 8 ( i know its a weird number lol) end temparature was 140 - 145
i found that the car slingshots all the way at the end and i was smiling at the straight infield was a tad more aggressive.
have a great day ! and hope this helps...
* VISA * MASTER CARD :)
kp-61 is offline   Reply With Quote
Old 02-21-2010, 08:38 PM   #12485
kp-61's Avatar
thanks tj
do you mind sharing your setup and for what motor? I might used this as a basis for future races how long was the straight
thanks!
Old 02-21-2010, 09:05 PM   #12486
sonic31's Avatar
kp-61 i'll get the setup on here as soon as i can i still have to unpack my stuff, i worked non-stop all week to make up hours at work for saturdays race so im kinda taking a break right now but i will post it.
by the way my motor was a redline 17.5 and my gearing was 92/40 and i used the 200 software for the class i ran, the 203 would've been illegal. the redline motor was very fast with the 203 software though!
Old 02-21-2010, 09:21 PM   #12487
20 SMOKE's Avatar
Trader Rating: 101 (100%+)
you ran rcgt
Jamie W
*Team Tekin*Tekno-rc*DE Racing*AKA*DDHRC*
20 SMOKE is offline   Reply With Quote
Old 02-21-2010, 09:58 PM   #12488
sonic31's Avatar
yea i ran rcgt, it was a lot of fun but watching the 13.5 class going at it made me want to run that instead.
ok i got my setup up...
drag brake - 20
brake strength - 100
neutral width - 5
throttle profile - 5
timing boost - 20
turbo boost - 15
turbo delay - 0.2
Old 02-21-2010, 11:50 PM   #12489
B4james's Avatar
Originally Posted by mikky32 View Post
Can you post your setup please?
Set up posted, 13.5 TC on large outdoor asphalt track.
Follow me on Facebook - James Ainslie Designs or on Instagram - JA_Designs
*HEI International for Protoform/Proline/Spaz Stix
*Bitty Design Australia for Bodies and Liquid Mask
* Airbrushmegastore.com for all paint and airbrush supplies
B4james is offline   Reply With Quote
Old 02-22-2010, 01:47 AM   #12490
Pattojnr's Avatar
Trader Rating: 19 (100%+)
i saw it mentioned before by Randy to run a minimum of delay at 0.2
how do you find it at 0 ?
i ran 0.4 but i can see advantages at 0.2 as the speed down the striaght, once you back off due to slower car (most cars) the process starts again. Cheers.
Serpent - Walter RC
Serpent E Power ..... Serpent 747 Reds M3T
Serpent 966-TE Reds M7T .... S411ERYX Speedpassion 3.5T, T-Shox
Serpent 811-TE REDs R5T
Pattojnr is offline   Reply With Quote
Old 02-22-2010, 02:31 AM   #12491
B4james's Avatar
Randy mentioned previously that due to the low start rpm you can get away with the 0 delay. I tried it and had absolutely no problems with heat or overtiming and this was with a Novak motor on standard timing.
Car was still very punchy but was also very smooth in its power delivery, not to mention that it also had a lot of top end speed. As I mentioned prior I was able to hang with 4.5 mod cars with this set up
Old 02-22-2010, 03:20 AM   #12492
I tried delay=0 with a 11.5R motor. The speed is very fast, it can hang around with 5.5R's. However, I do find the motor temp. to be higher than usual (around 70C to 75C).
With a delay<>0 with 11.5R, the temp is around 50ish C.
hardmankam is offline   Reply With Quote
Old 02-22-2010, 03:38 AM   #12493
Fast XXXS's Avatar
Trader Rating: 49 (100%+)
Originally Posted by Fast XXXS View Post
Hi guys, just a few questions. What are the differences between the DUO1 and DUO2 motors when used with the Tekin and the new 203 software. Which do people find has more RPM and which more Torque? Do they have to be geared differently for use on the same track? or Some settings run a bit softer/ harder between the two motors?
Any help would be great.
Cheers
Anyone?
Fast XXXS is offline   Reply With Quote
Old 02-22-2010, 04:11 AM   #12494
Yokomo_Ant3's Avatar
Trader Rating: 29 (100%+)
Anyone?
There pretty similar Luke, we have found the Duo 1 to be better on the settings we used though.
Antoni Caretti
Team Yokomo - Racing Performer - Sweep Racing
Yokomo_Ant3 is offline   Reply With Quote
Old 02-22-2010, 04:53 AM   #12495
Fast XXXS's Avatar
I see, mmm Damm, as i just bought a DUO2 Oh well i think ill be able to get it to work, with a little help *cough* James *cough*
Tekin Redline RS Sensored ESC and motors, opinions for offroad? Cain Electric Off-Road 4230 06-07-2015 04:38 PM
Sensored vs. Sensorless lemansracer Electric On-Road 71 02-14-2009 03:19 AM
New Tekin Redline Sensored Motors are Roar Legal! Randy_Pike Electric On-Road 3 08-05-2008 02:08 AM
Tekin Redline Sensored 10.5 HUCKMAN Electric On-Road 6 07-15-2008 08:50 PM
sensored vs sensorless bprocket Rookie Zone 5 05-16-2008 09:38 AM
Tags
v203, vegas 2.0
