Old 10-06-2008, 06:57 PM   #1201
Trips's Avatar
Trader Rating: 16 (100%+)
Originally Posted by mangoman View Post
The other thing which people have been discussing is setting the motor to sensored only, then advancing the timing on the motor itself (although im not sure if you can do that with your motor). Apparently when you do that the esc runs more similarly to like a sphere.
Someone was explaining to me the differences in running a motor in unsensored and sensored a while back but i dont remember what he was saying.
I did try running in sensored only mode for one qualifier yesterday. The car felt punchier, but lap times were the same as in hybrid mode. Post run temperature at the motor did jump from 145 to 200 however. I was running a 118 spur with a 53 pinion in a losi R for an FDR of 4.07. I'd have liked to try another run in sensor only mode with a tooth less pinion, but I didn't have access to a 52 (PRS, are you listening??)
Went back to hybrid mode for the main, but ran a 112 spur with the 53 pinion for an fdr of 3.87 and ran my best lap times of the day, 4 tenths better than in the qualifiers. Didn't get the fastest single lap of the main, but I did manage the best 5 lap and best ten lap averages of the main. Motor came off the track at 185. I'm going to try a 114 spur next time out to get the fdr to 3.94 and hopefully drop the temp just a bit... maybe gain a touch more infield punch too.
This was with a Redline 17.5 on my RS. Endbell timing maxed in sensor mode, backed down in hybrid.
I just want to say THANKS to the guys at Tekin... Your products and support are second to none.
MARSHAL!!
Trips is offline   Reply With Quote
Old 10-06-2008, 08:14 PM   #1202
SammyZ's Avatar
Trader Rating: 138 (100%+)
My tekin came out of my car in a hard impact and the case broke. I called tekin to see what they could do for me, i was blown away! I thought i was gonna have to send it in for a new case but they told me they'd sell me a replacement case for $7.50! i could not be happier
Not only is this is current best brushless ESC it is backed by the best customer service in the USA.
SammyZ is offline   Reply With Quote
Old 10-07-2008, 11:52 AM   #1203
Grenade10's Avatar
Trader Rating: 37 (100%+)
I could not be happier with my RS-Pro's once I got them set correctly with the Futaba radio. Works great in my WGT car and now have one (based on the size) able to fix my Darkside Mx2 car.
But I need some help on a roll out in 1/12 scale with a Tekin 17.5 and the RS-Pro. Smaller track (60' x 40') some techinical but a lot of open/fast if the car is set up correctly.
Thanks in Advance
Darkside, Sweep, BSR, Fantom, IGT Hobbies and IGT8
Byrons Fuel, ProtoForm Bodies & Futaba Radio Gear by Choice
Founding Member of CORRC .... 5280raceway
www.darksidems.com www.igthobbies.com www.IGT8.com
Grenade10 is offline   Reply With Quote
Old 10-07-2008, 01:36 PM   #1204
It's important to remember that when you crank up the timing on most motors they have more (sensored only) timing than what the hybrid mode has at full timing. I always end up gearing down a little with the speedo set to sensored only.
Fred_B is offline   Reply With Quote
Old 10-07-2008, 06:07 PM   #1205
Team Tekin
Randy_Pike's Avatar
Send a message via Yahoo to Randy_Pike
Fred is very right.
If you crank your motor timing and don't regear you're not going to get the right speed anywhere on the track. You WILL get more heat and less performance.
Your timing could have gone up as much as 10 degrees with no gear change. Imagine doing that with a competition brushed stock motor...you would have wasted it.
Definately re gear and check temps/speed.
"Things may come to those who wait, but only the things left by those who hustle." Abraham Lincoln
Tekin,Protek,A-Main Hobbies,JConcepts,Avid RC,Yokomo,MIP,SikLidz,FactoryRC, www.randypikerc.com
Randy_Pike is offline   Reply With Quote
Old 10-07-2008, 07:37 PM   #1206
davepull's Avatar
Any word on how the vista 64 bit hotwire is coming?
davepull is offline   Reply With Quote
Old 10-07-2008, 08:39 PM   #1207
WWfarren's Avatar
Trader Rating: 27 (100%+)
Send a message via AIM to WWfarren
Default hot wire
i heard it will be out in 2 or 3 weeks
XRAY T2 008 RUBBER & Foam, LOSI JRS-X TYPER R FOAM & Rubber CARPET RS PRO, RED LINE NOVAK, LRP
WWfarren is offline   Reply With Quote
Old 10-07-2008, 08:50 PM   #1208
davepull's Avatar
yah just talked to Randy keep of the good work Team Tekin
Old 10-07-2008, 08:58 PM   #1209
bsmooth's Avatar
Trader Rating: 17 (100%+)
What do you guys recommend for 10.5 12th scale, on carpet, RS or RS Pro?
Thanks in advance.
-Steve
bsmooth is offline   Reply With Quote
Old 10-07-2008, 10:10 PM   #1210
Grenade10's Avatar
I installed my second RS Pro in my 1/12 scale car this evening and ran into an issue that does not make sense.
I'm using a futaba and have the servo set on reverse, just like my other one. Anyway, it finds the radio, gets center, full throttle and full barke, then comes to the single lite in the center. You can pull full throttle once and it works. Then the next time, it just kind of sputters and then stops. If you re-set it the same thing happens again.
Anyone else have this issue? How did you fit it?
Thanks in Advance
Old 10-07-2008, 10:50 PM   #1211
Buckyaga's Avatar
Thanks in advance.
-Steve
RS will do you just fine.
the RS Pro is only needed for a modified application (TC or 4wheel off-road)
Factory RC
4WheelMod 4 LIFE
Buckyaga is offline   Reply With Quote
Old 10-08-2008, 07:08 AM   #1212
Thanks in advance.
-Steve
I've run the RS all the way to a 6.5 in 12th so far and didn't have any temp problems. You can drive a 6.5 like Jo Jo the circus clown and it will only light up 4-5 led's on temp.
I'm going to try running a 4.5 this weekend with the RS and a very small (10mm) fan blowing on the posts. From what I've seen the RS is pretty tough even if you overheat it.
Old 10-08-2008, 08:28 AM   #1213
bsmooth's Avatar
RS it is!
Thanks guys.
Old 10-08-2008, 11:34 AM   #1214
Team Tekin
TY@TEAMTEKIN's Avatar
We want the 32bit version to be solid before we get into the 64bit version so we don't have to go thru twice the updates. Get the bugs out first, then we'll move forward, but it won't be in two weeks.
We're working on it guys, these things take time!
Ty Campbell
TEKIN / TLR / SOR GRAPHICS / MIP / PROTEK / KALGARD / AVID
TY@TEAMTEKIN is offline   Reply With Quote
Old 10-08-2008, 11:45 AM   #1215
Trader Rating: 52 (100%+)
Hey Guys
just dropping by to say Hey...
should be back to norma and posting back on here in a few.
looking to get ready to run some TC and some 4 wheel mod buggy with the rs pros
thanks
MO
Mo Denton is offline   Reply With Quote
Tekin Redline RS Sensored ESC and motors, opinions for offroad? Cain Electric Off-Road 4230 06-07-2015 04:38 PM
Sensored vs. Sensorless lemansracer Electric On-Road 71 02-14-2009 03:19 AM
New Tekin Redline Sensored Motors are Roar Legal! Randy_Pike Electric On-Road 3 08-05-2008 02:08 AM
Tekin Redline Sensored 10.5 HUCKMAN Electric On-Road 6 07-15-2008 08:50 PM
sensored vs sensorless bprocket Rookie Zone 5 05-16-2008 09:38 AM
Tags
v203, vegas 2.0
