Old 02-11-2010, 06:29 PM   #12046
Trader Rating: 26 (100%+)
I was reading Jasons snowbird setup for 13.5 and it says fdr of 7.6. Is this correct. It seems extremely high for a track that size
eddie10 is offline   Reply With Quote
Old 02-11-2010, 07:02 PM   #12047
20 SMOKE's Avatar
Trader Rating: 101 (100%+)
its right
Jamie W
*Team Tekin*Tekno-rc*DE Racing*AKA*DDHRC*
20 SMOKE is offline   Reply With Quote
Old 02-11-2010, 08:09 PM   #12048
Regional Moderator
Darkseid's Avatar
Originally Posted by TrevCoult View Post
I've written a guide specifically aimed at beginners on programming the Tekin RS using the HotWire. It is on www.carsrcracing.co.uk at http://www.carsrcracing.co.uk/?p=188
Trev
Great guide. Answered alot of questions I was wondering about while I wait for my Hotwire to arrive.
TLR 22...Tamiya F104...
Old 02-11-2010, 08:27 PM   #12049
louielou's Avatar
Trader Rating: 16 (100%+)
thanks for the confirmation T.J; but i was also wondering why on Barry
Bakers setup he has a start rpm of 39XX, that option never came up for me when i put his end rpm of 10001?
Luis
[email protected]
Ebay account LOU840
louielou is offline   Reply With Quote
Old 02-11-2010, 09:37 PM   #12050
20 SMOKE's Avatar
because he may have forgot what the exact number was and put the closest one he could remember
Jamie W
Old 02-12-2010, 05:50 AM   #12051
hobie814's Avatar
Originally Posted by mikky32 View Post
Set your Boost down and replace it with Turbo.
As you lower your boost to 45 and set 10 Turbo, You will have a smoother acceleration.
What you also can do is use this setup.
Boost 50
Turbo 10
Turbo delay 0
Turbo ramp 2
Start RPM 5100
End RPM 17000
Throttle 5
Gearing 7FDR (to start with) Watch the motor temp.
As you don't do full throttle, your car drives easier away.
So for the infield this is better to drive.
When you hit the straight. give full throttle and you fly away.
As you want even more acceleration set your Turbo ramp to 3. Hold on this is fast.
Hello Mikky32,
Can I use this setup on my T3 with a LRP X12 10.5 Stock with rubber tires on an interior carpet track with quite a long straight ? thanks in advance for your help.
hobie814 is offline   Reply With Quote
Old 02-12-2010, 07:03 AM   #12052
stiltskin's Avatar
Trader Rating: 102 (100%+)
I agree here. Cuff's setup says 2000-7000 but 2000 doesn't come up either. I ran schreff's 13.5 setup in 17.5 yesterday with a 5.86 FDR. Car was very fast and easy to drive. Ripped out of the corners and pulled smooth for the entire straight.
Tony Rumple
Team EAM // Gravity RC
stiltskin is offline   Reply With Quote
Old 02-12-2010, 07:34 AM   #12053
20 SMOKE's Avatar
Originally Posted by hobie814 View Post
Hello Mikky32,
how long of a straight.there is no right or wrong setup to a certain degree,some work a little better than others,that set up is similar to schreffs set with a high rpm rang and 0 turbo delay
Jamie W
Old 02-12-2010, 09:55 AM   #12054
Team Tekin
Randy_Pike's Avatar
Send a message via Yahoo to Randy_Pike
Barry did say it was 39XX something or other... So we put 39xx.
You get the point. Same goes for Cuffs and even I'm guilty of this. The main important figure are the first 2 digits really.
In general a larger track will have a wider rpm band. A smaller track narrower.
Also if you have a great 1s setup, double those numbers for your TC and that should get you close.
For example if Jeff has 2,000 start and 7,000 end a good starting TC setup would be 4,000 start and 14,000 end on the same track in TC. This is because of the 1s vs. 2s . The usable rpm's are pretty much double from 1s to 2s.
"Things may come to those who wait, but only the things left by those who hustle." Abraham Lincoln
Tekin,Protek,A-Main Hobbies,JConcepts,Avid RC,Yokomo,MIP,SikLidz,FactoryRC, www.randypikerc.com
Randy_Pike is offline   Reply With Quote
Old 02-12-2010, 10:03 AM   #12055
hobie814's Avatar
it is difficult to say the lenght of the straight... Perhaps 40 l
meters... Where can I fine schreffs setup ?
Old 02-12-2010, 10:15 AM   #12056
niznai's Avatar
I am not sure I agree with this one. Better acceleration is good anywhere you can use it. Sure you top sooner on large track, but then you can use turbo?
The large outdoor tracks I have raced on (granted they are really large approx 50x20m and about 70-80x30m) would certainly allow full chat through most of the corners, so I would want to accelerate quickly and reach top speed as I entered the main straight (or the straights inbetween).
Here's my favourite track, scale bottom left.
Team Greasy Weasel
The best upgrade to any car is some driver skill.
niznai is offline   Reply With Quote
Old 02-12-2010, 10:29 AM   #12057
louielou's Avatar
thanks, 20 Smoke and Randy, for the explanation.
Luis
[email protected]
Ebay account LOU840
Old 02-12-2010, 11:12 AM   #12058
20 SMOKE's Avatar
http://www.teamtekin.com/hotwire/ESC...birds-v203.pdf
Jamie W
Old 02-12-2010, 11:47 AM   #12059
hobie814's Avatar
Thanks Jamie
Old 02-12-2010, 11:57 AM   #12060
Team Tekin
Randy_Pike's Avatar
What motor are you using here? What FDR? Setting your rpm "window" up correctly will get you the best acceleration setup. This of course coupled with the right gearing will be ideal. Having a setup where you never drop below the end rpm might as well have an on/off setup for timing. Finding the sweat spot for rpm's creates a car that has usable strong power.
Tekin Redline RS Sensored ESC and motors, opinions for offroad? Cain Electric Off-Road 4230 06-07-2015 04:38 PM
Sensored vs. Sensorless lemansracer Electric On-Road 71 02-14-2009 03:19 AM
New Tekin Redline Sensored Motors are Roar Legal! Randy_Pike Electric On-Road 3 08-05-2008 02:08 AM
Tekin Redline Sensored 10.5 HUCKMAN Electric On-Road 6 07-15-2008 08:50 PM
sensored vs sensorless bprocket Rookie Zone 5 05-16-2008 09:38 AM
Tags
v203, vegas 2.0
