Old 02-10-2010, 09:11 PM   #12016
cannon's Avatar
Trader Rating: 35 (100%+)
There is an old saying .... When all else fails read the instructions"
The LED sequence is explained in the instruction sheet.
"If LEDs 1,3 and 5 are flickering, it indicates that Voltage Cutoff may be set above battery pack voltage. Check that cutoff is cor-rectly set and that battery is fully charged. Motor or connections to motor are bad. Speed control not plugged into throttle channel on receiver, or receiver plug connection is bad"
Exactly as Randy said
www.feralbatteries.com ........... new website
cannon is offline   Reply With Quote
Old 02-10-2010, 09:40 PM   #12017
wingracer's Avatar
Trader Rating: 24 (100%+)
You got that right. I had the exact same problem after fiddling with some settings just before a heat. Unfortunately, I didn't have the instructions with me. I ran over to another driver and he grabbed the instructions and came over. He saw that the lights meant LVC so I plugged it up to the computer and found the problem. I had set it to 3 thinking that was three volts. Of course, that's actually 3s. A quick change and I was back in the race.
Sean. Certified speed crazed mowron.
Team Shepherd USA
www.ashfordhobby.com
wingracer is offline   Reply With Quote
Old 02-11-2010, 12:19 AM   #12018
bigbank66's Avatar
great job fellas....when u dont have the instructions...use your internet...low voltage was the problem...good lookin guys..but the clog problem is still in tack...my esc makes a loud screaching sound at low rpm....blip the throttle an its fine....ok fellas swing away???
bigbank66 is offline   Reply With Quote
Old 02-11-2010, 01:07 AM   #12019
Team Tekin
Randy_Pike's Avatar
Send a message via Yahoo to Randy_Pike
Well answer my other questions first. I need to know what software? What your settings are? What motor you're using? What wind? Where is the motor timing set? Etc..
"Things may come to those who wait, but only the things left by those who hustle." Abraham Lincoln
Tekin,Protek,A-Main Hobbies,JConcepts,Avid RC,Yokomo,MIP,SikLidz,FactoryRC, www.randypikerc.com
Randy_Pike is offline   Reply With Quote
Old 02-11-2010, 04:25 AM   #12020
Originally Posted by EAMotorsports View Post
The Zero mark in the center has 8 degrees built into it and each notch after that is 8 degrees as well.
EA
Thanks Eric! I had seen the post a few pages back but wanted clarification as i had been told something different by someone at the track.
boosta1276 is offline   Reply With Quote
Old 02-11-2010, 06:33 AM   #12021
Skiddins's Avatar
Originally Posted by CarbonJoe View Post
Running basically Schreffler's 13.5 setup with a Duo1 17.5, 6.56 FDR, the Novak Sentry data logger showed it was getting up to 32,250 RPM on a 90 ft x 40 ft carpet track (and that was with a chicane entering the straight!) Crazy fast!
Cheers.
Anyone got any figures for 10.5 and 13.5?
Xray T4'18, T4'14 (Wet Car)
Xray X12 2018
Xray X1'16
wlrc.co.uk (West London Racing Centre)
RCDisco.co.uk
Skiddins is offline   Reply With Quote
Old 02-11-2010, 07:16 AM   #12022
Also change your sensor wire.
I got a new sensor wire with one of my motors and it had the same problem. I changed it and the problem was solved.
I have several of them now to have spares.
That the GTB has no problem with the sensor wire is because it only uses to see were the rotor is and goes straight over to sensorless.
http://www.mikky32.com
Tekin RS pro
TOP racing Photon
Tekin Redline 10,5
Protoform LTC-R
mikky32 is offline   Reply With Quote
Old 02-11-2010, 08:38 AM   #12023
The Hawaiian's Avatar
Trader Rating: 94 (100%+)
well I jumped on the band wagon....had to do it...got me a tekin now
I wanna go fast
Justin "haole boy" Perry USCG (CGC Firebush)
NewRed Hobbies & Indoor Facility, da BEST clay off-road track in Florida.
!!Treat me the way you want to be Treated!!Race me the way you want to be Raced!!
The Hawaiian is offline   Reply With Quote
Old 02-11-2010, 08:48 AM   #12024
wingracer's Avatar
Originally Posted by The Hawaiian View Post
I wanna go fast
You will
Team Shepherd USA
Old 02-11-2010, 09:20 AM   #12025
Originally Posted by Skiddins View Post
Cheers.
Damien, i've got some figures from a recent session at maritime if you're interested (10.5 and 13.5)
CPD Racing
chris_dono is offline   Reply With Quote
Old 02-11-2010, 09:27 AM   #12026
AdminD's Avatar
That's true, i had oldest SS and
Still working and never fail until now,
Run Every week since the very first time
SS come out never stop running,
and Still Excellent!,
i would like to Thanks to NOVAK USA.
Sliders
AdminD is offline   Reply With Quote
Old 02-11-2010, 09:42 AM   #12027
The new speedo's all need a good sensor wire.
The Speedpassion sensor wire has given me a lot of trouble. With the LRP sensor wire and the Tekin sensor wire I have never got any problems.
With a bad sensor wire you can run a LRP tc but not the LRP SPX and SXX ss. Also the mamba, the Advanced and other speedo's that run completely sensord will give problems.
Tekin RS pro
TOP racing Photon
Tekin Redline 10,5
Protoform LTC-R
Old 02-11-2010, 11:20 AM   #12028
M-Technic's Avatar
Trader Rating: 15 (100%+)
I love how the Tekin flashes those two little LED's when you roll the car on the table, so you can know if the sensor is working properly. Helps diagnose problems!
RCAmerica | Xray | Hudy | Radiopost | Speed Passion USA | Trinity | P3 Graphics
M-Technic is offline   Reply With Quote
Old 02-11-2010, 11:48 AM   #12029
Skiddins's Avatar
Anything would be usefull.
Skiddins
Xray X12 2018
Xray X1'16
RCDisco.co.uk
Old 02-11-2010, 11:54 AM   #12030
20 SMOKE's Avatar
Trader Rating: 101 (100%+)
I wanna go fast
Originally Posted by wingracer View Post
You will
but he still wont beat me
Jamie W
*Team Tekin*Tekno-rc*DE Racing*AKA*DDHRC*
20 SMOKE is offline   Reply With Quote
Tekin Redline RS Sensored ESC and motors, opinions for offroad? Cain Electric Off-Road 4230 06-07-2015 04:38 PM
Sensored vs. Sensorless lemansracer Electric On-Road 71 02-14-2009 03:19 AM
New Tekin Redline Sensored Motors are Roar Legal! Randy_Pike Electric On-Road 3 08-05-2008 02:08 AM
Tekin Redline Sensored 10.5 HUCKMAN Electric On-Road 6 07-15-2008 08:50 PM
sensored vs sensorless bprocket Rookie Zone 5 05-16-2008 09:38 AM
Tags
v203, vegas 2.0
