Old 10-01-2008, 01:20 PM   #1186
Trader Rating: 32 (100%+)
I finally installed the RS Pros in my cars a couple nights ago and will hit the track after work.
joech is offline   Reply With Quote
Old 10-02-2008, 08:19 AM   #1187
Trips's Avatar
Trader Rating: 16 (100%+)
runnin my RS with a Tekin Redline 17.5 motor. First day out was Sunday. As I indicated in an earlier post, I was very impressed with the power and driveability. Never got the motor above 150 and the speedo never got hot. I'm running a Losi Type R indoor carpet on rubber tires.
I used a buddy's hotwire to set the speedo to around 90% timing in dual mode. Timing on the motor endbell was not moved from how it came out of the box. What should I expect if I were to crank the endbell timing and place the RS into sensor onoly mode? It['s great now, but if I could have a bit more rip or top I wouldn't complain...
thanx
MARSHAL!!
Trips is offline   Reply With Quote
Old 10-02-2008, 08:32 AM   #1188
I ran both my cars last night, my RS pro with Redline 13.5 ran great in my 008EU, lot of punch and top speed is good. However my Redline 17.5 didn't run as good in my 416. It didn't seems to have the punch or speed and my motor temp at 150 after 5 minutes. Both RS pro ran in sensor mode and max timming on motor. What is the FDR I should aim for the 17.5?
Thanks.
Old 10-02-2008, 09:53 AM   #1189
timmay70's Avatar
Thanks.
If you did not advance the timing on the motor itself, you weren't running with advanced timing. In sensor mode, the Tekin will run with the timing of the motor sensors. In hybrid mode, the system starts with the motor sensor's timing then switches to speed controller timing. When it switches to speed controller timing is when the timing you set in the speed controller will take over.
Either turn up the timing on the end of the motor, or gear up to make use of the surplus torque. Or, put the speed controller in hybrid mode and run both.
Speed Merchant Rev7, Tekin, TQ Racing (wire), Team Tamale
RC Excitement - Buy where you race, support your local tracks.
ROAR #105242
timmay70 is offline   Reply With Quote
Old 10-02-2008, 10:14 AM   #1190
Kenny L's Avatar
I got my rubber Phi going Tuesday night with Rs pro and Redline 17.5. Here are the settings I came up with car was pretty dailed motor temps 135max.
4.05fdr
Redline 17.5 w/full motor timing
hybrid mode
drag = 80
rev = 0
brake = 90
neutral = 10
blfw
throt = 5
volt = 2
push = 0
timing = 100
current = off
Team Tekin, Ko Propo America
Kenny L is offline   Reply With Quote
Old 10-02-2008, 10:16 AM   #1191
Thank you for the info. This Brushless thing is new to me. I did set the max timing on the motor and the RS pro is in sensor mode. Should I move the timing back and get the gearing right for the infield first and advance the timing to get the top end?
Thanks,
Joe
Old 10-02-2008, 10:18 AM   #1192
Thanks Kenny, I am going to try your setting next time out.
Old 10-02-2008, 11:49 AM   #1193
davepull's Avatar
Tekin RS pro 3400 lipo and the 17.5 redline installed in a Custom Works Aggressor.
davepull is offline   Reply With Quote
Old 10-02-2008, 11:56 AM   #1194
360rcspeedway's Avatar
Dave!
Is that my Snowbirds car???
haaa j/k
I do want to run oval though, gonna get a car setup for it def.
-Donny
360rcspeedway is offline   Reply With Quote
Old 10-05-2008, 05:07 PM   #1195
Need help i have RSPro Running a novak 10.5..Guys at my track running the same motor with LRP esc..They are faster all over the track..im running 4.42fdr they are running 5.10fdr..My motor is at 160-170-6min i also have the 13mm rotor in the motor..
S411, EX-10 Eurus DDS,Tekin,Novak,Trinity
Team SF-RcRacers(Some people enjoy eating are dust) Team Serpent
iceman76 is offline   Reply With Quote
Old 10-05-2008, 07:10 PM   #1196
Super Moderator
Marcos.J's Avatar
Trader Rating: 182 (100%+)
what timing are you running? also ditch that 13mm rotor get the smaller rotor it will make the motor spool up alot quicker and give you more rpm
Old 10-06-2008, 11:48 AM   #1197
Im running stock no Hotwire..
Old 10-06-2008, 12:03 PM   #1198
mangoman's Avatar
Unfortunately without the hotwire you wont be able to get the esc competitive against the other cars
You will need to find someone with a hotwire and get them to up the timing to around 90.
Hot Bodies Cyclone!!!
www.smaracing.org
www.rchobbies.com.au - www.feralbatteries.com.au
craig mcphee ( WHERE'S MY BEER )
mangoman is offline   Reply With Quote
Old 10-06-2008, 12:47 PM   #1199
i have one on order..Hope it works
Old 10-06-2008, 06:18 PM   #1200
mangoman's Avatar
If i recall correctly the default timing is set to 10 (on a scale of 100) so im sure you can imagine the difference when setting it to 90.
The other thing which people have been discussing is setting the motor to sensored only, then advancing the timing on the motor itself (although im not sure if you can do that with your motor). Apparently when you do that the esc runs more similarly to like a sphere.
Someone was explaining to me the differences in running a motor in unsensored and sensored a while back but i dont remember what he was saying.
www.smaracing.org
Tekin Redline RS Sensored ESC and motors, opinions for offroad? Cain Electric Off-Road 4230 06-07-2015 04:38 PM
Sensored vs. Sensorless lemansracer Electric On-Road 71 02-14-2009 03:19 AM
New Tekin Redline Sensored Motors are Roar Legal! Randy_Pike Electric On-Road 3 08-05-2008 02:08 AM
Tekin Redline Sensored 10.5 HUCKMAN Electric On-Road 6 07-15-2008 08:50 PM
sensored vs sensorless bprocket Rookie Zone 5 05-16-2008 09:38 AM
Tags
v203, vegas 2.0
