Old 02-10-2010, 08:47 AM   #11986
Originally Posted by mikky32 View Post
Set your Boost down and replace it with Turbo.
As you lower your boost to 45 and set 10 Turbo, You will have a smoother acceleration.
What you also can do is use this setup.
Boost 50
Turbo 10
Turbo delay 0
Turbo ramp 2
Start RPM 5100
End RPM 17000
Throttle 5
Gearing 7FDR (to start with) Watch the motor temp.
As you don't do full throttle, your car drives easier away.
So for the infield this is better to drive.
When you hit the straight. give full throttle and you fly away.
As you want even more acceleration set your Turbo ramp to 3. Hold on this is fast.
this set up is great
i changed my gearing to 6.6 and the car flys
good and progressave on the infield and QUICK on the straight
i think next time i test i will try turbo ramp 3 and see what happens
motor temps are about 80 degrees C so this is ok as i am driving for longer then 6 mins
Cheers Emiel
sidecarphil1 is offline   Reply With Quote
Old 02-10-2010, 08:55 AM   #11987
niznai's Avatar
Cheers Emiel
What sort of track is it?
Team Greasy Weasel
The best upgrade to any car is some driver skill.
niznai is offline   Reply With Quote
Old 02-10-2010, 09:11 AM   #11988
it is an indoor medium grip carpet track
30m X 16m fast flowing track
+ YouTube Video
Old 02-10-2010, 09:15 AM   #11989
niznai's Avatar
Thank you phil. that's pretty much like our track, perhaps ours is tighter but same surface area.
Team Greasy Weasel
Old 02-10-2010, 09:29 AM   #11990
Cheers Emiel
Hey Phil,
As you set the Turbo ramp to 3, you will have even a faster monster in your hands.
I like the infield with this setup. You can drive easy in the infield. and have fantastic acceleration when needed.
It's is based on Jason Schreffler his setup so thank him for it.
The only thing I did was trying this setup and playing a bit with the Boost and Turbo ramp to get a personal setup.
He has on his 10,5T setup the Turbo ramp on 3.
I use 2 because I found 3 to much for me.
Also did I lower a bit of the Boost and lowered the end RPM to 17000 for my 10,5T.
I didn't loose any top speed on the indoor track but the car accelerated a bit smoother on the straight and in the infield.
Jason is a better driver than me. I can't handle that much of power.
Phil I tried it with the 10,5T on Ramp 3 but I drove my car in pieces.
It's fast so be care full and check the temp after 1 mint because your motor will get hotter with the Turbo ramp on 3.
You can lower the Boost to lower the temp a bit or gear down a bit.
90C must be possible for the motor. GM says that that is the best temp for there motor to run on with the best results but I would be holding that as the max and try for the 80C.
http://www.mikky32.com
Tekin RS pro
TOP racing Photon
Tekin Redline 10,5
Protoform LTC-R
mikky32 is offline   Reply With Quote
Old 02-10-2010, 09:34 AM   #11991
Jason is a lucky guy
Only for a photo with those 2 I would race if my live depends of it.
Tekin RS pro
TOP racing Photon
Tekin Redline 10,5
Protoform LTC-R
Old 02-10-2010, 10:03 AM   #11992
Team Tekin
Randy_Pike's Avatar
Send a message via Yahoo to Randy_Pike
Try running 20,000 end rpm, 5442 start rpm and 40 boost. That is a pretty wide powerband for Tc. Should be pretty close the the blue box.
"Things may come to those who wait, but only the things left by those who hustle." Abraham Lincoln
Tekin,Protek,A-Main Hobbies,JConcepts,Avid RC,Yokomo,MIP,SikLidz,FactoryRC, www.randypikerc.com
Randy_Pike is offline   Reply With Quote
Old 02-10-2010, 10:42 AM   #11993
Trader Rating: 45 (100%+)
Advice for RS Pro, v203 and a 4.0T for TC. Should I bother with any of the settings or just program the speedo for fwd, brake and neutral?
Apex is offline   Reply With Quote
Old 02-10-2010, 10:45 AM   #11994
Randy/Mikky,
It looks like the late thread is to have a higher start rpm as around (4000 to 5000), will this be more suitable for a indoor small-mid size track?(less than 100ft long straight)? Or generally this is now a more 'overall' usable starting points?
And in terms of controlling the temp, what changes of setting is most sensitive to increase the motor temp? (hopefully this is not too theoretical a question to ask) Will it be wise to use Schreff's snowbird setting (reversing the turbo and timing boost) as a mean to control heat? Circuit I run at is somewhat large(120ft+) and has semi-technical infield.
Thanks in advance
My RC Blog => http://blog.sina.com.cn/biaozhigongfang
My RC Vid blog => http://6.cn/profile/list.php?u=14606899&t=v
Aurora is offline   Reply With Quote
Old 02-10-2010, 11:05 AM   #11995
20 SMOKE's Avatar
Trader Rating: 101 (100%+)
Originally Posted by Aurora View Post
Randy/Mikky,
Thanks in advance
setups are both high and low,my track is about 140+with out the sweeper and my settings are low.i am playing where they are at cause i never come off the throttle accept at one corner.heat is caused by over geared to under geared and timing over lapping to much and bogging it down
Jamie W
*Team Tekin*Tekno-rc*DE Racing*AKA*DDHRC*
20 SMOKE is offline   Reply With Quote
Old 02-10-2010, 11:45 AM   #11996
metalracer2's Avatar
Trader Rating: 20 (100%+)
Send a message via AIM to metalracer2
i'm going to get a tekin for my 1/10 truck running a 17.5 and 4wd buggy running a 13.5.
does anyone have a good starting set up for ether car?
First you forget names, then you forget faces. Next you forget to pull your zipper up and finally, you forget to pull it down.
Team BOOZE CRUISEN!
Rides....
AE B4.1W AE T4.1
metalracer2 is offline   Reply With Quote
Old 02-10-2010, 11:49 AM   #11997
Team Tekin
Randy_Pike's Avatar
It's all a matter of personal prefference really. If the track is shortish and you're running TC than yes a bit higher start rpm will get some snap out of the corners as it CAN allow you to run a bit of motor timing.
There are a lot of offroad setups and discussions in the offroad thread here on RcTech.
also here:
www.teamtekin.com/hotwire.html
RP
Old 02-10-2010, 12:01 PM   #11998
M-Technic's Avatar
Trader Rating: 15 (100%+)
I run on a large outdoor asphalt track, and with our new layout which is semi-technical (has a few tight hairpins) I have found a 2,500 start RPM to work the best. 1,500 seemed to bog down the motor, and 4,000 had a noticeable lag in the boost coming in. This is in 17.5, although most of the 13.5 guys are running a similar setup.
RCAmerica | Xray | Hudy | Radiopost | Speed Passion USA | Trinity | P3 Graphics
M-Technic is offline   Reply With Quote
Old 02-10-2010, 12:52 PM   #11999
I run with Nosram Pure motors (LRP X12), with motor timming -10 (oooo Dot), fdr:8.4, large track, medium grip.
RS pro v203: Dual Mode
- DB: 7
- BS: 75
- NW: 5
- TP: 3
- TM: 75
- CL: Off
- End rpm: 23K-25K
- Start rpm: 5XXX
Very smooth power, and fast.
I run in Sensored mode, too, there are more power, but is easy overheat the motor, i put TMB:5, Turbo: 5-10, delay:0.5, other setings the same, very fast and easy to drive.
Greetings, Luis C.
## NOSRAM ## YOKOMO BD5W ## BMI DB12RR+ ##
luic is offline   Reply With Quote
Old 02-10-2010, 03:30 PM   #12000
Skiddins's Avatar
Can anyone tell me what sort of RPM a 10.5 and a 13.5 motor are reaching at the top end, I know it's a bit dependant on gearing etc but a rough idea would be fine. The figure without turbo etc.
I do remember 27t's used to reach 25k off load but would get nowhere near that on track.
I'm interested to know as I want to better understand the upper rpm limit for the timing.
Skiddins
Xray T4'18, T4'14 (Wet Car)
Xray X12 2018
Xray X1'16
wlrc.co.uk (West London Racing Centre)
RCDisco.co.uk
Skiddins is offline   Reply With Quote
Tekin Redline RS Sensored ESC and motors, opinions for offroad? Cain Electric Off-Road 4230 06-07-2015 04:38 PM
Sensored vs. Sensorless lemansracer Electric On-Road 71 02-14-2009 03:19 AM
New Tekin Redline Sensored Motors are Roar Legal! Randy_Pike Electric On-Road 3 08-05-2008 02:08 AM
Tekin Redline Sensored 10.5 HUCKMAN Electric On-Road 6 07-15-2008 08:50 PM
sensored vs sensorless bprocket Rookie Zone 5 05-16-2008 09:38 AM
Tags
v203, vegas 2.0
