Old 02-15-2010, 03:52 PM   #12256
tc3team's Avatar
Originally Posted by jmackani View Post
Yeah, I know it sounds crazy, but I see alot of people having this problem with the Novaks. I had the same squealing even with only 30 degrees of timing added. I first tried reducing the timing on the motor and it made it worse to the point under no-load conditions it would squeal on the car stand. Since that made it worse, I advanced the timing on the motor and the problem went away. I believe there is something that is not right with the novak ballistics. I noticed there appears to be very little help out there for the novaks and I do not think it is in Tekin's best interest to comment on one of their competitors motors in my opinion.
Intresting thoughts.
I don't like the thought of using excessive timing from the get go.
It could be considered bad for motors back in the brushed days (when we went away from 44degree stock motors to lesser degree stock motors, they became more durable imo), it can be just as bad (but more expensive!!!) for brushless motors too, logic tells me that we can always have too much of a good thing...
I would not say it is in Tekins best interest to comment on outside brands, but merely inhouse testing and indeed a lot of race track action (sponsored and privately used Tekin Equipment) is seen with to be with the Tekin motor/RS combi.
Sometimes you get a mix and match combi of Tekin ESC and non Tekin motor and it works great for one, but real bad for another... A bit hit and miss.
This isn't my own plug to say "use Tekin ESC and motor only" but it sure does cut out any possible compatability issue in my eyes.
These are my own thoughts as a Tekin Team guy for 3.5 years until recently, but I am more than happy for anyone to correct me on anything they see fit to, it is of no joy for me to give the wrong impression about a company I have been happy to be part of...
Tim - hope the capacitor resolves your issue, doesn't sound like you are alone in using the RS at West Kent, so you've got a chance to share info now on setups....
Fusion Hobbies / www.horshamrc.org
The wife stops me being sane and the r/c stops me from going insane....
tc3team is offline   Reply With Quote
Old 02-15-2010, 04:33 PM   #12257
20 SMOKE's Avatar
Trader Rating: 101 (100%+)
Originally Posted by JPMSRacing View Post
I just ordered a 13.5 Redline motor, I will get in the car and see how it acts I guess. Everyone told the ballistic motors would work with the RS Pro, but I cant get it to work. Tried of getting mad at a toy car.
did you try dual mode at all or have you pulled the sensor wire off and try running
Jamie W
*Team Tekin*Tekno-rc*DE Racing*AKA*DDHRC*
20 SMOKE is offline   Reply With Quote
Old 02-15-2010, 04:42 PM   #12258
Bryan Kendall's Avatar
The novak kinetic is way too late to the show!!
Bryan Kendall is offline   Reply With Quote
Old 02-15-2010, 04:57 PM   #12259
cyclone x's Avatar
one of my race buddys this weekend worked on my esc and changed the rpm,s around and its insane now on the track
good job tekin
Chase Chandler
Sponsors:HOTBODIES Express .The Track. Stevo Racing
Cars: VE8, F104 PRO, B4.1, HPI BLITZ, Losi SCTE
cyclone x is offline   Reply With Quote
Old 02-15-2010, 05:20 PM   #12260
jmackani's Avatar
Trader Rating: 14 (100%+)
I actually started out at 30 degrees timing on the esc with the understanding that the Novak mechanical timing was set at 30 from the factory. It still cogged no matter how far apart I spread the timing across the rpm range. I tried to follow logic also by reducing the mechanical timing and this was the main indicator that it made it worse. FYI, I have a redline motor on the way.
jmackani is offline   Reply With Quote
Old 02-15-2010, 05:22 PM   #12261
JPMSRacing's Avatar
Location: Lost in the Dead Space between my Ears Somewhere around Wamego, KS (OZ Land)
No I didnt try dual mode because the whole idea of the Tekin was for the sensored settings, and I didnt try no sensor wire because my Novak will not do anything without the sensor wire hooked up, so I figured the Tekin would be the the same.
I'm around still!!!
JPMSRacing is offline   Reply With Quote
Old 02-15-2010, 06:08 PM   #12262
bigbank66's Avatar
I might have found the problem of my clogging....i have a digital servo installed in my car as soon as i apply small amount of throttle i get this squealing sound..i just benched test my car with a different servo an the squeal is gone...ill install the servo an test it later an post my finding!!
bigbank66 is offline   Reply With Quote
Old 02-15-2010, 06:09 PM   #12263
Krio's Avatar
Trader Rating: 150 (99%+)
Actually, if the RS doesn't see any sensors it automatically jumps to sensorless mode so you can keep running in case the plug gets pulled mid race somehow. With high turn motors it will cog a little down low, but not as bad as you have seen with this weird novak incompatibility.
www.kriostasis.com
Krio is offline   Reply With Quote
Old 02-15-2010, 06:12 PM   #12264
advfuel's Avatar
Trader Rating: 29 (100%+)
I need a little help on where to start with my gearing.
Xray T3, I have been using 3.45FDR with SXX speedi.
I have now a RS and have heard that I should be around the 6.5FDR. Thats a huge jump.
The motor im using is a 17.5 Tekin running on asphalt large track.
http://www.onroadrccarclubbunbury.org.au/Site/index.htm
The straight is 55m long with flowing and a couple hair pins
Basicly where should I start with this gearing. All the set up posted a mainly carpet or small circuits
advfuel is offline   Reply With Quote
Old 02-15-2010, 06:27 PM   #12265
6,5FDR for a 17,5 is think to light.
I run 7,8 indoor with a 10,5T
start with 4,5 to 5FDR.
Setups for a 17,5 is not my thing. I never drove with a 17,5T. I drive 13,5 and lower turns but you can try to start with this.
Boost 45
Turbo 10
Turbo delay 0.9
Turbo ramp 2
Throttle 5
Start RPM 3500
End RPM 10000
Gearing 5 FDR
Motor timing 10
Temp the motor in time.
You can higher everything a bit but start with a lower timing and watch if the Turbo kicks in ad the right time.
If it kicks in to late lower the Turbo delay a bit but I think it will not be much lower.
Watch if you have enough speed. As the infield is good but top speed to shored ad some Turbo.
But first get the right infield speed. You can higher the Boost for a bit more power.
Play also with the gearing.
See what the acceleration does when you go to 4,5FDR.
Maybe you must gear lighter. Sorry I don't now how a 17,5 goes.
http://www.mikky32.com
Tekin RS pro
TOP racing Photon
Tekin Redline 10,5
Protoform LTC-R
mikky32 is offline   Reply With Quote
Old 02-15-2010, 06:45 PM   #12266
20 SMOKE's Avatar
Boost 45
Turbo 10
Turbo delay 0.9
Turbo ramp 2
Throttle 5
Start RPM 3500
End RPM 10000
Gearing 5 FDR
Motor timing 10
your close,i would start with a 5.5fdr and move the end rpm to 12000 that start is ok
Jamie W
Old 02-15-2010, 06:51 PM   #12267
advfuel's Avatar
Boost 45
Turbo 10
Turbo delay 0.9
Turbo ramp 2
Throttle 5
Start RPM 3500
End RPM 10000
Gearing 5 FDR
Motor timing 10
Thanks Mikky
Ha, Ive just noticed your website, thats awsome mate
Old 02-15-2010, 07:08 PM   #12268
Ok I will give the setup to a club member of me. he has a 17,5T Tekin for this year. Can I try some setups with him.
Thanks Mikky
Thanks.
As you found a good 17,5T setup please send it to me. I will post it.
I don't have much info about it.
I'm still working on the site but because of my study and I am building a website for a RC club in Belgium were I'm also a member.
Tekin RS pro
TOP racing Photon
Tekin Redline 10,5
Protoform LTC-R
Old 02-15-2010, 07:14 PM   #12269
niznai's Avatar
What I have found on our small carpet track was that with a 17.5 (SP V3) low FDRs overheat the motor. This was tested with motor timing set to 0 (which isn't saying much, because as we have seen BL motor timing is not consistently defined across motor brands) no turbo, boost at 45, wide boost window starting at low RPMs (2000ish-17000ish), linear throttle profile (3/4) and no drag brake.
Low FDR seemed to work better with v200 as far as overheating problems are concerned. Motor was Tekin 17.5, timing as per factory setting (not sure what that is), turbo at .7 delay, boost all the way up, profile 3, no drag brake (I am not a fan of drag brake because we have a tight technical section where I would rather let the car flow freely than brake).
There is still some testing to happen as soon as the track opens again but this is an interesting difference between the two software versions.
Team Greasy Weasel
The best upgrade to any car is some driver skill.
niznai is offline   Reply With Quote
Old 02-15-2010, 07:18 PM   #12270
The Speedpassion runs best with 10 timing.
Gear lighter and set a higher start RPM.
The Tekin has standard timing of 12.
I love the Tekin motors. I don't no why but they drive very smooth.
I have a good feeling with the motor so I will also get a 13,5T.
The 10,5T is fantastic. I don't now how it is compared to the Nemesis and the DUO 2 but I think that it isn't a big difference.
Tekin RS pro
TOP racing Photon
Tekin Redline 10,5
Protoform LTC-R
Tekin Redline RS Sensored ESC and motors, opinions for offroad? Cain Electric Off-Road 4230 06-07-2015 04:38 PM
Sensored vs. Sensorless lemansracer Electric On-Road 71 02-14-2009 03:19 AM
New Tekin Redline Sensored Motors are Roar Legal! Randy_Pike Electric On-Road 3 08-05-2008 02:08 AM
Tekin Redline Sensored 10.5 HUCKMAN Electric On-Road 6 07-15-2008 08:50 PM
sensored vs sensorless bprocket Rookie Zone 5 05-16-2008 09:38 AM
Tags
v203, vegas 2.0
