Old 02-15-2010, 09:07 PM   #12286
bigbank66's Avatar
I was using a new line of servo called Align 620 digital ultra speed....the servo works fine...the reciever works fine...the Tekin esc works great now...but put them all together an u have cogging...i changed it out for a hitec high torque..car works fine now!!! if u have cogging check out the servo..it might work just fine but it sends a signal to the motor an reciever that makes the problem....at lease was my problem..
bigbank66 is offline   Reply With Quote
Old 02-15-2010, 09:07 PM   #12287
niznai's Avatar
Originally Posted by CarbonJoe View Post
I've been using a JR9000s and a JR9100s in two different TCs with no cogging issues (both RS Pros).
Same here, no probs, no cap with JR servos (same as Joe). Used both Spektrum and KO receivers, neither gave me any problem.
Team Greasy Weasel
The best upgrade to any car is some driver skill.
niznai is offline   Reply With Quote
Old 02-15-2010, 09:30 PM   #12288
M-Technic's Avatar
Trader Rating: 15 (100%+)
I'm also using a digital JR servo with no problems (Airtronics DSSS receiver).
RCAmerica | Xray | Hudy | Radiopost | Speed Passion USA | Trinity | P3 Graphics
M-Technic is offline   Reply With Quote
Old 02-15-2010, 11:55 PM   #12289
tc3team's Avatar
Originally Posted by jmackani View Post
I actually started out at 30 degrees timing on the esc with the understanding that the Novak mechanical timing was set at 30 from the factory. It still cogged no matter how far apart I spread the timing across the rpm range. I tried to follow logic also by reducing the mechanical timing and this was the main indicator that it made it worse. FYI, I have a redline motor on the way.
let us know how you get on with the redline, you should see the cogging go away instantly with the right setup.
A safe combination of timing is 0deg endbell, 30 on the boost on v189, ive used it many times indoors on a small track and it's kept up with anyone, on a hot lap its 2/10ths quicker than anything else...
Fusion Hobbies / www.horshamrc.org
The wife stops me being sane and the r/c stops me from going insane....
tc3team is offline   Reply With Quote
Old 02-16-2010, 02:49 AM   #12290
TheCoolCanFanMan's Avatar
Originally Posted by THancock View Post
Dual Drive isn't an option as I need to run it sensored only to get the benefit of v203.
I don't use brakes at low speed as the car setup gets me round the corners without coming to a standstill. I only need brakes from high speed to bring me to cornering speed, which is usually a very quick stab of the brakes when using the SPX.
Hi Tim
Could you not use just a little more drag brake, as you and I drive very simular and hard ly use brakes any ways, as our cars flow round corners pretty well, just a suggestion, but worth a try imo
Cheers Malc
ps have you changed your setup to Easbourne since last year, when I helped you out with the 3 hole piston idea
ARC 2013 model ZEN Racing, MM-UK, HW 3.1, Rich Paints, MM UK Rug Racers win13.5 2007/8
2nd in 2008/9/10 Win Ansman GP 2010 Schumacher GP. 17.5 blinky Winner of STCC 2009/10 13.5 WLRC 2010 Summer series. Winner of EWS Winter. 17.5 Blinky Winner of 2012/13/14 Rug Racers. 17.5 Blinky 2013 WLRC summer series. Newbury RCC GP 2014 17.5 Blinky 2015 3rd in 17.5 Rug Racers
TheCoolCanFanMan is offline   Reply With Quote
Old 02-16-2010, 04:31 AM   #12291
Skiddins's Avatar
What is the effect on the R1 ESC with the v203 software, how many of the features work?
Damian
Xray T4'18, T4'14 (Wet Car)
Xray X12 2018
Xray X1'16
wlrc.co.uk (West London Racing Centre)
RCDisco.co.uk
Skiddins is offline   Reply With Quote
Old 02-16-2010, 04:42 AM   #12292
tc3team's Avatar
Damian
Here are all the features explained from a cut and paste off the main page.
My understanding, (in short), is that the ESC/Motor is tuned with more accuracy with v203 over previous software ,which, when set correctly with the correct gear ratio, is allowing the turbo to spool in quicker and at a user/hotwire set/configured rpm parameter of engaging and disengaging = faster lap times.
HotWire Vegas tips from team manager, Randy Pike
Motor Timing: Launch
Motor timing is an absolute. It’s effective throughout the entire range of the cars speed. This is the adjustment that should be made for the first few feet of car travel.
Timing Boost: Acceleration
The ideal start/end rpm for boost will depend on the platform/chassis being used along with track size and motor wind. The size of the range will also affect how the car pulls. A narrow rpm range will effectively produce a faster rate of boost vs. a wide range will have a slower rate of boost:
1000rpm start / 6000 end with 50 timing boost will provide 10 degrees of boost per 1000 rpm vs. 1000rpm start / 11000 end with 50 timing boost will provide 5 degrees of boost per 1000 rpm.
Spec Motors:
So far pan cars are using between 1,000 and 7,000 on most tracks. This is due to not having a gearbox and being direct drive.
TC’s are showing a useable range of 2,000 to 13,000 on most tracks. This is due to having a reduction gear box.
Turbo Timing: Top speed
Turbo Delay: This is the time that must expire at wide open throttle to engage turbo. This is NOT dependant on RPM’s in any way. Ideally this should be NO lower than .2 and in all likelyhood will be set at .4 or more. Tracks that have straights less than 80ft will likely NOT need turbo.
Turbo Ramp Rate: This is the literal ramp rate of whatever your turbo timing is set.
A turbo setting of 20 will give you the following reaction:
1.0 Ramp rate = 20 degrees in 1 second applied
2.0 Ramp rate = 20 degrees in .5 seconds applied
3.0 Ramp rate = 20 degrees in .30 seconds applied
So if you run timing it will just change the total applied, not the speed at which it’s applied.
Old 02-16-2010, 04:47 AM   #12293
Skiddins's Avatar
Motor timing is an absolute. Itís effective throughout the entire range of the cars speed. This is the adjustment that should be made for the first few feet of car travel.
Spec Motors:
TCís are showing a useable range of 2,000 to 13,000 on most tracks. This is due to having a reduction gear box.
Turbo Delay: This is the time that must expire at wide open throttle to engage turbo. This is NOT dependant on RPMís in any way. Ideally this should be NO lower than .2 and in all likelyhood will be set at .4 or more. Tracks that have straights less than 80ft will likely NOT need turbo.
So if you run timing it will just change the total applied, not the speed at which itís applied.
But does the older R1 ESC end up with the same features?
What's the difference between the R1 and the RS?
Xray X12 2018
Xray X1'16
RCDisco.co.uk
Old 02-16-2010, 04:49 AM   #12294
tc3team's Avatar
I'll let someone who knows or has an R1 to tell you that, as in short, I only have an RS Pro and don't know (at least it rhymes lol).
Old 02-16-2010, 04:50 AM   #12295
Skitee's Avatar
The one major difference is that the R1 is sensorless and the RS is sensored, so you won't have the turbo or timing boost from the RS but the R1 will have timing advance other than that all other features should be the same.
Xray T4 2018 ~ HobbyWing Xerun XR10 Pro ~ Motiv RC 4.5
Xray X12 2018 ~ ORCA Vritra VX3 1S ~ Speedzone 4.5
POWERED BY SPEEDZONE USA
Skitee is offline   Reply With Quote
Old 02-16-2010, 08:29 AM   #12296
Team Tekin
Randy_Pike's Avatar
Send a message via Yahoo to Randy_Pike
The R1 will gain none of the new features released in 203. The R1 is a sensorless only esc and will not have timing boost nor turbo.
"Things may come to those who wait, but only the things left by those who hustle." Abraham Lincoln
Tekin,Protek,A-Main Hobbies,JConcepts,Avid RC,Yokomo,MIP,SikLidz,FactoryRC, www.randypikerc.com
Randy_Pike is offline   Reply With Quote
Old 02-16-2010, 08:33 AM   #12297
Skitee's Avatar
Is there an echo in here ?
Old 02-16-2010, 08:04 PM   #12298
TfnG's Avatar
Trader Rating: 26 (100%+)
wanted to ask a few 1s WGT 13.5 questions. what is a good starting roll out for an 80x36 track? ive got the RS figured out with my TC, but my first run with a pan car will be thursday night.
from what ive read...im going to start with 35-40 timing, no turbo, rpm range 2000-7000. look good to start?
im just stumped on the rollout stuff and where i need to be.
thanks in advance.
GRAVECLOTHING.COM PROLEVELRC.COM
TfnG is offline   Reply With Quote
Old 02-16-2010, 10:14 PM   #12299
hi-tech-redneck's Avatar
Default 13.5 setup
help!!!!! randy or anyone,up until now i have been running v194,but lately iv'e been getting smoked by the guys with there new mamba max pro's in 13.5 tc/i need a good esp setup for the new software.big speedworld sized track,i've been running the same setting since the 09 reedy race,(thank you randy for helping me get up to speed there)i was fast until everyone upgraded. i am also building a 12scale 13.5 1cell lipo car for the same track i can find a few setup sheets on tekins site for carpet 13.5 but nothing for assfault,any pointers would be helpful,thanks guys!!!!
tularecountyrc.com/the chicken ranch/exeter hobbies/nor-cal hobbies,ripon raceway/hara tcx/losi 22/top photon vta/tekin/reedy/hpi racing/3racing/AT&T/much more/upgrade rc
hi-tech-redneck is offline   Reply With Quote
Old 02-16-2010, 10:28 PM   #12300
Still Bill's Avatar
thanks in advance.
What 13.5 motor? I am assuming that you want to run v203.
Constantly evolving CRC WGT and WGT-R/T...Carpet & Asphalt...All thanks to Team CRC.
And a pair of Associated B6 buggies for turf and clay tracks.
Still Bill is offline   Reply With Quote
Tekin Redline RS Sensored ESC and motors, opinions for offroad? Cain Electric Off-Road 4230 06-07-2015 04:38 PM
Sensored vs. Sensorless lemansracer Electric On-Road 71 02-14-2009 03:19 AM
New Tekin Redline Sensored Motors are Roar Legal! Randy_Pike Electric On-Road 3 08-05-2008 02:08 AM
Tekin Redline Sensored 10.5 HUCKMAN Electric On-Road 6 07-15-2008 08:50 PM
sensored vs sensorless bprocket Rookie Zone 5 05-16-2008 09:38 AM
Tags
v203, vegas 2.0
