Tekin RS ESC sensored >
Old 02-12-2010, 12:17 PM
  #12061
niznai's Avatar
I guess my question was why would you want a wider RPM band on a larger track. I suppose you take into account a higher rollout when you say the window would be wider?
niznai is offline
Old 02-12-2010, 12:23 PM
  #12062
Originally Posted by stiltskin View Post
I agree here. Cuff's setup says 2000-7000 but 2000 doesn't come up either. I ran schreff's 13.5 setup in 17.5 yesterday with a 5.86 FDR. Car was very fast and easy to drive. Ripped out of the corners and pulled smooth for the entire straight.
The software GUI accepts the end rpm number you type in (say, 10000) and then you select a start rpm and you update settings.
When you go back into the settings, the max rpm has a slightly different number to the one you put in. Whenever I put in 10000 rom, it always cames back as 10001. As Randy says above, the first two numbers are the most important.
It would be best if people posted what they entered on to the end rpm, and what they selected as start rpm from the list. The actual numbers it selects will be the same if we start with the same inputs and selections. HTH
SlowerOne is offline
Old 02-12-2010, 01:28 PM
  #12063
tc3team's Avatar
the bigger the track, the more spaced out you want the turbo to operate, if it worked in short burts, imho it could lead to the motor getting hotter, quicker- you'd be spooling the car up too quick, topping out early- you want the motor to keep pulling, not fade away.
On smaller tracks, you need that instant HP boost, so you narrow the rpm range to make that happen.
Thats my understanding of it anyways...
tc3team is offline
Old 02-12-2010, 01:30 PM
  #12064
stiltskin's Avatar
Trader Rating: 103 (100%+)
I wasn't questioning the process, I was just showing another example of the RPM range being "approximate" on a setup sheet.
stiltskin is offline
Old 02-12-2010, 05:11 PM
  #12065
Originally Posted by hobie814 View Post
Hello Mikky32,
Can I use this setup on my T3 with a LRP X12 10.5 Stock with rubber tires on an interior carpet track with quite a long straight ? thanks in advance for your help.
Originally Posted by mikky32 View Post
Set your Boost down and replace it with Turbo.
As you lower your boost to 45 and set 10 Turbo, You will have a smoother acceleration.
What you also can do is use this setup.
Boost 50
Turbo 10
Turbo delay 0
Turbo ramp 2
Start RPM 5100
End RPM 17000
Throttle 5
Gearing 7FDR (to start with) Watch the motor temp.
As you don't do full throttle, your car drives easier away.
So for the infield this is better to drive.
When you hit the straight. give full throttle and you fly away.
As you want even more acceleration set your Turbo ramp to 3. Hold on this is fast.
HEY MIKKY
that set up is FANTASTIC !!!!! i used it tonight and i am as quick as my fastest lap with the SPX but now i do 5 or 6 laps close to my quick ones
if i can keep the car tight and nice in the corners i am up there with the fastest guys in our club
the only thing i changed was boost 54 and gearing of 6.64
my xrays set up is as box appart from i added 1.5mm not 1mm on the front camber link outer joint to remove a bit of steering
Thanks to Tekin for a wonderful speedo and thanks to every one on this topic for the advice
KEEP UP THE GOOD WORK !!!!!!!
sidecarphil1 is offline
Old 02-12-2010, 05:31 PM
  #12066
Hello Mikky32,
Jason posted on this topic that the LRP X12 can't handle this setup.
Your motor becomes very hot.
I found also that the motor get's hotter than with the other setups.
I believe also that the motor can't handle this setup so I wouldn't use this setup.
Start with a setup without any Turbo and ad it when needed but only for top speed.
Originally Posted by sidecarphil1 View Post
HEY MIKKY
Good to hear that the setup works for you.
You will be faster than your old fastest lap after you get used to the power.
mikky32 is offline
Old 02-12-2010, 06:26 PM
  #12067
cyanyde's Avatar
HEY MIKKY
Put the steering back and find more rear traction and you'll be breaking your lap record in no time ;-)
cyanyde is offline
Old 02-12-2010, 07:19 PM
  #12068
Trader Rating: 24 (100%+)
hi,i have a question.the Tekin RS PRO work great in 4.5t MOD TC.thanks
IVAN RM is offline
Old 02-12-2010, 07:32 PM
  #12069
Trader Rating: 27 (100%+)
Just got done installing my Tekin RS into my TC5 and I have a few questions..
First of all how do I get rid of reverse? I looked in the manual and I didnt see how too.
and also now my servo is making that noise that all digital servos make all the time.. Is it gonna do that forever? cause i cant get it to stop,, and my LRP never made it make that noise when it was in the car.
C_Money is offline
Old 02-12-2010, 09:03 PM
  #12070
20 SMOKE's Avatar
Trader Rating: 102 (100%+)
the pro can handle anything you throw at it
20 SMOKE is offline
Old 02-12-2010, 09:12 PM
  #12071
stiltskin's Avatar
Reverse can be locked out by choosing BL/FW on Motor Type.
Old 02-12-2010, 09:13 PM
  #12072
20 SMOKE's Avatar
to change press mode until #6 led MT (motor type) press the INCR 1 led for forward/brake only
20 SMOKE is offline
Old 02-12-2010, 09:56 PM
  #12073
warnos's Avatar
Default RS with Redline 21.5
Just a quesiton regarding the redline motors.. The motor can came in the box with the standard timing at 12 degrees. Since the timing is now handled by the Speed Controller should I change the can timing back to 0?? Is this what everyone else is doing??
As on some of the V203 setup sheets I have noticed that the end bell timing is set to standard.. does this mean 12 degrees for the redline motor or 0 degrees..
When I run the Redline motor compared to a LRP Vector X11 is seems to have higher timing standard.. just an observation I have noticed with gearing of the two motors so I though the timing of the redline should be taken back to 0..
Cheers
warnos is offline
Old 02-12-2010, 10:29 PM
  #12074
ok and the servo noise? Or is that just the servo trying to find center and will never really go away?
C_Money is offline
Old 02-13-2010, 12:06 AM
  #12075
i am quite happy with my set up
i just need to be less agressave on the throttle
it is me not the car
